Question about Sewing Machines
How do you take the top off of a Bernina 817 sewing machine
Just need to know how to remove the top section of a Bernina 817 sewing machine. At first it looks like it just clips on. but there is some real resistance coming from the center. I don't want to force it in case i brake it
Any help would be great
  • jon_worrell Mar 13, 2009
    I have had screw drivers under it, but as you apply pressure you can see the lid/top deforming out of shape. It is made from cast Ally, who knows what grade it is and I don't fancy the idea welding and machining it to fix it...
    Well not for a sewing machine any way.. :)
  • Anonymous Mar 18, 2009
    Can't get the top off the 817 Bernina sewing machine.
  • 3 Answers
Open the face plate (the hinged door where the light bulb lives). Near the top and back, near the upper hinge, is a round, grooved button. Push the button and the top cover is released. It's in the manual, but the picture isn't clear, or something has changed. You can get a free manual by searching for bernina 817 manual pdf.
Posted on Jul 09, 2014
  • 6 Answers
SOURCE: Bobbin Carriage clanking noise, yet the machine sews fine??
If your bobbin area is making a noise, then do NOT sew with the machine until a reputable technician looks at it. You may have thrown something just a little off line - not enough to affect sewing NOW, but it could easily cause troubles down the line.
I suggest you call ahead and talk directly to the repair person - not to the sales person. Ask if you can bring in the machine while he/she is in the shop so they can listen while you run it.
You aren't trying to cheat the store out of the repair charge, just ensuring that the problem is diagnosed correctly.
You paid lots of money for this machine - it deserves good care.
Posted on Dec 30, 2007
RickE1
  • 202 Answers
SOURCE: How to open sewing machine case
Possibly thread got caught up where you can't see it either behind the hook or behind the handwheel. Not knowing what model machine you have your just getting generic answers here.
You will have to remove a cover and/or the handwheel to see. Its the only way it could be jamming up unless a gear broke
Good luck
Posted on Jul 31, 2008
SOURCE: bernina 180 thread breaking and tension problems
First make sure that you are using a new needle in the proper size. A needle with burrs on it will cause the bird's nest problem. Also, is the thread you are using old? My repair guy told me to keep my filled bobbins in the freezer to maintain their humidity, and that has made a world of difference in my stitching. Finally, how long has it been since you had the machine cleaned and serviced, and was it by an authorized Bernina repair shop? Bernina machines have special screws that only Bernina authorized repair people have - I discovered that when I took my machine in to someone who was not authorized only to have the timing go off in a matter of weeks. The authorized repair guy found clumps of thread that had been air blasted into the inner works of the machine and those clumps were getting caught up in the new stitching and causing the same problems you described. Good luck!
Posted on Feb 28, 2009
Mimito7
  • 128 Answers
SOURCE: user manual download bernina activa 140 sewing machine
Try this... www.2instructions.com
Posted on Apr 30, 2009
RickE1
  • 202 Answers
SOURCE: I have bernina sport 801 machine and need to know
You can oil any two metal parts that move togeather or through each other. Do not oil bearings and do not oil gears. Do not use 3 in 1 oil or WD-40. Use regular sewing machine oil.
801's were made from 1979 - 1982. The way Bernina dated these on the machine is by the serial number. Your number would probably start with a 0 or a 1. 1970 is a 0, 1971 is 01, 1980 is 1, 1981 is 11, 1990 is 2, 1991 is 21 etc. etc.
Rick
Posted on Oct 08, 2009
How do you thread the bernina 1230
You can probably use the manual for the 1260. Sewing machines basically thread alike from one model to the next.
One thing to remember: ALWAYS RAISE the presser foot when threading the top thread! This will help prevent those dreaded thread nests under the fabric.
BERNINA Sewing Systems (in the Out of Print section)
Jul 25, 2017 | Bernina Sewing Machines
Bernina sewing machine 1630.. Stitch won't stay in. Bobbin thread pulls out ???
Clip the top thread next to the spool. Raise the presser foot and pull the clipped thread DOWN through the needle eye. (Always remove the top thread in this manner. NEVER pull the top thread up!!!)
Now, ALWAYS RAISE the presser foot and rethread the top thread. Verify the thread path is correct.
Set the top tension to the midway point (then tweak the tension by testing).
If the bobbin thread is still pulling out, the top thread tension needs to be tightened. The tension is correct when the top thread and bobbin thread meet in the middle of the fabric.
Understanding Thread Tension Threads
How to Achieve Ideal Sewing Machine Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Jun 27, 2017 | Bernina Sewing Machines
Where can I get power cord, foot pedal, and manual?
About 17,700 results (0.94 seconds) Search Results
    Bernette Sewing Machines - BERNINA Support: Machine ...
    www.bernina.com/...Manuals/bernette-manuals/Bernette-Sewing-Machin...
    Bernette Sewing Machines Within this section are the Bernette series of sewing machine manuals that are no longer ... bernette 50 / 60 / 70 / 75 Manual (7.4 MB).Missing: power
    [PDF]Manual - Bernina
    www.bernina.com/de/.../BERNINA.../bernette.../Manuals/deco340_EN_...
    Congratulations on your decision to buy the bernette Deco 340. By owning .... Insert the power supply plug into the wall outlet and turn the power switch on. 1.
    BERNINA Support: Machine and Accessories Finders, and ...
    www.bernina.com/en-US/Support-US
    Out of Print Manuals. Out of ... BERNINA FAQ - Find answers to frequently asked questions. ... Please note: this service can only address SOFTWARE questions.
    www.bernina.com/.../BERNINA.../BERNINA.../Manuals/0333017104_2...
    You've decided on BERNINA, a reliable choice that will delight you for years to come. For over 100 .... Power cable. · .... control the sewing speed by pressing the foot
Feb 03, 2016 | Bernina Bernette 75
I would like to hear about other owners of the 880 and what problems they have had.
BERNINA 880 Review ' Sewing Insight
www.sewinginsight.com/bernina/bernina-880-review/ Mar 12, 2015 - A site visitor asked for a review of the BERNINA 880. ... Usually, machines that sew at speeds up to 1000 embroidery stitches per minute also come with considerably more ..... Beverly Rutherford Brother Innovis 950D Review ...
Sewing Machines >> Brother "The Dream Machine" or ...
sewing.patternreview.com > Forum > Sewing Machines Jan 13, 2015 - 10 posts - ‎9 authors Pattern Review ... Subject: Brother The Dream Machine or Bernina 880 Date: 1/12/15 ... Embroidery/Sewing Combo: Brother Dream machine.
Bernina 880 - Sewing Machines and Patterns Review
sewing.patternreview.com > Forum > Sewing Machines May 9, 2014 - 10 posts - ‎9 authors Bernina 830LE - Brother Dreamweaver VQ3000 - Bernina B530 - Janome ... I just read the manual a bit, then started tinkering and I had a ...
Customer Reviews: Bernina 830 Embroidery and Sewing ...
www.amazon.com/Bernina...Sewing-Machine/...reviews/B0081A3KMQ The 880 also has a stronger/different motor that can run at 1200 stitches per minute ... One is the way the camera works on some of the Brother machines, as well as ... I hope this review helps anyone wanting to buy any sewing machine really.
Bernina 880 - Sewing Machine Review - Top Ten Reviews
sewing-machine-review.toptenreviews.com > ... > Sewing Machine Review Search. Appliances » Other-Household » Sewing Machine Review » Bernina 880 ... Compare to the Top 3 Sewing Machine Review ... #2 Brother PC420PRW.
Best Sewing Machine - Bestcovery
www.bestcovery.com/best-sewing-machine-overall Apr 27, 2015 - Read our reviews to find the Best Sewing Machine and compare photos, specs and user reviews. ... The Bernina 880 Quilting and Embroidery Sewing Machine is ... The Brother XL2600I Sew Advance Sew Affordable 25-Stitch ...
Dec 27, 2015 | Sewing Machines
I inhereted a bernina ferreit in cabinet need instruction manual
I believe you probably have a Bernina Favorit. A Favorit is an early mechanical Bernina sewing machine and, to Bernina vintage lovers, is a keeper. Favorits are the flat-bed version, not the free-arm version, but is a wonderful machine nonetheless. If you search the internet using:
Brand +
Model +
the word "Manual"
(ie Bernina 640 Manual)
you might have some luck finding a manual.
Or, you can join the Yahoo BerninaThirtySomethings group
Yahoo Groups, where older manuals are available in the Files section. In addition, you will have access to a wonderful resource of Bernina users/lovers including conversations on using, maintaining, repairing, and assorted other advice about your older Bernina.
The first thing you should probably do is pick up a good quality sewing machine oil (Bernina oil for CB Hook is recommended--however, never use 3-in-1, WD-40, cooking oil, or the old oil can that you might find in the machine's accessory box). Consult the owner's manual in the Maintenance section to clean and oil your machine. If the machine has not been used in several years, the motor may sound like it is straining to move the mechanical parts. Most likely, the old oil has dried out and is sticking things together. Do not force the motor to move things without first cleaning and oiling the machine.
Remove the top cover and swing open the cover on the left side where the lightbulb is located. Gently hand rotate the handwheel and while watching the moving metal parts, apply ONLY one-two drops of oil every place that metal rubs against metal. (Sometimes the oil ports are marked with red paint as a guide, but some machines are not marked.) Use only 1-2 drops at a time. Do NOT over-oil as too much oil can be as damaging as no oil. Gently move all the levers and dials and oil those moving parts as well. Do NOT oil the white plastic gears, the belt, or the large round metal cams (which your machine may or may not have). Then, tilt your machine back and remove the bobbin & bobbincase and with a soft brush, remove any lint, dust. Then while hand-rotating the handwheel and moving the levers and knobs, apply oil to the moving parts under the machine. The feed dogs are usually a problem so be sure to test the feed dog knob. If anything seems to be sticky, resistant to movement, you can also direct hot air from a handheld hairdryer into the interior mechanism to help loosen things. Be sure to place a drop of oil on the bobbin hook in the bobbin area (the manual should show this).
If there is anything that is still sticky, then a few more drops of oil and the handheld hairdryer should be employed until things are moving well again.
A Bernina is a great machine for the sewing enthusiast, but only if it is maintained and cared for regularly. Cleaning and oiling should be performed approximately every 8-12 hours of constant sewing, or every time a bobbin is emptied, or at least every six months if not in frequent use.
Aug 30, 2015 | Bernina Sewing Machines
My bernina 707 minimatic..isn't working!! My needle keeps getting seized an won't move up an down...Then when i try to sew it sews blanks....
Replace the needle.
Make sure the needle is inserted the right way. If the needle is installed the wrong direction the machine will get stuck.
Check and correct tension of the bobbin. (Guide attached)
Start the top tension at four and adjust as needed.
When threading do it with the pressure foot up so any snags can be felt. If there are snags they must be corrected. While threading, little tugs of the thread along the way will help. The snags can be felt this way.
Aug 25, 2015 | Bernina Sewing Machines
How do I remove the back panel of my Bernina 1080 sewing machine?
The back panel on the BERNINA 1080 is not removable. These machines are cast metal, and the main body does not disassemble. The top of the machine will come off, but what it sounds like is that your bobbin winder is engaged, and the clutch in the machine is preventing the machine from turning. Try disengaging the bobbin winder and see if your machine will run. If not, I would reccomend taking your machine to a certified BERNINA technician for repair.
You can locate a BERNINA Dealer using the locator at the attached link.
Find Dealer easily find your nearest BERNINA dealer BERNINA
Mar 11, 2015 | Bernina Sewing Machines
Rick
Sep 20, 2009 | Bernina Sewing Machines
Sewing Machines Logo
420 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
