Question about Honeywell 3820 Wireless Handheld Barcode Scanner
Will not hold charge? - Honeywell 3820 Wireless Handheld Barcode Scanner
WHY isn't MY TOMTOM CHARGING? It's BEEN PLUGged IN FOR 45 MINS.
Usually an old (or older) battery will no longer hold a charge ... or will only hold a small charge (that will let you run the GPS for only a few minutes).
Often, when the TomTom device is always connected to the charger (in a vehicle), where it charges every time the car is turned on, whether the TomTom is being used or not, the battery gets charged (partially or fully) often enough to use up the "maximum number of charge" cycles for the battery. Hence, it will no longer charge properly or hold a strong charge.
Like for all lithium batteries, it's better if your device is not always connected and being charged (whether you are or are not using it). The battery will last longer and it will still be able to hold a stronger charge.
Feb 24, 2016 | Tomtom GPS
If my vehicle receices a jump start and it won't hold a charge , what is wrong with it ?
Depends.
If the alternator is charging, and the battery will not hold a charge, I would suspect the battery.
If the alternator is not charging the battery, I would look at the fuseable links and connections.
Aug 14, 2012 | Chevrolet TrailBlazer Cars & Trucks
My old 611 dosent hold the battery charge for long even though I have put in a new battery
An in car charger will not charge as well as the mains, when charging for the first time you should use the mains, and charge for at least 8 hours. If it didn't charge correctly, it will be the same low charge all the time, as the battery has a memory that makes it charge the same each time. Try charging from the mains, you might be lucky.
May 22, 2012 | Cell Phones
Does not hold battery charge
Since you have a new phone and a new battery and is still doesn't work ... the first step should be to take it back to where you got it ... have then evaluate it for possible replacement.
May 16, 2010 | LG Shine KE970 Cellular Phone
Phone not holding charge with new battery
Have you try to use another charger to charge and it doesn't hold charge? if yes., no problem because it be that your charger is bad. But since it does not charge with another charger, it means the charging port is bad.
The problem with the phone is the charging port, the charging port of your phone is not charging the phone that is why it doesn't hold any charge,
All you need to do is to change the charging port of your phone and you will see that your phone will hold charge.
Take care.
Apr 28, 2010 | Motorola Mobility SLVR L7 Cellular Phone
My sanyo pm 8200 wont hold charge!
Since the battery and charger are new and yet it does not still hold charge.
Have put the battery in another similar phone and try to charge with your charger to see if it will hold charge? if you have.
It means the charging port of your phone is bad and you will need to replace it.
The charger is not charging the battery in anyway because the charging port is bad, so just change your charging port, your phone will now hold charge.
Take care.
Apr 14, 2010 | Sanyo PM-8200
Battery not holding charge
hi dave_hanc93
you say its not holding a charge, but is it charging?
plug the charger in and make sure the light is on on the charger, then on the map screen, tap the screen where the satellites are. on that screen on the top right is the charge indicator. is it green and moving from left to right? if not, then its not charging.
try hooking it up to the home dock to your computer and check and see if its charging on the home dock.
let me know how you make out.
bill
Oct 08, 2009 | Tomtom GO 910 GPS Receiver
Ryobi 18v One+ battery won't hold a charge. I have two of them and neither one will hold the charge. The charger is the Ryobi 18v charger plus.
Does it not hold a charge, or will the charge not indicate "fast charge"? I had to apply a initial jump charge on the battery to get it up to 20 volts, then I put it in the Ryobi Charger, and it started charging it.
Mar 29, 2009 | Ryobi 15" Electric Factory Reconditioned...
Stuck on hold
Sounds like the hold switch itself is bad. You may need to RMA it, or take it to a local electronics repair shop.
Jun 20, 2008 | Sony PlayStation Portable (PSP) Console
IRiver H340 new battery won't hold a charge!!
It can be the charger that is actually causing your battery to not hold a charge. The closest thing to you would be www.iriverstore.com. connie
Jul 09, 2007 | iRiver H340 MP3 Player
Honeywell 3820 Wireless Handheld Barcode Scanner Logo
46 people viewed this question
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
ray gallant
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
