Question about Zanussi ZDF3020W Dishwasher
Zanussi error code ih - Zanussi ZDF3020W Dishwasher
ERROR CODE C-3B08
Code
C3B08
Description
IH input voltage error • While the IH heater was ON, input power was at the high voltage detection value or over for more than the predetermined period of time. • While the IH heater was ON, input voltage was at the low power detection value or under for more than the predetermined period of time
Causes
• IH coil unit (IHC) • IH power supply (IHPU) • Noise filter (NF1) • Printer control board (PRCB)
Remedy
1 Check the connection of the fusing unit. 2 Check the fusing unit, IHC, IHPU, NF1 and PRCB for proper connection and correct or change as necessary. 3 Check the marketing area of the fusing unit. If the marketing area is incorrect, replace the fusing unit for proper marketing area. 4 Check the marketing area of IHPU. If the marketing area is incorrect, replace IHPU for proper marketing area. 5 Replace IHC 6 Replace IHPU 7 Replace PRCB 8 Replace NF1
Jun 29, 2012 | Konica Minolta Office Equipment & Supplies
Error code c447
Fuser error...
Clear the message... 08-400 "0"
If occur again, u need to check the fuser probable, such as themistor, IH board, connectors and etc...
Apr 05, 2012 | Toshiba COPIERS E-STUDIO 520 Copier
I have a Toshiba 350 copier ans it has a error code c440
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
please vote me.
Thanks
Best Regards
Mar 07, 2012 | Toshiba e-Studio 350 Copier
Toshiba e-282 printer says call for service
please hold down 8+c and let us know what the error code is it will be shown on the display
if the error is c440 then do the following
switch off the machine
while holding down 8+0 switch on the machine
when the machine is in test mode key in 400 and press start button
key in 0 and enter switch off the machine wait a few seconds and switch on the machine if your code is c440 that should clear your error
Apr 05, 2011 | Toshiba e-Studio 232 Black and White...
Error code c440. call for service toshiba studio 352
Fuser unit error code, need to replace fuser unit
BR
Feb 11, 2011 | Toshiba Estudio 200L Copier
How to solve a problem error code c44 e studio 163
C44 Abnormal fuser after abnormality judgment
1,2.3. Check the thermistors, IH control board, IH coil and LGC board
Check the above components following the procedure 1, 2 and 3 for [C41].
4. Clear the status counter
Change the current status counter value (08-400) “4” to “0” for [C43] and “5”, “7” or “9” to “0” for [C44], taking
the same procedure as that for [C41].
* The status counter value is as follows in the following cases. Change them to "0" respectively.
• The error occurred during warming-up: "4" or "5"
• The error occurred after the machine has become ready: "6"
• The temperature detected by the center thermistor is 230°C or higher: "9"
• The temperature detected by the side thermistor is 270°C or higher: "9"
Nov 23, 2009 | Toshiba e-Studio163 Copier
''toshiba e-studio 720 error code c473
This is an overvoltage error....Really need a tech to fix this...could be bad wall voltage....or the thermostat in the IH unit...or the fuse in the IH unit...or the logic board....
Oct 31, 2009 | Toshiba E-STUDIO 720 Copier
Toshiba 160 error code
For error code C44, it indicates Heater abnormality.
If happen again, then u need to check the thermistor. Replace it if necessary. If themistor replaced but still happen again, then u need to proceed to check themostat--> heater-->Mainboard-->Switching regulator.
Mar 09, 2009 | Toshiba E-Studio167 Copier
Zanussi ZDF3020W Dishwasher Logo
47 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
