Question about Kensington Electronics - Others
USB PROBLEM my pendrive not shown either in my computer or disk management and driver is ok on device manager
  • Kensington Master
  • 27,725 Answers
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts you might have restore it to its defaults Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7 Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
Posted on Mar 01, 2013
razorbak15
  • 55 Answers
SOURCE: Pen drive not showing in My Computer
Try to Format it. Its too costy to get it back to life, your pendrive is screwed :(
Posted on May 28, 2008
SOURCE: transcend 4gb pendrive not being detected in Win XP
my 4gb pendrive is not detecting in my win xp operating system,before 2,3days i repaired my operating system,after that it is not detecting..pls help me
Posted on Oct 29, 2008
pankaj_dic
  • 1250 Answers
SOURCE: transcend 4gb pen drive not getting detected
pen drives generally have 3 to 5 years warranty, if your pen drives are not detectng on other systems also, its better to replace it
Posted on Nov 03, 2008
SOURCE: XP (SP2) not recognising Maxell USB Flash Drive 2.0
whan i fix my usb in computer and try to open it ,the message appear "please insert a disk into drive d".
what is it? how could be solved this problem? help me
Posted on Nov 21, 2008
Dr_Joseph
  • 86 Answers
SOURCE: Please insert a disk into Drive E
probably you removed the pen without properly stopping the device.
usb pens are sensitive about this. you must use an icon that is on traybar to stop usb storage devices before removing them.
now it is probably in read only mode or damaged.
if it is still inside warranty try to replace it.
Posted on Jan 26, 2009
My Transcend v30 pendrive is not working i had checked it in other computers but it was not working
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Apr 23, 2011 | Transcend (589307) Media
Pendrive is shown in my computer but it does not shown in disk management and dos.if you try format it then error occurs "windows was not unable to format it"
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall then
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start or you might tick one box then return after its finished the first repair the tick the second box
click start click on my computer you should see your pen drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps don
Mar 01, 2011 | Computers & Internet
4 gb pendrive led glows but now shown in my computer, i tried to check in many computers and laptops but the same problem. please help me.
umm, how old are your computer and laptops that you're using to check?
It could be that they don't have a USB 2.0 port.
Is there any message at the bottom right of your computer when you plug it in saying anything related to a USB device.
Also you can click on Start/"right-click" My Computer/Manage/Device Manager/Universal Serial Bus Controllers --- make sure that this says it's working properly and enabled.
Dec 09, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Need driver for pny 4Gb Pendrive. It is saying Please insert disk when i try to open my pendrive. it is displaying in Devise manager.
Normally most of the pen drive are plug and play means the hardware is recognised automatically by windows.
Try the following steps below:
>start
>setting
>control panel
>computer management
>in left column click disk management
>then you can perform format according to your choice.
ok try this and let me know
Any other help, you are most welcome
Regards
Uttam
Jan 26, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Have Sony 1GB memory stick "magic gate" that wont open on my laptop vista
ok
try
these steps:
1.plug your pen drive 32gb in your computer.
2.then open Control panel.
3. open administrative tools.
4.open Computer Management
5. a window label computer management will appear.
6. click disk management
7.locate you pendrive and select delete partition or format it fat 32 or other format convenient for your usage.
ok
hope this will help
cheers
uttam
Jan 17, 2010 | Lexar JumpDrive Classic Portable USB Data...
"insert a disk into drive"
right click my computer
manage
in right panel double click storage
double click disk management(Local)
right click on the pen drive shown and click format
Oct 03, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Kingston DT1000 pendrive was not detected in computer
hi there.
this is what i have just found on the internet it might help you out but not sure.
After plugging in the device. Go to device manager (In run type "devmgmt.msc") In Device manager go to "Universal serial bus controllers" It should list the storage devices that you have connected to your PC. Right click and then click "Uninstall. Remove the USB drive and restart your system.
Try connecting the device again, I think this should solve the problem.
for windows xp
first you need to go to Device Manager by double-clicking on the System icon in Control Panel, choosing the Hardware tab, and clicking Device Manager.
go to divice manager
usb hub controler it will be at last of the list then
right click on usb hub controler open it go to usb root hub right click & go to properties
then go to device and click ok
do it 4 to 5 time it will work 100%
i have tried it and it worked
Best of luck :)
hi do one thing go to my computer right device manager ther u to o universal serial bus right click on tht option go to update driver select yes this time only give automatic k . before doing this step plz insert mother board driver cd after tht u do all this procedure thn c ur pendriv vl be dedected k
if none of the above works try this link out.
Kingston DT 1000 pendrive was not detected in computer Google Search
Nov 20, 2017 | Transcend (589307) Media
hello sr my pendrive wn i connect to my pc and it is not showing and option in my pc so is it any damage at pendrive and how can my pendrive work
May 19, 2008 | Electronics - Others
Pen drive not shown
Right click on my computer and goto "Manage" -> disk management and select your drive and assign drive letter for the pen drive.
Dec 12, 2007 | Electronics - Others
Electronics - Others Logo
67 people viewed this question
Top Kensington Electronics - Others Experts
Are you a Kensington Electronics - Other Expert? Answer questions, earn points and help others
