Question about HP Photosmart C6180 All-In-One InkJet Printer
It does not print
It says there is a problem with the cartridge but I already checked each ink cartridge, they are all original and the all seem fine. The device that moves form one place to another when printing seems not to be moving and it says error:
oxc18aoo1
  • 240 Answers
Try to press and hold the power button to print the system setting. or if you can access the menu on printer ,print the printer setting, if you still have the CD included when you purchased the printer ...there is calibration utility sftware in that cd..you can use the software to diagnose the problem if hardware or setting
Posted on Mar 13, 2009
Mx860 prints too light
Replace your ink cartridges again. Seem like the print heads are busted already. Try returning the cartridges to the seller or ask to have them replaced.
Nov 23, 2013 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Epson Sx415 New Cartridge,empty already?!?!
1. New original ink tank will dried for several times of head cleaning procedure.
. ....ran a nozzle check and cleaned print heads because it wasn't printing any ink on the paper.... ???
Nothing at all? If yes, problem is in the printer main board. Lost electricity to the head.
Jan 13, 2013 | Epson Office Equipment & Supplies
Original Vs Compatible Ink Cartridges - Which is Better?
If you will be printing large numbers of documents and other files then compatibles make good financial decision.
Compatibles are cheaper than originals. However you should check that you are getting good quality compatible ink cartridges.
As long as you are printing at least once a week then compatibles will serve you well without problem. To keep your printer in tiptop condition you should swap for an original cartridge once in a few months. This may seem like a foolish idea when you are saving money, but an original cartridge will help clean your print head and keep your machine working optimally.
If left for a long time ink can dry out in the cartridge and on the print head causing damage. Original ink usually has extra chemicals and agents to prevent this from happening. As you are likely to have to buy a new compatible cartridge if this happens any cost saving you achieved lost immediately.
Aug 12, 2010 | Brother Office Equipment & Supplies
ESP9 color prints begin coming out purple like
Use only original ink cartriges, the non original has ink normaly is not for you printer, and you wast your money and damage the printer print-head
Jan 02, 2010 | Office Equipment & Supplies
Out of original Versajette Ink
Not,. Also you need the original versaink.I think because it is specilly designed for checks.
Feb 15, 2009 | G7 Productivity Systems VersaJette M300...
Unable to print with new ink carts
Usually, that message means that your cartridge is dead. Try removing it, clean the electric contacts on it and the ones on the cartridge carrier. Put it back in. If that doesn't help, you will need to buy a new color cartridge.
If you do not have a replacement cartridge, you can still print in, what HP calls "ink backup mode". Simply remove the problem cartridge, and print with the remaining one, in this case, the black one.
  • If you remove the tri-color cartridge, printouts will be in grayscale.
Dec 23, 2008 | HP Deskjet D4160 InkJet Photo Printer
Print cartridge in right stall not supported
Are these genuine HP ink. If not try using Original ink.
If its already the original ink then check the Exp date of the ink and try cleaning the copper contacts of the ink ( not the nozzles ) of the ink and the printer
All the best
Sep 24, 2008 | HP PSC 2410 All-In-One InkJet Printer
No colour printing
The problem with Canon printers sometimes is that, if you do not use original cartridges and put compatible ones, the printer will not recognise them. Even if you refill the originl ones the printer will still think that they are empty due to the microchip that every cartridge has. Try using original inks. If you already used original inks, then another reason might that the ink tubes have benn blocked because of dried ink if you haven't used your printer for a long time. Try performing a deep clean through the printer application.
Hope that helps
Apr 20, 2008 | Canon i80 InkJet Printer
Canon MP530 U052 Error
The dreaded U052 error means that the 'chip' fitted to the Cartridge is not responding .. Canon (like all printer mfgs) makes all it's profit from selling Ink .. so they fit these chips to try to prevent you refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and (it seems) the chips are particularly sensitive to static / damage .. many people end up blowing the chips during the swap over .. or even when fitting the original genuine cartridges to a brand new unit for the first time ...
If the unit is brand new, take it back and demand a replacement ... if you have just swapped over the chip onto a compatible cartridge, you can try buying a genuine Canon cartridge (which will have a new chip) = hopefully that will do the trick
NB. I have seen some suggestions that canon's have a 'Service Mode' that allows you to disable the cartridge chip checking and allow you to print no matter what .. however I've never found any details ... perhaps some-one else has the details ??
Feb 05, 2008 | Canon PIXMA MP530 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
32 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
