Question about Canon CLC 1120 Color Copier
Clc 700s E020 error
I can print just black and just cyan but not yellow or magenta
  • vinces642 Mar 15, 2009
    thanks for the info i check the connetions .also i get a cleaning web need to be replaced message but it's not a error
    can't get in servic mode on my clc 700s i have no * on my key pad to * 2&8 * also all my dev's are pluged in, still i cant print full collor .if i select color crection and select bk or cayn 1 at a time it will prin, if i select yellow or magenta i get a e020 error and turn offf and turn on again
    Problem Solver:
  • 7 Answers
Your cartridge is not conected Yellow&magenda cartridge mg Roller earth connect
Posted on Mar 13, 2009
WHENEVER THE MACHINE PRINT CYAN COLOR ITS GET AN ERROR E020 0200.. ALL THE SERVICE ENGINEERS HAS CHEKED BUT IT HAVE THE SAME PROBLEM
You might have a seized cyan developer unit.
This error is caused by drum motor drive stopping or being overloaded.
Jan 25, 2010 | Canon CLC 1150 Color Copier
CLC 1180 with error E020 with sub 124
first check this site for the error codes.
clik here
The error code E020 refers to a density problem with one of the Drum Units.
ur hopper motor has jammed and it is not allowing the toner to go to the developer just open the hopper motor and put it into the developer or remove the connecter attacted to the developer. it will work . there is a gear actually on the motor which breaks.
So the only sol. is to replace, if it is under warranty caontact the customer care..
Goodluck,
Dont forget to rate me as fixya..
Jan 29, 2008 | Canon CLC 1150 Color Copier
I have an older Canon clc 900 Error E020 Switch power on and off again"displays when trying to copy. When I turn the copyer off and on again the same message displays.What to do ?
Error :
Intermittent E020 / E061 codes.
Workaround :
It's possible that there is a poor drum ground from the static eliminator brush. You may need to replace the static brush with the drum grounding leaf spring from a CLC 350 (part numberFA5-9308-000). Follow the procedure in technical publication CTP.NO 700/800-69.
Error :
E020 sub code 0440 and light density on all colors
Workaround :
Check the developer assembly movement, i.e. up & down and that the magnetic roller is turning. Check the EPC readings, laser output, fold back mirror, and the connectors for the developer and the developer bias contacts. If all the above checks are good, then the problem can be with the AC voltage output of the developer bias HVT. The DC-voltage for the developer bias is split between two colors ( magenta & yellow ) or ( cyan & black ). The AC voltage is supplied for all four colors and it's loss will be seen in all the colors whereas the loss of the DC voltage would affect only two colors. To fix the problem replace the developer bias HVT part # FG5-3068-060.
Oct 18, 2009 | Canon CLC 1150 Color Copier
Error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Aug 20, 2009 | Canon imageRUNNER C3200 Copier
E020-0200 canon lbp5970
check your magenta or cyan developer .this is a generic error for all canon copier developer unit
Jun 27, 2009 | Canon CLC 1110 Copier
Error codes E00020-01b0
you need to replace your yellow drum unit with a new one, error code is as follows E020-01(yellow), -02 magenta, -03 cyan, -04 black. for future referrance
Jun 05, 2009 | Canon imageRUNNER C3200 Copier
E020 02FF Error
the problem this in tolva of cian
Sep 05, 2008 | Canon CLC 1120 Color Copier
CLC 1180 with error E020 with sub 0124
Did you change the Magenta stater/ developer? A E020 code is saying that the toner desity is low. Try replasing the developer and run the ATDC for Megenta and see if that helps. You may have a problem with the developing ass'y it self. You may be able to take another colors dev. ass'y with the hopper open and see if the code goes away. The sub code 0124 means that it is the Magenta dev. ass'y
Error Code
SPECIFICALLY...you need to replace the Black drum unit.
the sequence of that particular error code is;
E020-01XX(Yellow drum)
E020-02XX(Magenta drum)
E020-03XX(cyan drum)
E020-04XX(Black drum)
Apr 02, 2007 | Canon imageRUNNER C3200 Copier
Canon CLC 1120 Color Copier Logo
117 people viewed this question
old marine
old marine
