Question about Toshiba Satellite Pro M300-S1002X Notebook
How to turn off number lock
I have separate keyboard p[lugged into my laptop and it automatically turns on the number lock on the laptop keyboard. How can I turn it off?? I can turn of on the separate keyboard and then unplug it and it turns off for that period of uise but when laptop turns off and I turn on again th number lock is on. Appreciate yourt help.
  • 240 Answers
Press Hold Fn key + F4
or change the setting to bios Set up to Disable Num Lock
Posted on Mar 13, 2009
Can't get past lock code
Laptop computers have the advantage being portable and self-contained, but among their drawbacks is a keyboard without a separate number keypad. While for most applications number keypads are unnecessary, they can be useful for data entry. Laptops sometimes provide a number keypad by giving certain keys double duty, allowing them to enter numbers rather than letters when a "Number Lock" setting is turned on. Number Lock, however, can get turned on accidentally, or enabled by an operating system by default, which can really mess up your typing. If typing "M" ends up displaying a "0" on your screen, Number Lock is probably the problem.
Try to locate the function key. On a T-series ThinkPad, it's in the lower left hand corner. It should be labeled "Fn," and the lettering may be blue, green or red instead of white. If your laptop lacks a "Fn" key, use the "Shift" key for Step 3 below instead. Locate the key labeled with "NmLk". On a T-series ThinkPad it shares a key with "ScrLk" which sits on the very top row between the "PrtSc" and "Pause" keys. On other IBM laptops, the "NmLk" key might share a key with "Delete." While holding down the "Fn" key or the "Shift" key, depending on your model, press the "NmLk" key. This should turn off Number Lock and restore your keyboard to its usual state. Number Lock on an IBM laptop is a "toggle" setting. You can turn Number Lock on by following the same steps.
b>
Feb 05, 2013 | IBM ThinkPad Computers & Internet
Lenovo p580 numlock off
What options have you tried ??
Number Lock on IBM Laptop Computers b> Laptop computers have the advantage being portable and self-contained, but among their drawbacks is a keyboard without a separate number keypad. While for most applications number keypads are unnecessary, they can be useful for data entry. Laptops sometimes provide a number keypad by giving certain keys double duty, allowing them to enter numbers rather than letters when a "Number Lock" setting is turned on. Number Lock, however, can get turned on accidentally, or enabled by an operating system by default, which can really mess up your typing. If typing "M" ends up displaying a "0" on your screen, Number Lock is probably the problem.
also Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
Jan 30, 2013 | Computers & Internet
When my number lock is on the letters will not print as stated they will print a number or other
This is normal for a keyboard with embedded number pad, rather than a separate 10-key area. Turn off the number lock to type the alphabetical characters and use the top row of numbers to enter values. Turn on the number lock when entering only a long string of numbers.
Alternatively, connect a USB external keyboard to the notebook. Either get a large keyboard with a separate number pad or get a 10-keypad only (http://www.cyberguys.com/product-details/?productid=37379 ). Then you can have a normal keyboard and stil have the 10-key functions without toggling the NumLock often.
I hope this helps.
Jun 11, 2011 | HP Pavilion DV9620US Notebook
When I write text on the laptop keyboard, only numbers show but no letters. what to do?
Try reset your laptop. Remove the battery and allow 1 hour before re-inserting the battery. Then get back to me what happen.
Nov 04, 2010 | IBM Thinkpad 560 Series Laptop 20h4241...
I have an Asus X58L laptop, For some reason there is a letters lock and I do not know how to unlock it. So if I press letter u it gives me 4, if I press p it gives me - and so on, unless I press Fn button
It sounds like you have the num lock switched on, most laptop keyboards are too small to have a separate numeric keypad so use the letter keys on the right side of the keyboard for this. (you should note numbers as well as the expected letters on the face of these keys).
To turn off the num lock, hold down the Fn key and press Ins. (located top right of the keyboard).
Jun 27, 2010 | ASUS Laptop Keyboard for Asus Eee PC
Where is the Fn key an a dell keyboard?
This is a simple problem, due to the size of laptops, the manufacturers cannot fit on a normal number pad as on a standard keyboard, so what they do is use a function key to turn a portion of the keyboard in to the number pad.
to get rid of this you need turn the 'number lock' off this may be a single key or a combination.
for my laptop its:
press together; the function key (normally 'Fn' bottom left) and the number lock key (Num Lock).
hope this sorts out the problem.
May 30, 2010 | Acer 91.63X07.001 Keyboard
On my hp 6735b laptop I would like to turn off the scroll zone on the touch pad if possible.
You don't specify what system are you using. In Windows you have to go to Control Panel, Mouse and Pointing Device properties, and find your touchpad options there, including the scroll areas.
If it's not there, chances are there is a separate application, either in Control Panel, or in the Start Menu, for setting up the touchpad. You can also look in the system tray beside the clock - often there's an icon there for the pointing device.
Nov 25, 2009 | HP Compaq 6735b Notebook
Laptop keyboard is not working correctly
Accoring to the problem you have mentioned i am sure the keys are not connected properly. The tab key is connected on the Caps lock key. Moreover make sure you press the fn key to check for any changes as it is the key which helps you toggle in Laptop
Oct 08, 2008 | Dell INSPIRON 6000 CENTRINO...
Keyboard
The Numeral Lock mode is turned on by pressing the key named "NUM LOCK" which is usually located on the top of the number keypad (on far right side of keyboard).
However, laptop keyboards are different. Most laptops do not have a separate numeral keypad set. Those laptops usually use a blue (or other color-coded) "Fn" key, on the bottom left. You must press that Fn key at the same time as the "Num Lock" key of same colr. Then a light comes on to indicate the mode change, and some alpha-numeric keys on the keyboard now become your numeral keypad. On mine, it is 789, UIO (456), JKL (123) and M (which is zero).
If this is too confusing, you can plug in a cheap full size desktop keyboard, using the USB or PS2 port on your laptop. That is what I prefer, because the funky integrated dual-key deal interferes with all the touch-typing I learned 37 years ago.
Feb 10, 2008 | Compaq Presario 1275 Notebook
Toshiba Satellite Pro M300-S1002X Notebook Logo
935 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
