Question about Sony Playstation 3 (PS3) Console
Ps3 3 blinking lights
When i turn on my ps3 within a few seconds i get 3 beeps and then the light flashes red. I have tried a new hard drive. I am thinking about trying a different power supply.
  • 4 more comments
  • crimsonflood Mar 13, 2009
    Light turns green blinks yellow and then right back to red. Turned off during gameplay now wont turn back on.
  • zuse1000us Mar 13, 2009
    I am using the original powercord. If the cpu is bad can i buy a broken playstation and take the cpu out of it?
    it is using the original power cord. It has turned on before. If it is the cpu can i take the cpu from another one and put it in there or is the cpu connected directly to the motherboard? and if it is connected directly to the motherboard can't i take the motherboard from another one and put it in this one
  • zuse1000us Mar 14, 2009
    if i use another motherboard does it have to be a motherboard from another 80gb ps3 or can it be from a 40gb or 60gb?
  • pnz 38 Mar 30, 2009
    I have 40 gb model.Light turns green blinks yellow and then right back to red.please tell me what do do if worth to fix.
  • Kristie steiger May 11, 2010
    are you using the original power supply that came with it?
    Has it ever turned on?
    Novelist:
  • Sony Expert
  • 172 Answers
Hi my name is Juan and unfortunately your ps3 is dead what happen is that for some reason it got so hot and the processor stop working when you turn on the ps3 it does a self test and if something is not working right it turns off immediately with a green yellow red light so don't spend your money in another power supply I can guaranty to you is not the power supply I do sell and fix playstations and this is why I know this this problem is common on the 60Gb and 80Gb also in 40Gb but not like on the 60and 80Gb
Posted on Mar 13, 2009
  • Juan Rivera
    Juan Rivera Mar 13, 2009
    the cpu is directly connected to the motherboard and this is why there is so many brocken ps3's but yes you can buy another broken unit and install the motherboard but ATTENTION the bluray drive has a controlboard under if you replace the motherboard you have to replace the bluray drive CONTROLBOARD from the other unit you want to buy why is this well the bluray control board is married to the motherboard so if you just install the motherboard and use your bluray control board your bluray will not play any games you can use your bluray but not your controlboard so remember this any motherboard you buy make sure it comes with the bluray controlboard only the control boar is the one that can't be replaced all other components are standar the longes you buy the same model # thanks and good luck also rate my help
  • Juan Rivera
    Juan Rivera Mar 14, 2009
    well you can get any model and use his own case try to buy one that seller is selling the ps3 because the bluray drive is not working and you can use your bluray but remember that you have to use the same controlboard that came with the playstation you buy the models you can buy are
    ceche01,cecha01,cechg01, this is if you have the older 80Gb because the new 80Gb model is compatible with the following models cechh01,cechk01,cechL01 so look at the serial # on your playstation and next to it is the model # check your model # and see wich models are compatible and any playstation you buy it is better not to take the motherboard out instead take your bluray drive and installed on the one you buy it is easer and fast all you have to do is swap the bluray controlboard located under the bluray drive
So how can it be fixed
Beeps red light hp pc
The blinking should be in a pattern.
Power Green On (S0) Computer on
Power Green 1 blink every 2 seconds (S1) Suspend Mode
Power Green 1 blink every 2 seconds (S3) Suspend to RAM
Power Green Off (S4) Suspend to Disk (if applicable)
Power Clear Off (S5) Computer off
Power Red 1 blink followed by 2-second
pause - Repeat
Power Supply failure
Power Red* 2 blinks 1 second apart CPU thermal shutdown
Power Red* 3 blinks 1 second apart CPU not installed
Power Red* 4 blinks 1 second apart Power supply overload (crow bar)
Power Red* 5 blinks 1 second apart No memory
Power Red* 6 blinks 1 second apart No graphics
Power Red* 7 blinks 1 second apart System board failure (detected prior to video)
Power Red* 8 blinks 1 second apart Invalid ROM
Hard Drive Green Blinking Hard drive activity
*Blinking
Aug 17, 2013 | HP Computers & Internet
The green light on front of my HP computer comes on for a couple seconds and then it goes to red light blinking and beeping try to turn off and back on several times and go right back to blinking red
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jun 04, 2012 | Computers & Internet
I have a 2gd snadisk flash drive, when i insert it in usd port, red light blinks for few seconds and then turns off. flash drive is not deteted by windows.
Have you made any recent changes to your computer hardware - new USB ports/hubs?
There may not be enough power getting to the drive for it to power up correctly.
Hope this helps.
Dec 14, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Playstation 3 (PS3) Console: Whe i touch the red startup button it beeps and tu...
you got a YLOD yellow light of death when you get a yellow light briefly and then the red lights start blinking, you need to reflux the solder on the processors and apply heat to them, here is a link on how to do the repair, if you are not good at doing these kind of work, I would suggest taking it to a pro.
http://www.youtube.com/watch?v=XIm0Qk0CVTE&feature=related
May 17, 2010 | Sony Playstation 3 (PS3) Console
When system is turn on its beeps red and turns off
The blinking red light usually indicates hardware failure. If your Ps3 is still under warranty you should contact sony have them send you a box with free postage and send them your console. They will locate and fix the problem for you.
If your console is not under warranty anymore there are a few things you can try.
First remove the hard drive and try booting up your console. If it says no drive found shut the console down and put the hard drive back into place. If it works after that then the issue was just a drive error which is now corrected. If the light is blinking again then the drive itself is bad.
Second turn the ps3 off for 60 seconds by using the switch on the back. Now hold down the eject button and turn the power switch back on while your still holding the eject button. This can help with overheating issues.
If these simple fixes dont resolve the problem then you will need to contact sony and ask about repair cost's. As fixing it yourself would require experience in working on gaming consoles.
Jan 16, 2010 | Sony Playstation 3 (PS3) Console
Ps3 freezes and turns off
Most of the times, it is a problem of connection with your hard drive or the hard drive itself is broken.You can quickly fix the PS3 by carefully re-setting the drive.
In order to do this, you need to take out the hard drive and then once out, replace inside the PS3 the same way. Usually this is the answer to the Ps3 blinking red light problem. If the red light does not go away by applying thus method, you will have to get a new drive
the next you can follow if this does not work, in case you do not want to buy a new drive
To do it, when PS3 is on standby, hold the power button until you hear 2 beeps.
If it does go onto the video output screen, turn it off again using the
power button and once its back on standby, try holding the power again
until you hear the double beep.
Check if you see this screen and try to do a system restore (note: you will lose your profile data here, since currently you do not have option to take a backup)
else a better option could be to give the ps3 console to Sony for servicing in case you are under warranty period, however they would not repair your device and send it back to you, they send you a refurbished device in replacement to your console
Nov 19, 2009 | Sony Playstation 3 (PS3) Console
Certain DVDs cause my PS3 to shut off and blinking red light
The yellow light is also know as the yellow light of death casued by a hardware failure. It can be casued ny over heating a bluray drive failure, a hard drive failure or even a powersupply failure. You know you have it when you power up the yellow light flashes then you hear some beeps then the red llight flashes. I would suggest returning it if you have that option or getting it fixed somewhere else as a last option.
If you think the **** player is causing the problem remove it and see if it turns on if not you could try another one and see if it works.
Sep 29, 2009 | Sony Playstation 3 (PS3) Console
Blinking red light
General hardware failure. Usually the red light means either bad power supply or bad hard drive.
You can start by pulling the hard drive out and then power on the system.
More than likely it's a power supply / motherboard issue, in which case you'll have to contact Sony for repair.
You can reach them @ 1-800-345-SONY
Feb 20, 2009 | Sony Playstation 3 (PS3) Console
How to fix blinking red light on my ps3?
You should open up the PS3 and use compressed air to dust it off. Take a look at the thermal paste to make sure it isn't dried up! PS3 Flashing Red Light The Ultimate Solution
Jan 20, 2009 | Sony Playstation 3 (PS3) Console
Red light blinking on PS3
If your having this problem I know how to fix it but only for about 30-45 seconds.
Okay this is what you do.
1.If your ps3 is turned on press the red button , it should turn green then yellow ,beep and blink red.
now do this 3 times without turning it off.
2.Turn your ps3 off.
3.Turn it on while holding the eject button.
4.Now your ps3 should stay on ,(like I said for about 30-45 seconds).Also the fan should be on.But then after a while it turns back off.And that's as far as I got.
(It really works if you do it right)
Jun 10, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
816 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
