Question about Ricoh Aficio 2015 Copier
N ricoh 2015 printer i want print the username in each paper while printing
Right click the printer Icon, select "properties", Select "printing preferences", and depending on the driver (there are several), select "add/change custom settings", or maybe "layout". anyway, it is a "watermark" you need to set. You will see the option, to "edit" and you can select the placement and size.
Posted on Mar 13, 2009
  • binesh
    binesh Oct 28, 2014
    am done the same, but when am checked its printing tin test page only
Ricoh 3000dn
1. The cover is open.
• Close the cover.
2. No paper in the tray
• Load paper in the tray.
3. The printer has stopped printing due to a major error.
4. The print cartridge is not installed.
• Install the print cartridge.
5. The life of the print cartridge.
• Replace the print cartridge
Apr 15, 2013 | Ricoh Aficio Sp 3300DN Laser Printer
When printing, instead of a picture, 70 or so pages of numbers and letters come out
Hello probsy,
I know what your problem is. But it's a matter of me properly conveying the information. Bottom line is that you you either have a corrupt print driver or the wrong print driver. A print driver is the program that is loaded on your computer (or your server if you have one) that enables your computer to communicate with/and submit data TO the printer. If the "driver" is corrupt or wrong, then the printer "MAY" still understand that it needs to print something.......but then you get the **** you are talking about. I have seen printers absolutley run the paper out of every tray printing squiggles and numbers and then ask for more paper !! So for example you have a Ricoh printer but you are using the print driver for a Xerox printer. The printer MAY recognize the command to "PRINT", but what it prints will be.....who knows? At this point I have answered your question. I would go further but you will need to remove the printer from your pc and reload and install the CORRECT/CLEAN driver. I am sorry I can't be your IT person. If I gave you further instructions I may do more harm than good. Show this post to anyone you trust with your computer and they will get it, and can be there "near you and live" and you will be fine. Take care. :-) SPINAL
Mar 19, 2011 | Ricoh Aficio 2015 Copier
Hello we have one printer Ricoh 2015 we want to connect to network printing . It is possible
In order to connect it to a network, you need to have the print/scan option installed. If your copier has the print/scan option, you can hook it up with an Ethernet cable and download the print driver from the Ricoh website:
http://ricoh-usa.com/downloads/software.asp?tsn=Ricoh-USA
May 29, 2010 | Ricoh Aficio 2015 Copier
Ricoh ap610n prints crooked. It's about 4 years old. Has been a great work horse but now prints come out crooked.
99% of the time its paper loaded with the side guides of th paper drawer open too wide. -Carl
May 13, 2010 | Ricoh Aficio AP610N Laser Printer
We don't get print from Ricoh after formatting the
try and print a test page from the driver and make sure paper is set corectly
Oct 25, 2009 | Ricoh Aficio 2016 All-In-One Laser Printer
Portrait v. landscape
Check the paper size dial on the paper drawer. Most likely it is incorrectly set - either size, and/or orientation.
Jul 06, 2009 | Ricoh Aficio 2015 Copier
Richo Aficio 2015 I have a richo 2015 machine which has a reading of 1,08,700(number of print out taken)but lately the paper gets folded inside just above the drum. The matter does get printed on the paper...
The pressure roller is inside the fuser section of the copier. If there is a flat spot on the roller, you will get those results. It's better to rebuild the whole fuser unit including the bearings and heat roller. That will stop that jamming from happening.
Jan 26, 2009 | Ricoh Aficio 2015 Copier
Paper coming out from the tray is folded for richo 2015
You do have a fuser problem. There are a set of stripper fingers that are supposed to keep the paper from wrapping around the heat roller. One of them may be damaged and is catching the paper. The Pressure roller can also cause problems if it is torn. You need to have the fuser looked at by a tecnician to determine the problem. Hope this helps.
My printer will only print from bypass tray. Why?
It may be something to do with the paper size settings on printer driver, document print settings or page setup. If for example the computer thinks the paper size is Letter, and the paper in Tray 1/2/3 is A4, it won't print.
Jan 23, 2009 | Ricoh Aficio AP3800C Laser Printer
Problem with printing document footer text on RICOH SP C811DN
Check the paper size settings and orientation of the driver from the Control Panel, and that match to the paper size in the printer's trays.
Good luck and please rate me, thanks.
May 28, 2008 | Ricoh Aficio SP C811DN-DL Printer
Ricoh Aficio 2015 Copier Logo
304 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
