How do i reset the thermostat for a Dimplex OFC2400TIF
We have a new OFC2400TIF heater. We have set a program which worked for a day. Now the heater will not work on either manual or auto. The display lights are all on, the screen indicates that the heater is...
The heater may need to reset itself. Turn the Master ON/OFF Switch to OFF and unplug the heater from the wall outlet. Wait 12 - 15 minutes and plug the heater back in. Turn the Master ON/OFF Switch to ON and set the controls as you normally would. Hopefully, that 12 - 15 minute timeout allowed the heater to reset itself. If this continues to occur, contact Dimplex Technical Service at
888-346-7539.
Hope this helps you to further troubleshoot and solve the problem.
Apr 24, 2011 | Dimplex OFC2000 Oil Filled Radiator Heater
Why does my dimplex model bf8000st fan and heat turn off after 2 or 3 minutes? the flame lights keep working, just no fan or heat.
"Resetting the Temperature Cutoff Switch
This unit is equipped with a thermostat which controls the temperature
of the room by turning the heater on and off. The heater is protected
with a safety device to prevent overheating. Should the heater
overheat, an automatic cut out will turn the heater off and it will not
come back on without being reset. It can be reset by switching the
Main On/Off Switch to off and waiting five (5) minutes before switching
the unit back on."
http://dimplex.com/cms/publications/7208680300r03_EN.pdf
Dec 13, 2010 | Heating & Cooling
Where can I find replacement thermostat for Dimplex DGWH 4031 electric heater?
I have been lucky using Grainger they usually have these items in stock or can locate them quite quickly.
Dec 13, 2010 | Dimplex DGWH4031 Heater
How to install a wall dimplex thermostat to a dimplex fan wall heater /RDH2010tcw/1000/2000W/240
disconnect wire A from the thermostat, and connect it directly to one of the supply wires. Connect B and C to the other for 2000W.
Mar 03, 2010 | Heating & Cooling
Please help me to get the manual. dimplex thermostat, or i need help to stall my thremostat
Dimplex products are typically sold at most Home Depot and professional electrical supply houses. However, they rarely will have all the literature for those products in their stores.
Dimplex once provided an online list for all their heaters and thermostats, but no longer have the product manuals available on their website for customer download. They make both 120V-AC and 240V-AC versions and several different models, so I can't safely provide you with the wiring connections, since each installation is different and depends on the type of thermostat and heater(s) being utilized.
So now that I've given you the bad news, let's move onto the good news!Dimplex now uses an online request form for customers to get manual and literature on all their products. They'll send you the manual for your Dimplex product free, once you submint the request.
Here's the link to the request form for you to fill out and submit, just have your model number handy and you should be all set.
http://www1.dimplex.com/customersupport.aspx
Hope you find this Very Helpful and best regards!
Sep 18, 2009 | Dimplex Heating & Cooling
My dimplex night storage heater has stopped working.
...not too sure of your model but all dimplex heaters to my knowledge have an 'overload' cut out built into the system. Ours is more up to date but still goes now and then, problem is you have to get into the electrics and click the reset button, normally near or on the thermostat it's self, could be a small white plastic button, or a piece metal sticking up that needs pressing down to reset...but please before attempting make sure that you TURN OFF THE ELECTRIC / REMOVE THE FUSE/ WHAT EVER IT TAKES TO CUT ANY CHANCE OF AN ELECTRIC SHOCK!!!...because I can and will get you if it can ;-)... if your not a competent electrician please get hold of one !... good luck.
Feb 01, 2009 | Dimplex Heating & Cooling
Dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Jan 05, 2009 | Fahrenheat Electric Convector Baseboard...
ELECTRIC FIREPLACE ONLY 1+ YEARS OLD HEAT STOPPED WORKING ONLY?
The heater will not work if either the thermostat or blower are not working. (or the heater element is bad). Most of the time with these electric heaters, it's the thermostat.
http://extranet.dimplex.com/files/domain4103//DS5598%20DS5603%20DS5804%20PARTS%20&%20SERVICE%20MANUAL%20REV00.pdf
page 6 has a list of the parts
Feb 02, 2008 | Dimplex DS5598 Mid-Size Heater
Heating & Cooling Logo
209 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
