Question about Panasonic KX-T7630 Corded Phone
My phone will not go to answer mode
I have set up my voice mail but the phone just rings out. about 25sec to time out.
  • Panasonic Master
  • 2,460 Answers
If you have "set up" voice mail, you must have dialed a number to get there, like 165 or 500 or something. You have to tell the phone to forward calls to it. From the intercom, start with *7104 and the extension of the voice mail group plus #. There are 5 levels of Call Forwarding and 3 conditions. The *710x forwards both intercom and outside calls where 2 is ALL 3 is busy 4 is no answer and 5 is BUSY/NA. There's more, but these are the basic. Once you set it, the FWD/DND button acts as a toggle to turn it on and off.
If you're into punishment, try page 192 of the attached pdf. It explains all of the Call Forward and Do Not Disturb options, as well as all of the set operating instructions for a TDA system.
http://public.carl.airpost.net/TDA/200_TDA_OM_06-121.pdf
Carl
Posted on Mar 16, 2009
Why won't the answering machine, when set to 'answer on' not record a message?.It goes to voice mail. Is my machine defective?
Maybe the answering machine is set to pick up at say"5 rings" and the voice mail is set to pickup at "4 rings" . Change the voicemail setting to a higher setting than the answering machine. That may be the problem.
Aug 26, 2014 | Lands Phones
THE ANSWERING SYSTEM WON'T RECORD MESSAGES,ALL MESSAGES GOES INTO POOVIDERS VOICE MAILE, AS IF MY PHONE IS BUSSEY?????? I CHECKED AND RECORD TIME IS NOT SET TO ANNOUNCE ONLY ANS ALL MESSAGES HAVE BEEN...
This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
Mar 30, 2011 | Uniden Cordless Phone
We have a Landmark/Southwestern Bell Telecom DKS 308/616 system and need to know how to access and change the auto attendant greeting.
Call your own number or press and hold #1 button and when the message starts playing press either # or * and follow the directions. It's usually #
Apr 16, 2010 | Cell Phones
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Set number of rings before answer machine pick up
From the main menu select the Voice Mail option in Voice mail select Ring Delay in Ring Delay you can choose the delay time before Answering Machine pick up the phone from 0 to 30 secend.Reza from Iran
Oct 01, 2008 | Siemens Gigaset S455 Cordless Phone
Number of rings
press *94, then press the number of rings you want 1-9. The tone will change and thats it.
Nov 29, 2007 | Siemens Gigaset S455 Cordless Phone
To recieve fax on brother
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
MANUAL
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
FAX ONLY
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
FAX/TEL
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
TAD:ANSWER MACH.
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
only
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
do
not
work in this setting.
Nov 27, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Call will not Transfer to Voice Mail
Typically you want your phone system to ring your phones (say extension 10, 11 and 15) and then if no one answers after so many rings the call is transfered to the port the voice mail is on (let's say it's port 16) The voice mail is set to answer right away but does not "ring" until the call is transfered to it. This way (at 4 rings) if a call comes in on line 1 and you answer after 3 rings but a call comes in on line 2 at the same time, the first ring on line 2 will not make the total = 4 and set off the voice mail. I would guess the port at your voice mail is not set to ring and nothing is set up to transfer calls to your voice mail. Did you set this up yourself? How did you program the phone system?
Aug 21, 2007 | Toshiba Stratagy 4 Lite Voicemail System...
Panasonic KX-T7630 Corded Phone Logo
287 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
