Question about Roper Refrigerators
Roper model number rt18akxkq08 not cold
Things in our freezer wont freeze. now fridge is not very cold either. we are putting our dairy and meats in the freezer with ice bags to keep them cool. can't afford a professional fix right now, can we do this on our own?
mikedurland
  • 481 Answers
SOURCE: bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 28, 2008
SOURCE: refrigerator not that cold and freezer not freezing well
dirty coils underneath the fridge, or the fan in the bottom (to cool the compressor) is not working.
Posted on Aug 07, 2008
  • 531 Answers
SOURCE: Freezer too cold and fridge too warm
check fan cold control or damper control
Posted on Apr 07, 2009
bobicehouse
  • 1524 Answers
SOURCE: I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Posted on Apr 23, 2009
jumptrout51
  • 3361 Answers
SOURCE: Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
Posted on May 28, 2009
Hi ;vejust bought a candy fridge freezer model n0 turned dial to super lights were on constant but now the orange light is flashing what does this mean also some of my meat isnt freezing
What's the model number of your fridge and what type of meats are you putting in and how much at once and what's the temperature of the meat +-, I'll explain everything and give you the best solution.
Regards
Jun 07, 2016 | Candy Refrigerators
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
My side by side kenmore refrigerator, freezer isnt freezing
the fan in the freezer is not working to blow the cold air in the freezer you need a new fan you need a repair man it will cost you $300 good luck i have the same problem don't buy samsung they are useless that why home depot don't sale samsung
Nov 12, 2009 | Samsung RS265LABP Side by Side...
We put things(meats,water,veg.) anything but
check the cold deflector door for proper operation, then check the cold control itself as it may be defective
Nov 01, 2009 | Freezers
Roper Freezer Stopped Freezing
. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
Jul 02, 2009 | Refrigerators
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Fridge has hot spot
Hit it with a big stick!
Mar 24, 2008 | Refrigerators
Temperature adjustment
Generally the freezer temp is the REAL temp of the unit. Fans, dampers and manual control levers let some of that cold freezer air into the refer compartment to cool it. Check your owners manual for damper operations if you have one. If you have a refer temp control all that does is control a damper to let the cold freezer air into the compartment. Also make sure you don't block off any of those vents in the refer or freezer compartment or bad air circulation can occur.
Oct 05, 2006 | Candy CPCA250K Bottom Freezer Refrigerator
Refrigerators Logo
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Randall W
Randall W
Level 1 Expert
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
