Question about Sony VAIO VGN-T350 Notebook
Sony t350p everything seems to work but no display
I changed the lcd to expanded in the bios and now I can't see anything and can't get back to the bios to change it back! I hold the f2 key but nothing on the display. HELP!
Try hooking it up to a monitor. You may be able to see on the external monitor so you can change it back
Posted on Mar 13, 2009
The LCD display screen is blank, back-light remains on. Powering off machine to power back on results in loud, abrasive rattle which seems to come from scanner. Unable to do anything with device.
When this happens the first thing you should do is check the connections to the LCD screen. However if it was working fine before this is most likely not necessary since they have to be connected properly to show anything. After that you would need to replace the LCD or the Logic board. If everything else is working properly then the problem is more than likely the LCD needs to be replaced.
Mar 12, 2014 | Brother MFC 6490CW InkJet Printer
From asus p5kpl-am in bios i changed display mode...now i can't see anything on lcd monitor..but everything works fine like numlock,capslock...on keyboard..mouse..
Try clearing your CMOS. Turn off your computer and press the "clr CMOS" switch on the back I/O of the motherboard, this will reset the bios to factory defaults.
Jun 08, 2013 | Computers & Internet
Vgn-t350p/l it has no video! Anyone help?
may be your camera is not working or its drivers are missing. check that first and then get back to me with details and some bit of its history then i will assist further. thanks for using Fixya.
Apr 15, 2011 | Sony VGN-T350P/L PC Notebook
Vgn t350p no sound
Try the steps below, this should work:
  1. Restart the computer.
  2. Check the system volume to make sure the volume is not muted or too low.
  3. Ensure the volume control dial on the left side of the front panel is increased to an audible level.
  4. Plug in a set of headphones to see if there is sound through the headphones. NOTE: If there is sound through the headphones, the issue is with the speakers.
  5. Ensure the playback device is correctly selected .
  6. Select a sound scheme in Control Panel.
  7. Reinstall the sound drivers.
  8. Check for conflicts in Device Manager.
  9. Remove all added hardware to see if it is conflicting with the sound card.
  10. Reset the BIOS to the default values.
  11. Use the System Restore utility to restore the system back to a point when the sound last worked properly.
Download and install the Audio drivers from the below link:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNT350P&upd_id=1670&os_id=7
Thanks!!!!
Dec 21, 2010 | Sony VGN-T350P: VGN-T350 Pentium M 753...
How to replace a lcd screen on a sony vgn t350p
Hi. Here is a graphical instruction to disassemble your laptop and replace LCD screen. http://laptoprepair.ca/news/11776.html
and here is the service manual in case you need more info.
http://www.notebook-manuals.com/laptop-manuals/service_manual_for_SONY_VaioVGN_T350P_9e406957d4_VGN-T350P-manual-repair.pdf
Good luck.
Jun 12, 2010 | Sony VAIO VGN-T350P/T Notebook
Dell latitude d60..the laptop wont display without external monit
Seems that you have a loose LCD screen cable connection. You will need to disassemble the laptop & make sure the LCD screen cable connection is tight.
Please check this link for more details:
http://www.laptopparts101.com/lcd-screen-video-cable/
Feb 23, 2010 | Dell Latitude D600 Notebook
My sony vaio vgn -T350P , when I turn it on, I
hi, it may be a ram or processor problem you may need to replace one of them
Jan 17, 2010 | Sony VAIO VGN-T350P/T Notebook
LCD DISPLAY SCROLLS Sony Handycam DCR-SR62
Had the same.after stopped showing anything and the rest was working perfectly. Changed the flex wire connecting camcorder and it's like new. got from the repair shop and did it by miself. Good luck
Meggita
Aug 04, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Where is bluetooth module in sony t350p?
Typically, the blue tooth modules are found in the same compartment as your RAM.
Let me know if you can't find it...or look at your owner's manual
Apr 13, 2009 | Sony VAIO VGN-T350P/T Notebook
Sony VAIO VGN-T350 Notebook Logo
128 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
