Question about Frigidaire FRS26R4A Side by Side Refrigerator
When I plug in my refrigerator, it throws my circuit breaker?
I've tried plug it into different outlets around the house, but everytime I do it cause that wall or outlet to lose power. What is wrong with this fridge?
  • studo67 Mar 13, 2009
    If I turn the power off at the breaker, and then plug it in, it will work for maybe up to 3 or 4 minutes at times, but you can hear the relay switch in the back clicking, like it's ready to shut off. Then eventually it does shut the power off. Not at the fridge but the circuit breaker. Before that you can hear the compressor and everything seems to be running fine. I bought it used, plugged it in, in my garage for a week, and it worked fine. Moved it into the house today, and now this?
  • Anonymous May 22, 2009
    My fridge fills up with water in the drip container at the rear of the fridge and after about 12 hrs of use it flicks the breaker switch to the house knocking out the power to the house. I tried other power outlets around the house and it does it on all of them. Someone said it may be an earth problem with the fridge? can anyone solve the problem.
    New Friend:
It trips right and then& there
Posted on Jun 25, 2013
  • 201 Answers
You may have a seized compressor, evaporator or condenser fan - have you tried turning it off first, plugging it in and seeing if that will hold? If you open the doors with the fridge off, will the lights still work? Can you hear the compressor start up when you turn the fridge on, or does it trip right then?
Posted on Mar 13, 2009
If there is no power for either the washer or dryer, is there an internal fuse or reset button
I assume you checked the circuit breaker for this outlet? Both appliances are plugged into the same outlet? I would try unplugging both appliances then attempt to reset the breaker again....throw it completely to the OFF position, wait 10 seconds and throw it to the ON position. At this point we are assuming the breaker is working. It could actually be defective. It could be tested with a meter or test light. If you don't have that try plugging a lamp or another device into the outlet the appliances where plugged into. If it works you know your breaker, wiring, and outlet work. If not you need to troubleshoot that...perhaps a ground fault breaker somewhere in between? If the outlet works with the test lamp, next plug in one appliance at a time to try to determine which pops your breaker.
Feb 06, 2015 | Dryers
Pops Circuit breaker when plugged in
Have you tried plugging it in to a different outlet? You may have too many things using that same circuit. Seems worth a try - hope it helps. We found that our fridge was using the same circuit as our washer and microwave and this kept it from popping the breaker after we used another outlet.
Nov 23, 2013 | Hotpoint HSS25GFP Side by Side...
Cuisinart juice sqeezer throws circuit breaker
Is this a new juicer, have you used this before without the circuit failure?
Most circuits in the house will be are 15 amp breakers. If the appliance has a high amp load then this can cause it to switch the breaker turning on or off.(due to to voltage spikes) I have a waffle iron that does the same thing if my refrigerator cycles while the iron is on.
There are a few things that could cause this. But before anything else I would try the juicer in a different plug that is on a different circuit, like the living room for example. If that works well then I would start looking at you may need to replace the circuit breaker, they do go bad.
Apr 05, 2012 | Cuisinart Juicers
Everytime I plug my Kirkland Signature Refrigerator in , model # ST14CKXK000, the circuit breaker trips. Where should I begin looking to troubleshoot this issue?
the plug socket or circuit your refrigerator is connected maybe over loaded.
try it on a different circuit perhaps use and extension cable to another room to try it.
if you have too may devices such as toaster, dishwasher and fridge on the same power outlet it may be over loaded and trip.
if this is the case then speak to your electrical engineer to see of you need a higher rated trip placed in the room where you will use the refrigerator.
if the refriderator trips on any circuit it maybe faulty and need expert repair.
i hope this was helpful.
Dec 12, 2010 | Refrigerators
My superba refrigerator recently keeps tripping off the power. I tried swithing to a different outlet but it didn't work (same problem). What is causing this?
well usually several plugs are on the same breaker and just because u use a different plug dont mean u r using another breaker try replacing the breaker and see if this cures the problem breakers sometimes get weak and trip when they need replacing but make sure u put in the same size if it still does it then u have something overamping because of being dirty or clogged up around the fridge or behind it or under it make sure its clean all around and try unplugging a couple of things on the outlets and see if it stops tripping
Mar 01, 2010 | KitchenAid Superba Architect KSCS25IN Side...
I have a Whirlpool refrigerator, Model # ET18NKXFW0 1, Serial # EG5130791. It has working fine for 12 yrs. I recently moved it from one location to another in the back of a pickup on its side. As soon as...
Refrigerators should never be plugged into a GFI due to the start up amps that it draws on start up. With other items on the same circuit it is too much of a load. Refrigerator need to be on there own individual circuit to keep this from happening and not a GFI. Hope this helped.
Feb 02, 2010 | Refrigerators
Microwave trips circuit breaker when plugged in repeats when breaker is reset . There is no problem with house electric.
The circuit is probably a 20Amp circuit (see the number stamped on the circuit breaker switch). Most likely, it is the same circuit as the refrigerator, crock pot, window A/C unit, etc....
Also, if you are using an extension cord or a power strip or a surge protector. Those may not have a high enough power rating.
One other possibility (not likely) is that the circuit breaker is a 15Amp and the microwave is 1500 watts.
What else is cut off when the circuit breaker is tripped?
Solution is to use a different outlet for the microwave, or turn off any other applicance in the same circuit (except the refrigerator, of course).
Hope this helps!
Sep 16, 2009 | Microwave Ovens
Clothes Dryer tripping house circuit breaker
If it is breaking the main circuit of the house there is something wrong. It should throw the breaker to the dryer only. It sounds like you are having a problem with a short between the main breaker and sub panel in the house. Is there any way you can move the breaker in the panel to a different place on the same panel to see if it is that circuit only. If not check the outlet and the plug on the dryer and make sure the wiring is connected correctly.
Aug 03, 2009 | Dryers
Everytime I plug in the power cord, it trips the breaker.
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
May 13, 2009 | GE GTS22KBP Top Freezer Refrigerator
My washer keeps kicking out the electrical outlet everytime it goes beyond the filling stage. I hit reset and it only goes for a second. Help!!!!!
try using a different outlet in your house, with a decent quality extension cord. it might be a problem with the outlet or circuit breaker reset switch.
if it still does it on another outlet in the house then it might be a bad motor.
Jun 28, 2008 | Washing Machines
Frigidaire FRS26R4A Side by Side Refrigerator Logo
737 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
