Question about LG Televison & Video
CONVERGENCE IS NOT WORKING FOR HALF OF THE SCREEN
Trying to adjust the convergence , is not doing anything for right half the screen. Left hand side is great, right hand has three colors shadows...
  • 76 Answers
Replace STKS on convergence board
Posted on Mar 13, 2009
Convergence on lower half of the screen is off, green arc appears
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Apr 05, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Color convergence drops on left side
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 13, 2009 | JVC AV-48WP30 48" Rear Projection...
Convergence problems at 1080i resolution
With TV off ON Front Panel board Press and hold vol-&ch- at same time untill set comes back on you should now be in Service Menu ,try adjusting convergence then.
Feb 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52930BL Setting Green Convergence
check conector j19105 to be seated properly.
if this dosent fix it
look in the uper right hand side of light box in the back of the set
you will see the convergence Power supply, remove and replace it.
save your self time and just replace the board.
regards,
daniel.
Jan 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Looks 3d
Do not open anything until you. Go to menu on your remote find convergence and press the volume button to the right go to manual and press right again. you should see a bunch of rectangles, now you should also see a set of red cross heirs press the #2 to move cross heirs up and eight to move down numbers 4 and 6 will move left and right and 5 will place the cross heirs back to the center once you have chosen the selected section to adjust line up the magenta with the other colors using the channel and volume buttons these move the lines up down left to right adjust all lines until they are white. i do not know how to switch from magenta to green or blue but this should get you started on the right track with out having to replace anything. good luck! if you figure out how to switch from maqgent to green or blue please post it so that I may adjust mine as well tahnks
Dec 26, 2008 | JVC AV-65WP74 Rear Projection Television
Hitachi 61udx10b picture problem
Replace both of your STKs these are your convergence ICs STK392-110- use STK392-180s .
Dec 14, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Convergence adjustment
HELLO . it sound like you need to replace the convergence board or just the IC'S ON THE BOARD. IT WOULD BE CHEPER THAN THE HOLE BOARD. "GOOD LUCK"
Jul 27, 2008 | Akai PTH5498 54" Rear Projection...
Convergence off on top and the 2 side right and left
You need to check all the convergence resistors out of circuit 1 or 2 are most likely open and need to be replaced. You can get the service manual and free tech support at this link .
http://servicemanuals.vstore.ca/
Apr 16, 2008 | Panasonic PT-47WX49 47" Rear Projection...
I am having a shadow/double image problem only on the left side of the screen
Yes its called the Convergence ICs there are two of them they are mounted on a huge heat sink with the part number stamped on them they will have a STK number such as STK392-110. they have 16 pins on them there are two cost around 10 dollars each, you will also need some Heat sink Compound. Just look for the largest heat sink in your tv and thats where they will be. However if you can move both red and blue colors up,down right and left its probaly not your ICs. Do the colors move in all directions? If so you probaly just need to do a multipoint convergence adjustment.via of the service menu. Hope this helps. let me know if you need anything further.
Jan 11, 2008 | Sony KP-41T65 41" Rear Projection...
Televison & Video Logo
67 people viewed this question
