Replacing Canon Laser Class 830i 810 1023N Fuser Unit
ctf1800
  • 4402 Answers
SOURCE: Problems with Canon imageCLASS D680 Laser Printer?
you have to move whole scanner it to the left Lift the platen unit lever (1) and slide the platen unit (2) until the strange_left_arrow.gif mark appears.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=8152
then faq >>> select the install tuner
Posted on Dec 20, 2007
SOURCE: nec 860 laser printer fuser unit
remove cartridge and leave top door open, then remove two screws in back ; open front sheet panel to find two screws to remove then remove outer case carefully AND PLACE ON LEFT SIDE BECAUSE THERE'S A RIBBON WIRE ATTACHED.
there are 4 screws holding the fuser unit in place, remove AND LIFT OUT BY ROLLING TOWARD YOU to reveal 2 screws to access the red roller assembly!
In my case there was a very tightly wound piece of paper stuck in there not visable without removing the screws on the fuser unit!
Posted on Dec 18, 2008
  • 990 Answers
SOURCE: I have a canon laser class 9500, i am unable take fuser
Hello sir ; The user manual you get it online, instrction to remove the fusing unit quit simple, open back door ( sometime require to remove back panel ) you may findout two blue knob release it and may be aalso need to removed two screw pull out this unit half way the unpug the connecter , whole unit coming out.
Posted on Aug 18, 2009
don_farr
  • 1018 Answers
SOURCE: how to take fuser unit and heat roll out of canon
Unless you are an authorized service technician I strongly urge you not to do this task.
The least bit of ESD can destroy your motherboard.
If you are simply trying to avoid the repair costs, check into purchasing a new printer. It may cost less to replace the printer than it does to repair it.
Don
Posted on Dec 03, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: how to replace fuser unit in brother Laser
Sorry to read about your problem, I hope this helps you out.
you can replace, toner,drum,belt and waste..
but the factory/service center has to replace the fuser unit
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Posted on Dec 25, 2010
How to program TX report on a canon laser class 830i
You can find instruction on how to configure Transmission Reports on page 364 of the use guide. (see below)
http://downloads.canon.com/cpr/pdf/Manuals/lc_800_series_basic_operation_guide.pdf
Hope that helps.
Dec 19, 2014 | Canon Office Equipment & Supplies
How do I print the configuration page from the canon Laser class 830i fax machine
I am using a mac, and not the same brand printer, but I go to my system preferences, pick my printer, go to the top and pick "Options and Supplies" a new screen should open. There should be a "test" icon, as well as options for allignment, cleaning heads,etc..
Nov 19, 2014 | Canon Office Equipment & Supplies
I am getting a feeder glass dirty message. I have cleaned glass and rollers. Do I need to reset
look the cartridge is there some defect.and then do the reset.Its not anything big failure just the printer sometimes mix the right info.
Jun 05, 2014 | Canon Laser Class 830i Plain Paper Fax
Our RX report for our Canon 830i fax machine lists a transaction failed (NG) with error code #0106
This error usually means you have a phone line problem.
You need to try to increase your transmission level, or check the line equalization. It could also be a problem with an echo on the phone line.
Dec 16, 2009 | Canon Laser Class 830i Plain Paper Fax
Photo copys are intermittently coming out black without copier settings being changed
you need to watch the exposure lamp under the glass . see if it goes out during a copy run. if so you may have a bad lamp, wires, invertor or pcb. if it does not go out you may need a drum, chagre replacemnet or developer. you may need a tech to look at it.
Oct 27, 2009 | Canon Laser Class 830i Plain Paper Fax
Aug 18, 2009 | Canon Office Equipment & Supplies
Check Printer error
1)need to replace the fuser unit assy.
2)this is useful link http://www.precisionroller.com/canon-laser-class-7000/products.html
3)Pls feedback me .Thanks
Aug 11, 2009 | Canon LaserClass 7000 Plain Paper Fax
Canon Laser Class 730i Printer/Fax -- Error Code/Alarm E004. How do I clear it?
E004 Fixing Unit Failure.
I would recomend calling repair Tech to resolve this issue....unless you know how to access service mode and perform a Printer Reset operation. Could be complete Fuser Unit failure.
Jun 02, 2009 | Canon 730i Laser Printer
210 people viewed this question
k24674
jasbo
jasbo
