M/c not working properly on installing another new 128 mb sdram
I have got a PIII m/c of 815e motherboard, Celeron 1.1 GHz processor and 128 MB SDRAM. The motherboard contains 3 slots for RAM. I have bought another 128 MB SDRAM and whenever i installed the RAM the m/c isn't working properly. Please help me to solve the problem.
  • 530 Answers
Hi im josh in cebu phils.may i help you?
friend if that happen. There are some possible reason why it wont work properly.
1. If the memory bank is damage or covered with dust and dirt.
2. You have use not the same memory frequecy or memory brand.
3. Your mainboard couldnot support the capacity memory loaded.
Solutions: Please check this to solve the solutions.
1. Try to clean the memory bank or swap the other memory for testing
2.Try using the same brand and the same frequency of memory ex. if pc 400, pc 333, 133 or etc.they should be the same
3. try checking the mainboard support. if it accomodates your memory.
thats all friend good luck hope i helped you.
Posted on Mar 13, 2009
Need apower supply and hard drive for my compaq presario 1103WM. how old is this unit
It must be up to 8 years old ish as it has XP installed.
17-inch flat screen CRT monitor NEW* Intel Celeron D Processor 3252.53 GHz, 533 MHz FSB, 256 KB L2 cache 256 MB DDR SDRAM CD-RW (48x32x48) 40 GB hard drive 9-in-1 memory card reader 10/100Base-T networking interfaceIntegrated graphics with 64 MB shared video memory *The new Celeron D processors are more efficient than the old Celeron processors. The New 325 D benchmarks faster than the old Celeron 2.7 GHz processor.
Almost any IDE hard drive will work, up to 540Gb and any reasonable power supply should be OK. Check ebay and also google for a power supply.
Hope that helps.
Feb 16, 2011 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Upgrade PCChips M925
According to PCChips, the maximum CPU & memory supported for all three is the Intel P4 Northwood (HT) 3.06 GHz 512K,533FSB,Socket 478 and 2GB (2 x 1GB) DDR 266.
Be sure you have the latest BIOS version for your motherbaord.
M925ALU (V7.3) must have BIOS : 030703s
M925G (V8.0) and M925G (V9.1b) must have BIOS : 050510s
Hope this helps you out.
Jan 09, 2010 | PC Chips (M925G) Motherboard
Can work Memory SDRam 128MB PC100 with SDRam 512 MB PC133
It wont work, it will hang ur system. Ur motherboard supports but using Mutli-frequencies RAM is not possible, either u use SDRAM 512 BM PC133 or ur 64/128 PC100 RAM, You cant use all together.
Apr 20, 2009 | QDI Group QDI Advance 10T Motherboard
Need to know bus speed of Trigem Cognac MB used in HP Pavilion 6730. Is it 100 MHz or 66 MHz?
it's 100 other info as follows:
Component Attributes RAM (standard) 64 MB SDRAM standard Maximum 256 MB (2 x 128 MB DIMM) Speed 100 MHz synchronous Sockets Two 168-pin DIMMs Size 16, 32, 64, and 128 MB DIMMs Type Supported SDRAM, 100 MHz, Intel PC SDRAM unbuffered DIMM specification, revision 1.0 compliant
Cache Level Quantity Level 1 (Primary) 32 KB (on processor) Level 2 128 KB (on processor) Upgrade Sockets None
Dec 09, 2008 | Computers & Internet
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
I NEED RAM
Hi zouganeli,
You can install one, two or three modules. Each memory module can hold a maximum capacity of 128 MB of standard SDRAM chips, or 256 MB of registered SDRAM chips so maximum memory capacity is 384 MB of standard SDRAM memory or 768 MB registered SDRAM memory.
Hope that helps
Take care,
Michael
Nov 14, 2008 | Computers & Internet
Regarding upgradation of SDRAM
hi dear
there is always speed mismatch problem occur when we use low processor & high ram
so try to use 256 ram
also try to use 1 slot of 256 ram & 2 slots of 128 ram diffrently
& compare the speed
hope it will help to u
Jul 08, 2008 | ASUS SiS Chipset CUSI-FX Motherboard
I have a P3 at 500MHz and was wondering with this Motherboard,
The motherboard has three, dual in-line memory module (DIMM) sockets. Minimum memory size is 16 MB; maximum memory size is 768 MB. The largest DIMM supported at this time is 256 MB using unbuffered 128 Mbit technology parts. The BIOS automatically detects memory type, size, and speed.
The motherboard supports the following memory features:
  • 168-pin DIMMs with gold-plated contacts
  • 66 or 100 MHz SDRAM
  • Non-ECC (64-bit) and ECC (72-bit) memory
  • 3.3 V memory only
  • Unbuffered Single- or double-sided DIMMs in the following sizes:
DIMM Size Non-ECC Configuration ECC Configuration 16 MB 2M x 64 2M x 72 32 MB 4M x 64 4M x 72 64 MB 8M x 64 8M x 72 128 MB 16M x 64 16M x 72 256MB 32M x 64 32M x 72
Synchronous DRAM (SDRAM) can be installed in one, two, or three sockets. EDO DIMMs are not supported. Memory size and speed can vary between sockets.
Note: Intel® Pentium® II processors with 100 MHz front-side bus should be paired only with 100 MHz SDRAM. Processors with 66 MHz front-side bus can be paired with either 66 MHz or 100 MHz SDRAM.
All memory components and DIMMs used with the Intel® SE440BX-2 motherboard should comply with the PC SDRAM specifications. These include: the PC SDRAM Specification (memory component specific), the PC Unbuffered DIMM Specification, and the PC Serial Presence Detect Specification.
Note: It is recommended that SPD memory DIMMs be used with the SE440BX-2 motherboard. However, the BIOS will allow the use of non-SPD DIMM memory.
So the max you can go is 3 x 256 MB.
Thanks and please take a moment to rate fixya.
Jul 06, 2008 | Intel Desktop Board SE440BX-2 Motherboard
UPGRADE
U have to find the motherbord's manual !!!! U will find there all u need. But most probably u won;t be able to put those processors (the speed diferences are too big, even if they are of the same slot type)
Jan 14, 2008 | Soltek SL-65KV2-T Motherboard
Intel 815E Mother Board
Do you mean the Power Supply?
These are relatively cheap and easy to replace.
Dec 03, 2007 | Intel Motherboard
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
