Question about Sun Java Programming Language (cdj-275)
Validating in jsp
How can i validate values from database(ms-acess). Ex: To check login form
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
JavaScript Form Validation JavaScript can be used to validate input data in HTML forms before sending off the content to a server.
Form data that typically are checked by a JavaScript could be:
  • has the user left required fields empty?
  • has the user entered a valid e-mail address?
  • has the user entered a valid date?
  • has the user entered text in a numeric field?
Required Fields The function below checks if a required field has been left empty. If the required field is blank, an alert box alerts a message and the function returns false. If a value is entered, the function returns true (means that data is OK):
function validate_required(field,alerttxt)
with (field)
if (value==null||value=="")
alert(alerttxt);return false;
else
return true;
} The entire script, with the HTML form could look something like this:
<html>
<head>
<script type="text/javascript">
with (field)
{alert(alerttxt);return false;}
else {return true}
} function validate_form(thisform)
with (thisform)
if (validate_required(email,"Email must be filled out!")==false)
{email.focus();return false;}
</script>
</head> <body>
<form action="submitpage.htm"
onsubmit="return validate_form(this)"
method="post">
Email: <input type="text" name="email" size="30">
<input type="submit" value="Submit">
</form>
</body> </html>
E-mail Validation The function below checks if the content has the general syntax of an email.
This means that the input data must contain at least an @ sign and a dot (.). Also, the @ must not be the first character of the email address, and the last dot must at least be one character after the @ sign:
function validate_email(field,alerttxt)
with (field)
apos=value.indexOf("@");
dotpos=value.lastIndexOf(".");
if (apos<1||dotpos-apos<2)
else {return true;}
<html>
<head>
with (field)
else {return true;}
with (thisform)
if (validate_email(email,"Not a valid e-mail address!")==false)
</script>
</head> <body>
onsubmit="return validate_form(this);"
method="post">
</form>
</body> </html>
P.S.: If this information was helpful, please rate this solution.
Posted on Mar 13, 2009
Halifax login online
Some internet banking websites only let you log in normally on the computer that you originally set up the account with. There will be a different route on the website when logging in using a different computer. If this IS the same one, it may be that you need to check your email for an email validating link. try also using different browsers.
Good Luck
Feb 03, 2014 | Computers & Internet
My laptop keeps saying validating identity and it wont go on line troubleshooting says things seemed to be ok but its trying to say a cable is unplugged or my local area connection is firewalled and i
You didn't provide your router make, model, so this is a general procedure. Wired or Wireless connection? You didn't say? Shut down the computer, unplug , remove battery. Unplug the wired/wireless device,. Unplug the ISP modem, remove battery, if applicable. Verify ALL cables and connections. Replace battery in the ISP modem, plug in, wait for selftest. Plug in the wired/wireless device, wait for selftest, If wireless, try a Ethernet cable to verify your router is connecting to the ISP modem. I would suspect a Laptop issue.
Jan 04, 2013 | Computers & Internet
I have a cisco by linksys and i have validating indentity went a enable on seting and my labtop came up but i still have validating identity when i start up lab top status connection will this go away if...
you will have an option called wifi protected setup(wps)...You need to disable this particular feature...
This feature when enabled gives the error message like "validating identity"...
or by the other way instead of disabling the wps, you can add the network manually by entering the network information like ssid, password and security type...
This will also help....
This is a 100% proven solution for validating identity....
Because I directly work for Belkin....
Dec 11, 2010 | Belkin (F5D5231-4) Router
My dell Laditude D610 keeps saying validating identity when i try to connect to my new network.
I had an idea for your "validating identity problem."
Can you get to a dialog box that shows the "Properties" for your wireless networks. What we are looking for is specific for the connection to your wireless network.
We want to get to a page that asks if you want to "Enable IEEE 802.1x authentication for this network." If you disable this (no check mark), does the "validating identity" problem go away?
Let me know if you need more specific help.
Jul 05, 2010 | NetGear Computers & Internet
Dell Inspiron 8600 validating problems
please check the settings of your connection why it need validating the identity. maybe there's a conflict on the configuration.
May 10, 2010 | Computers & Internet
I want to learn that how can i connect my HTML page with my DATABASE created in MS ACCESS so that i can fill my table in HTML page directly-
1. You can use Pages option in MS Access. The page in MS Access is the web page in MS Access which allows you to access database in MS Access database.
2. You can use MS Office Front Page application and use the Form builder and connect your database in that.
3. You can also use Google Apps Business Solution for this however the database will not remain in MS Access but will remain in Docs online.
4. You can use .net application developer for this as well but needs expertise in that.
Mar 09, 2010 | Microsoft Office Standard for PC
Validation code using single loop for multiple fields in javascript
As example, use it:
JavaScript Form ValidationJavaScript can be used to validate input data in HTML forms before sending off the content to a server.
Required FieldsThe function below checks if a required field has been left empty. If the required field is blank, an alert box alerts a message and the function returns false. If a value is entered, the function returns true (means that data is OK):
with (field)
else
return true;
}The entire script, with the HTML form could look something like this:
<html>
<head>
with (field)
else {return true}
}function validate_form(thisform)
with (thisform)
</script>
</head><body>
method="post">
</form>
</body></html>
E-mail ValidationThe function below checks if the content has the general syntax of an email.
with (field)
else {return true;}
<html>
<head>
with (field)
else {return true;}
with (thisform)
</script>
</head><body>
method="post">
</form>
</body></html>
Mar 04, 2009 | Computers & Internet
Connecting html form to Ms-access data base
If, as I suspect, this is for a web form, then it effectively can't be done on a "proper" web server. This is because you cannot install MS Office on an MS server OS (e.g. Server 2003). You need to use MS SQL Server or MySQL instead. If this is for very limited use (i.e. only a few clients at a time), you can use XP running IIS but this is really not a good idea. The sedurity implications don't bear thinking about :) Linking a web page to Access can probably be done using ASP (never even thought of trying it - anyone else here know for sure?) If you are using a Linux web server then it's totally out of the question. Use Webmin or PHPMySQL to set up a MySQL database & PHP to code the linkage between the page and the DB. There are plenty of tools out there that will automate this for you, some of them Open Source and therefore free to acquire.
Sep 26, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
671 people viewed this question
Top Sun Computers & Internet Experts
Cosma Papouis
Cosma Papouis
Robin Hill
Robin Hill
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
