Paper stops half way shuts off brother lazer
Paper stops half way shuts off brother lazer printer
  • autgal Mar 13, 2009
    very good answer can be rear fuser sensor thank you very nush
  • 62 Answers
It could be several issues, such as paper tray needs to be set a little loose (not exactly on paper setting) or could be a rear fuser sensor is malfunctioning. That task would be sfor a tech and they could inspect and repair pretty easy unless the fuser is old and warn out. Hope this helped!
Posted on Mar 13, 2009
Why is my photocopier only printing half a page
check your paper size for your original or the cassette paper size they can both cause the scanner to only scan part way. it thinks the paper size is different than what you are using.
Aug 18, 2014 | Sharp AL Office Equipment & Supplies
Why is my photocopier only printing half a page?
Sounds like one of the sensors in the doc feeder that detects the size of the paper has gone bad.
Also, make sure you always close the document feeder when making copies. Sometimes it helps to put a blank sheet of paper over the back of a small object if you're copying something small.
Copier Collin Houston TX Copier and Imaging Expert
Aug 18, 2014 | Sharp Office Equipment & Supplies
When press print, the status light flashing orange. It print for a while then the paper light flash yellow, then it stop. The printer print up to half a page the it stop. Check printer and turn printer...
the flashing amber status light is normal indicating data going from computer to printer.the flashing paper light indicates a paper jam or out of paper. A sensor maybe not working properly or sticking. If your model number ends in a D check
Jul 16, 2014 | Brother HL 5140 Laser Printer
I have a brother printer HL2040 lazer printer and the paper button keeps on flashing red. There is no paper jam any where and there is paper in the paper tray. What can I do?
check that the front and back cover are completely closed.
check for a paper jam in the back as well.
if you still dont see anything, you probably have a small piece of paper jammed in the sensor area somewhere in the printer,
Aug 25, 2010 | Brother HL-2040 Laser Printer
Why does my hp printer only print half of my email message
please i did not know if ur printer is lazzer or deskjet but try and check ur page set up or ur printer paper set up in printer folder, if is a lazer printer remove the cartridge and clean the transfer charging unit if the problem persist change the lazer toner cartridge
Aug 24, 2010 | Office Equipment & Supplies
Paper Jam whilst doing a multi page scan
The rollers that pull the paper through could need a cleaning. With general usage these parts do get worn down. By having your printer cleaned by certified technician it would resolve this problem.
May 28, 2010 | Brother MFC-260C All-In-One InkJet Printer
Hi,I have a brother printer DCP7200 Lazer I refill...
there is no special toner, check the connector that connect the magnetic roller to the charger and try another bottle of toner if the problem persist change the cartridge
May 19, 2010 | Brother DCP-7020 All-In-One Laser Printer
Paper jam brother mfc8840
It is problem your copier drum unite replace it & solve problem
May 21, 2009 | Brother MFC-8840D All-In-One Laser Printer
Brother hl-2070n; Paper jams half way through drum unit.
Usually there is a sensor right before the paper enters the fuser. If the paper sensor is bad the machine will stop feeding and output the error paper jam. This is probably the cuase if the paper stops in the same position all the time.
Nov 19, 2008 | Brother HL-2070N Laser Printer
jasbo
jasbo
