Question about FrancisFrancis! X5 Espresso Machine
Francis francis x5-espresso splatters all over
When I try to make espresso with my francis francis x5, the espresso does not come out in a slow and steady stream. Instead, the espresso splatters all over and the machine starts to make these hissing sounds. Please help!! Thanks so much.
  • Anonymous Apr 08, 2009
    I have the same problem even when I am using the illy pods. It's as though the machine is getting so hot that it is brewing steam instead of hot water.
I have a Cuisinart EM-100 that I purchased 6 months ago. Recently, about the last couple weeks, when I pull the espresso, it is coming out very, very slow. Pretty much only a drip, so the coffee is getting burned and it makes a rumble noise. I have cleaned the unit with vinegar/water through both the coffee part and the steam wand. Although, that wand is not causing any problems. I have checked the rubber gasket, and it is fine. When I use the espresso part but don't put any coffee in it, it is dripping steady (although one side drips perfect, the other side sort of sputters). I have also cleaned the portafilters. Any suggestions as to what may be causing the coffee not to pull through?
Posted on Jun 26, 2012
    Problem Solver:
  • 10 Answers
1) The coffee you are using may not be ground finely enough to provide a proper extraction time, resulting in water rushing through the ground coffee much too quickly. Think of it like water running through a handful of pebbles as opposed to a handful of sand. You want "sandier" coffee.
2) Your gasket (the rubber part that seals the portafilter to the group head) may be worn/damaged and is leaking water when you are brewing. Attempt to contact FF! or Saeco to secure a replacement gasket. When you are not using the machine, don't tighten the portafilter all the way in to the head, either leave it completely disengaged or only loosely attached. This saves wear on the gasket.
3) Your brew water may be too hot. Purge your boiler right before brewing by running water into a bowl without the portafilter locked in. After a few seconds the superheated water will be run out and you're ready to brew.
Posted on Apr 01, 2009
Is there an illistration available for the various parts in the Francis Francis x5 particularly the heating element?
Hi there, yes i have the PDF exploded diagram of the Francis Francis X5 model of both outer and inner parts. If you send me an e-mail to coffeeservice@live.com and just say in the email that this is what you need and i can email you back with the PDF attached. Any problems please get in touch.
All the best
David
The Domestic Coffee Service
Jun 16, 2009 | FrancisFrancis! X5 Espresso Machine
Francis Francis fuse defective?
Hi
If you have power its not likely the fuse. It could be the heating element or the board.
Boiler gets too hot
Hi Contact Francis/Francis because you need power board.
Apr 12, 2009 | FrancisFrancis! X5 Espresso Machine
FrancisFrancis! X5 Espresso Machine Logo
810 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
