Question about Bosch Dishwashers
Bosch she45mo2uc HOW TO REMOVE CONTROL PANEL COVER?
2 Suggested Answers
SOURCE: Replace Control panel cover on dishlex dishwasher 500E
If your 500E is the same as my 500E then the controls are electronic touch buttons. The are part of a self adhesive strip and stuck to the front of the door. No screws involved. Only the LED lights are mounted on a circuit board with screws on the back of the plastic front panel. ?????
Posted on Jun 07, 2009
My Bosch 300 does not have a little round plate nor a square plate below my drum opening on the exterior of the washer like many posters have indicated. How do I get access to my drain filter?
These Bosch machines are similar to some Kenmore washers (he4t). You can remove the lower front cover. Behind this cover, you will find a white plastic housing that has a s tree off cover. Be ready with a catch pan! Remove this cover and water and collected debris will come pouring out in a large gush. If this becomes clogged, the washer may send error codes and fail to spin and drain properly. You can fish out additional debris with your fingers before replacing the cap and the lower front cover.
Nov 10, 2016 | Bosch Washing Machines
Bosch SHE55M16UC/64 Dishwasher replacing control panel fascia or cover. How to remove chrome handle cover from old part and reinstall it?
You will have to take the door apart. Be very careful not to break any clips. The screws for the handle are on the inside of the door.
Mar 13, 2014 | Bosch Dishwashers
My Bosch dishwasher (shu30) sticks in the rinse
Not sure why you would want to remove the panel? When this problem occurs First try putting in diagnostic mode and going thru the cycles. Anyway the tech sheet will be located behind the panel this will walk you thru putting in diagnostic mode.
There is a series of 4 screws that hold the top portion on. These are located on the inside of the door and require a torx bit to remove. Remove the screws and then lift up and out on the cover to remove. There is not a lot of wire there so I usuall remove the lower panel also,same procedure just remove the screws and slide down slightly to remove this panel. You will have to plastic pcs that slip over the hinges at the bottom and these may fall off when removing the panel. To reassemble put lower panel on first and leave the top two screws out until the control portion is installed then put in the rest of the screws.
Mar 24, 2010 | Bosch 23 in. SHU303 Built-in Dishwasher
Bosch 500 series dryer stuck on pause mode
things I would try:
remove the power from the dryer and let sit for a while. Plug back in when you feel it is time.
If that does not reset, I would take the cover of the board to see if the button is not stuck. (remove the top 1st, the the cover of the control board will come out)
Jun 05, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Bosch dishwasher = machine on but no water, so the lower basin has water in it and because of it the FLOOD CONTROL SWITCH IS ON, so how do I drain the rest of the water so the FLOOD CONTROL SWITCH goes...
If you can see the water use a shop vac if not you will have to pull the unit out and remove the left side panel after removeing the water you will need to find the leak that caused the bottom to fill with water
Mar 29, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Timer switch has broken on bosch wvf 2401 how to replace?
First remove screws X2 from back of the machine that hold the top cover on. Once removed the whole top slides backwards and can then be lifted off. This gives you access to the plastic clips that hold the timer face panel on. The main control dial must first be pulled off through the front cover, then remove the front cover by unclipping it (a pain and a fiddle!) The dial on the timer can then be pulled off revealing the two mounting screws that hold the timer in!!
Feb 02, 2009 | Bosch Classixx WVF 2402 Front Load...
Bosch shu9905
Check the drain pump. First, manually initiate drain by pressing the second and fourth buttons on the keypad at the same time. If it pumps out, disregard the rest. If it doesn't at least hum, check for power at the motor.
Remove lower rack, lower spray arm, and screens in bottom, remove all water inside. Check for debris under pump cover in bottom of sump. The drain pump suction is through the hole on the left.
Behind the toe panel on the left is the drain motor, If no debris was found inside, the drain pump may have failed. Remove outer door panel (you may need to remove the two screws on the sides of the control panel.) Remove the metal panel across the top of the motor area , disconnect hose in front of pump, disconnect wires to pump, press tab at top of pump and rotate clockwise to remove pump. The impeller could be loose on the motor shaft, or the motor windings failed.
Mar 10, 2008 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Bosch Dishwasher SGS43E02 Exxcel Control/Display Facia Panel
The panel is replaceable by removing the #20 torx screws inside the door. Once removed the metal outer door cover will slide down and the plastic top housing less switch panel can be unclipped from two locking tabs on either side. You can order via BOSCH service center, check to see if it is warrantied before removing
Feb 06, 2008 | Bosch 24 in. SGS43E02 Exxcel Built-In...
Timer runs down to 1 min and just hums water covers the bottom
need more info on problem does it start washing then run down and hum or what
Dec 26, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Access controls
screw driver hex#15
Oct 27, 2007 | Bosch SHU9950 Dishwasher
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
