Question about Waring Pro WC1000 Coffee Maker
I have a waring pro 12 cup coffee maker but no manuel.
I want to know how much water is needed to start the brewing process. There are two carafes and two hot plates. How do I start?
  • Roberta Smith
    Roberta Smith May 11, 2010
    how many feeds are there when you make coffee ? as in trays where you add the coffee and it comes out brewed ?
    Sergeant:
    Champion:
  • 234 Answers
Most of them will make any amount of water you put in.But I would remen 2 to 4 cups.
Posted on Mar 13, 2009
Slow dripping and ground cup is extremely hot
Have you tried cleaning your coffee maker? If not just fill half of the carafe with white vinegar and let it brew. Keep basket in during cleaning but no filter needed. After running the vinegar through the brew cycle, fill the carafe with plain water and run fresh water through about 3 to 4 times. I do this every 4 to 6 months. I have a light on my coffee maker that lets me know when I need to clean it. I hope this helps.
Feb 27, 2015 | Mr. Coffee 12-Cup Programmable Coffeemaker
How to clean the coffee maker?
The easiest way is to run a cup of white vinegar in half a carafe of water through the brew cycle, followed by at least one carafe of clean water.
Jul 16, 2014 | Mr. Coffee 12-Cup Programmable Coffeemaker
My Mr Coffee beeps three times when I push the brew button and will not brew
If the carafe, the filter basket, or the water reservoir are not all properly seated, the unit will beep 3 times to let you know it cannot brew until everything is in place.
This happens to me sometimes when I push the button right as I'm putting the carafe in place. I just need to wait a few seconds.
Oct 03, 2013 | Mr. Coffee 072179228578 12 Cup Coffee...
Overflow of carafe
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual and/or do an Internet search for tips.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir, and the lines on the side of the indicator window as your guide. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Therefore, a 12-cup machine may make as few as nine 8 oz mugs of coffee.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve feature, if applicable, isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. It is vitally important to clean your machine with vinegar or as instructed by your user manual at least three times per year and monthly if under heavy use in a hard-water area. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Dec 03, 2009 | Waring Pro WC1000 Coffee Maker
If I put 6 cups of water in when it is done there is left only 4
The good news is there is nothing wrong with your coffee maker!
With any coffee maker that heats up the water, you're going to lose some of that water to the heating process (steam, etc.). You also don't get every bit of water out of the machine.
So that's why you need to look at the water reservoir level indications instead of using the graduations marked on the glass coffee carafe.
Typically, once you've figured out how you coffee maker works, I'd just "add" 2 more cups of water in the glass coffee carafe to get the amount of cups you want to brew.
I know my coffee maker is pretty close to exactly 2 cups shy of whatever I put in the glass carafe that I pour into my coffee maker. That's when I noticed the markings inside the water reservoir that didn't match the coffee pot. It was always 2 cups shy, so I just put 8 cups of water (using the carafe) to get 6 cups in the morning.
So I suggest you just you make these small adjustments to your water measuring and you'll get the right amount of brewed coffee out of your machine!
Hope you find this Very Helpful and best regards!
Sep 23, 2009 | Cuisinart DCC-1200 Coffee Maker
Not brewing. Add water and coffee, switch to the brew selection and the water/coffee does not flow. The machine heat ups and starts processing noise.
Make sure the lid is on the carafe.
Make sure you are not using a paper filter and a gold tone filter at the same time.
Make sure the carafe lid is down all the way and that the center knob of the carafe lid is making contact with the spring at the bottom of the filter basket.
If the above conditions have been met, then decalcify your coffeemaker by running 1/3 carafe worth of vinegar and 2/3 carafe worth of water through your coffeemaker - use the self-clean button to do this - will take about 35 minutes.
Aug 30, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
We have a waring pro wc1000 coffee maker and it just started taking forever to brew a pot of coffee. How can we fix it?
If you've never done a decalcification, do one. A decalcification basically means that you're running vinegar and water through your coffee maker to get rid of calcium build up, which can cause your coffee maker to run very slowly, or not at all.
You always want to do a "1/3 white vineger to 2/3 water" solution--meaning that if you have a 10 cup coffee maker, you want to fill it 1/3 of the way up with vinegar (3 cups), the rest with water. If you have a 12 cup coffee maker, you want to do 4 cups of vinegar, fill it the rest with water. And yes, it DOES have to be white vinegar--the other vinegar types don't do anything for calcium ;)
You basically just brew the vinegar/water though your coffee maker, and you might have to do it 2-3 times before it will be completely fixed--most companies recommend that you run the vinegar/water through your coffee maker once ever 1 to 2 months to prevent things like this from happening, so if it's already happening, you may have to do it more.
And always remember--after you brew a pot of vinegar/water through your coffee maker, brew a regular pot of plain water through it afterwards, or your coffee will taste like vinegar! lol
If all else fails, you can always contact Waring customer support - their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Aug 26, 2009 | Waring Pro WC1000 Coffee Maker
Cusinart 12 cup grind and brew overflows with grinds and water
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
Apr 02, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Waring Pro WC1000: Pour over 12 cup coffee maker
Waring Pro WC1000 coffee maker replacement carafe is Waring WC1000CRF glass replacement coffee pot. Black lid and black handle.
http://www.bestreplacementpart.com/waring-pro-wc1000-replacement-carafe/
Feb 20, 2008 | Waring Pro WC1000 Coffee Maker
Waring Pro WC1000 Coffee Maker Logo
207 people viewed this question
Top Waring Coffee Makers & Espresso Machines Experts
Hjalmer Lamminen
Hjalmer Lamminen
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Waring Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
