Question about Gigabyte Computers & Internet
User Manual mother board gigabyte H61M-DS2 - Gigabyte Computers & Internet
    Problem Solver:
  • 9 Answers
sri2008
  • 53 Answers
SOURCE: mother board drivers for intel(r) gigabyte technology 81845gv
U can download the drivers from Gigabyte.com,.
Pl tri it
Regards
Was this soultion useful ?show ur appericiation by rating it
Posted on Mar 24, 2008
  • 135 Answers
SOURCE: GIGABYTE MOTHER BOARD
go to device manager and right click on the items not installed and go to properties. click update driver and use search automatically make sure your connected to internet and it will check windows update for drivers
if this does not work the will be a model number on the board starting with ga- get this and go to gigabyte site and search for drivers
Posted on Jan 18, 2009
SOURCE: download sound card driver for mother board gigabyte
100%100%
Posted on Mar 25, 2009
SOURCE: gigabyte ga-8ld533 mother board problem
i have a problem with my mother bord 8ld533.my head phone is not working properly also its working with a small sound,alredy a have installed my sound driver..can you help me please...
Posted on Oct 29, 2009
Semi-Driver
  • 434 Answers
SOURCE: WANTED MANUAL FOR MOTHER BOARD GIGABYTE GA-8S661FM
GA-8S661FXM was the closest model to your question. If this is not your board, this is the right website to find your exact model, OK? When you have located your model among the products, on the left side of the page, click the "Manual" link and input the exact model number.
Gigabyte GA-8S661FXM
Posted on Jan 02, 2010
IS NVIDIA GEFORCE GT 720 GRAPHIC COMPATIBLE WITH THE FOLLOWING MOTHERBOARD GIGABYTE H61M-DS2 .NO DISPLAY COMES ON .AS SOON AS I REMOVE THE DISPLAY GRAPHIC CARD ,THE DISPLAY COMES .PLEASE HELP
Sorry but I am confused. You connected to the graphics card when it was in your machine and it did not function? Or was your monitor connected to motherboard display port? Have to ask.If a PCIEcard is in the PCIE port then onboard video is cut off.The signal only comes from the card. The card should work fine on that motherboard as long as the the card and slot are compatible, are they both PCIE 2,or 2.1 or 3.0
Mar 09, 2015 | Nvidia Computers & Internet
My Gigabyte Mother Board shows some time Load Optimized Defaults ten boot or Load Optimized Defaults then reboot . How to fix it?
Hello
Its very simple just follow these steps:-
you can enter the BIOS by hitting the DEL or F2 key when the computer first starts up and then selecting Load optimized defaults.
The reason why it shows is that any changes you have made to your BIOS may not be saved or probably the CMOS is not firmly fixed.Hope this solves your problem.Please rate me if my solution helped you.Have a good day.
Regards,
bonefirediv.
Apr 11, 2014 | Gigabyte Technology Gigabyte GA-H61M-S1...
My Gigabyte Mother Board shows some time Load Optimized Defaults then boot / Load Optimized Defaults then reboot / enter BIOS. How to fix it?
Two things come to mind first. Number one would be making sure you have the most up to date bios. Number two would be that maybe the motherboard battery is dying/dead and isn't holding enough charge to after being shut down to save the option you selected.
Ga-h61m-s2v-b3 not coming on using power switch
I agree with Mike, but would like to add a couple of things. I had the same problem with a Gigabyte board (new install) and found that I had to change the CMOS battery. I put in a new batter, and "voila" it worked fine after that. Also, not knowing your level of experience, make sure the front panel connections are on correctly. Generally speaking, if you look at the lettering on the plastic ends that plug into the board pins on the front panel connector, the lettering should face the edge of the board and not be facing the middle of the board. That too has caused a similar sounding problem in the past. Other than these two potential solutions, more information is definitely needed.
Mar 20, 2014 | Gigabyte Motherboard Ga-H61M-s2P-B3 Core...
Gigabyte H61M-DS2 slow on XP
Windows actually run slow because of a hidden part of your system, which is constantly being used by Windows. This part of your PC is called the "registry" and is the central database for Windows, which stores everything from your latest emails to your desktop wallpaper. It's one of the most important parts of Windows and can easily make your PC run slow.The more corrupt registry files your computer has, the more it struggles to read them.The files which makes it run slower and slower. To fix this, you simply need to use a reliable like am using Reginout since 2011. This is the program which actually work by scanning through the registry and fixing any bad files that are in there. Then allows Windows to read as many files as it wants, when it wants to.
Dec 11, 2013 | Gigabyte GA-H61M-DS2 Motherboard
Its beeping and beeping and beeping
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
- Shut down your computer atleast two hour a day.
Aug 04, 2013 | Gigabyte GA-H61M-DS2 Motherboard
I have upgraded to Windows 7 and also a new Gigabyte GA-H61M-D2-B3 Motherboard. 4GB DDR Ram I have plugged my Cambridge Soundworks SW320 in but I only get some sound, eg all music and back ground sound is...
Gigabyte GA-H61M-D2-B3 Motherboard supports 2/4/5.1/7.1-channel HD audio, whereas Cambridge Soundworks SW320 is 2.1 (only). Hence, the PC should be configured to provide 2.1 Channel output. The audio of your system may be configured to 2.1. So, please check the Realtec Audio sound manager/ configuration from the control panel or from tray (near clock) and set it to 2.1 (2 Channel Stereo Output).
Moreover, audio on your PC may be running on default HD Audio Drivers. So, you may also download/ install the latest drivers for Gigabyte GA-H61M-D2-B3 Motherboard.
(Refer to download section at the bottom of the page). After installing audio drivers, you would be able to configure the audio.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 13, 2011 | Creative Labs SoundWorks SW320 Computer...
Driver problem
I think that is a Gigabyte brand motherboard
GA-945GM-DS2 (rev. 2.0)
If it is then this should be the web link for your drivers
The 1 at top is for audio Choose which Operating System you have and download which fits your pc , you failed to tell us what Operating system you have .
I would book mark the page and download all the other ones you might need also ,while there
http://www.gigabyte.co.nz/Support/Motherboard/Driver_Model.aspx?ProductID=2408
If your numbers on MotherBoard doesn't match just look under "Driver" left side 2nd from top and find a better match for your motherboard
Best of Luck
I hope this will fixya friend
Nov 18, 2007 | Computers & Internet
Open Questions:
Computers & Internet Logo
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
