Question about RCA L42FHD37 42 in. LCD HDTV
"Unusable Signal" Hello all. Purchased an RCA L42FHD37 LCD in November. Worked great, but now having intermitent "Unusable Signal" come up. It plays audio/video fine, then I lose both, then comes on again, and this repeats every few seconds or so. Only happens with my DVD player, which I have hooked up to HDMI port #3 on the TV, which is on the side of the TV. I have an OPPO upconverting DVD hooked up to it. Funny thing is, it worked fine up 'till now. Never had problems before, and didn't change anything. Tried a new HDMI cable, but still has the problem. Switched to another HDMI port on the TV (in the back), and it works fine. RCA had me lug TV to local RCA shop, who tells me I need a new PC board, which they are still waiting on. Does this make any sense? Any help would be great. atiq1969
  • atiq1969 Mar 16, 2009
    But is there even such a thing as a PCB board for a tv, and if so, what is it?
  • Devon Sacco
    Devon Sacco May 11, 2010
    It does make sense.
    Newer TV are no different than a computer, more like a laptop.
    Look at the web site for TV parts, Shopjimmy.com
    You browse around and see all the parts in side TV, and it's no different that a computer.
    The only problem I believe is the screens are generating too much heat inside the TV causing the life reduction of PC boards inside.
    Just think about it, a big screen that a lot of watts, a thin computer behind it with no cooling fan.
    President:
  • 1,077 Answers
Ok. PCB means Printed Circuit Board.
It looks similar to the picture down below. A part must have gone bad on your PC board. So, the RCA shop ordered a replacement PC board to fix the problem. It's an interchangeable part. All newer TV now have PC boards, which each one hold a different function.
Posted on Mar 18, 2009
RCA L46WD22 LCD tv (3 year-old unit)...No picture, tried unplugging for a few hours to ''re-set'' the computer...nothing, tried to view a DVD, nothing, just a black screen with the ''unusable signal''...
The back lights inverter is working because you can see the "Unusable Signal' on the screen, if the inverter is dead, yoo will see nothing on the screen at all.
If the T-CON (LCD controller) is dead, you will see just gray glowing screen with no pictures or text.
You may have problem with video processor in the main logic board (tuner, audio, source selector).
Parts for your TV:
http://www.shopjimmy.com/catalogsearch/result/index/?q=RCA+L46WD22+&stock=all&limit=100
This is going to be difficult repair since you do have a way to try out the replacement board to be sure that is the problem. RCA service person has that advantage of parts in stock to try out.
I estimate the board from Jimmy to be about $150, from RCA will be twice as much, plus labor.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 28, 2010 | RCA L46WD22 Television
42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
Dec 05, 2009 | RCA L42WD22 42 in. LCD Television
RCA LCD 42Lfhd37 Unusable signal
have you tried calling to the store you purchased it from and seeing if they will print you a new receipt. alot of stores will do this for you. also some times the store will cover the tv under manufacturers warranty and will send someone out to your house.
hope this help
please feel free to ask if you have any other questions.
Apr 06, 2009 | RCA L42FHD37 42 in. LCD HDTV
Installation of wii
I had the same problem on a 32" rca crt. It worked fine, power was cut during electrical work and when it came back, "unusable signal." I went into the menu, then channel, then video input source. had to change it to the correct input "s-video in my case" Then it worked. GOOD LUCK!
Feb 14, 2009 | Nintendo Wii Console
Unusable signal
we had that problem last week.i bought a new remote control and it worked fine.
Jan 01, 2009 | RCA L37WD12 37 in. LCD HDTV
Unusable signal
it was a fuse in the digital board i took it to an rca repair shop and had it fixed has been working great since
Sep 25, 2008 | RCA L46WD250 46 in. LCD HDTV
Unusable Signal
Hello Mike:
The issue that you are having is with your small signal board and it needs to be replaced, it sounds like the microprocessor on that board is getting locked up.
Aug 19, 2008 | RCA L42WD22 42 in. LCD Television
Unusable signal
Had the same problem unplug the tv for hour. Had ours at the tv repair shop and it worked fine there brought it home now we have a great picture but no sound.
Jun 01, 2008 | RCA P52930BL 52" Rear Projection...
Unusable Signal
You may have IB001 going bad, it is RCA P/N 263568, and should have TDA6107q labeled on the IC which should consist of 9 pins soldered into the PC Board and attached to an aluminum heat sink. It is a video IC and could be going bad unless you have a defective solder connection somewhere causing this symptom.
May 29, 2007 | RCA 27F530T 27" TV
RCA L42FHD37 42 in. LCD HDTV Logo
825 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
