Question about Black & Decker Arize Electronic Toaster 2-Slice
Toaster recall Toast catches on fire
2 Suggested Answers
  • 13 Answers
SOURCE: what should one do if
Switch the over off at the wall and unplug it first. Remove the burning toast with steel tongs or something similar that wont burn you and place toast in sink in water to extinguish flames if there are any
Your oven should be okay to use again under the following circumstances
  1. The toast was simply left in there too long, hence it caught on fire
  2. There was only smoke or a very small flame and the interior of the oven was not blackened
If in doubt or the flames were of reasonable size, or the interior of your oven has been blackened with smoke, do not reuse the oven without getting it checked over by a licensed electrician. There is a risk that you may have overheated and melted some of the wiring.
Posted on May 10, 2011
KCO223 toast function not working
I too have the same KCO223 countertop toaster oven, and the toast function is not working. All other functions work fine, but the blue light won't come on in the TOAST mode setting.
Apr 09, 2014 | KitchenAid 12" Convection Toaster Oven...
I didn't get a manuel and the toast does not go
The Instruction Manual for your West Bend 78224 QuickServe Toaster is available here:
http://www.westbend.com/supportdata/L5670-QuikServeToaster-ALL.pdf
Uneven or ragged edges on your toast can catch on the toast rack and prevent it from siding through on to the serving tray. Trim off any ragged edges.
Thank you for using FixYa!
Sep 15, 2011 | West Bend 78224 Toaster Oven
What should one do if the toast in oven catches on fire? please respond.
May 10, 2011 | Black & Decker Toaster Ovens
The toaster is only cooking on one side
u have a broken element on one side. You may be able to look inside and see the broken element. If not take the ends off it may be there. No matter it is a broken element. Keep looking for the broken element it may be slightly tacked to each broken end but not good enough to allow enough current to pass through.
Oct 07, 2010 | Dualit CTS4E 4-Slice Toaster
Toaster won't stay in down position in order to toast - Cuisinart CPT-160 - although it will toast if I hold the lever down as it toasts
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Dec 22, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
The lever doesn't stay down anymore, what should I do?
It sounds like the latch is broken. Unless you are very comfortable opening appliances and know very well what you are doing, it is best to have the toaster replaced. Check if it's still under warranty, or buy a new one.
Any workarounds to block the lever in its down position are very dangerous and a potential fire hazard. You may be able to wiggle the lever into place so it catches whatever is left of the latch, but make sure it will pop up easily when the toast is ready.
I hope this helps.
Nov 16, 2009 | DeLonghi RT200 Retro 2-Slice Toaster
Can you toast bread in it?
You turn on the grill part, set the temperature dial to high wait a few minutes then place the bread on the grill tray provided.
You will need to position the grill tray near the top of the oven because that is where the elements are.
The grill gets hot so you will need to use tongs or gloves to gain access to the bread
Keep a careful eye on the bread because unlike a Toaster it will not eject the bread when it is done and it will catch fire.
Quicker and cheaper to buy a purpose built toaster and use the other one for doing casseroles etc
Jun 16, 2009 | Dualit 89100 1500 Watts Toaster Oven with...
Sunbeam 3831 Toaster (2-slice) -- toast/carriage won't stay down
great ! its a great fealing when you save a appliance from the junkyard .
Mar 30, 2009 | Sunbeam 3831 2-Slice Toaster
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Black & Decker Arize Electronic Toaster 2-Slice Logo
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
