Question about Uniden PRO510XL 40-Channels Base CB Radio
Uniden Pro 5010xl CB has garbled transmission
I had a friend test it out with me and when he keys up and speaks, it sounds like this garbled distorted mess. He can hear me fine when I key up. I even tried swapping out antennas and still get the same result. I've had the radio a few years and the problem seemed to gradually get worse over time.
  • Rommel Cana
    Rommel Cana May 11, 2010
    may i know what antenna are you using?
  • 141 Answers
Sounds like its transmitting on SSB, not AM
Posted on Jan 30, 2010
  • thndr143 Jan 30, 2010
    Since it's not a SSB radio, Im gonna go with bad VCO/IC PLL voltage causing unstable frequency which is caused my excessive heat due to high SWR (no antenna, bad ground ect) or a bad mic element.
    Champion:
  • 219 Answers
Receving crystal sounds like its going bad if so you'll know this winter....crystals hate could weather
Posted on Nov 21, 2009
    Guru:
  • 773 Answers
Change the blown speaker.
Posted on Oct 04, 2009
  • 181 Answers
Have you changed the mic.
Posted on May 22, 2009
How do I resoder the plug on a uniden cb mi
You need a schematic diagram to make sure you connect the correct wire onto the correct connection, else you'll stuff up the radio.
If you've never done this before, then don't find a technically minded friend to do it for you.
That's my advice.
Cheers,
Peter
Apr 28, 2012 | Uniden Pro 510 XL
No audio keys up 3 watts pa has no audio to
  • Hi, I can help.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 23, 2011 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Have a uniden pc 68 elite it seems everything works the whene transmitting the needle moves a. but it has no volume it makes no noise i have tried a different mic i have put a new ext speaker on it and it...
Could be audio chip.
  • Insert external speak jack into pa port.
  • Turn volume down
  • Switch cb/pa switch to pa
  • speak into mic
if you are getting audio from speaker ......chip is fine.
Jan 04, 2011 | Uniden Bearcat Pro PC68Elite 40-Channels...
I have a Uniden Pro 510xl, it's about 9 yrs old. I went to use it last week and after turning it on, found that there was no sound, (turned the squelch up) . When I keyed the mic, I saw that I was...
chk mic, lose cable in **** plug test with other mic .. also test with Ext speaker.. do u get any reading on meter / LED display during RX? does PA work? otherwise your sound chip is dead
Dec 30, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
Garbled when transmitting on goldwing gl1500 cb
seems to be over modulating, turn modulation down or speak further from microphone, also ensure when you transmit, that you have 12 v at the power terminals
Sep 26, 2009 | Radio Communications
Mic not Keying up
Sounds like you are not modulating well. try adjusting your amp.also, test your antenna for wire breakage and, make sure that your mic has good wires as well.
Jan 22, 2009 | Uniden Bearcat Pro PC78XL 40-Channels Base...
Uniden Pro 510xl can send but not receive
If you look on the solder side of board you shoud see a straight line of 5-7 solder joints, look on the other side the audio vhjp is a bmack thin retangular ic chip. Not to worry you wont hurt anything by doing this. Its an old cb tech trick to test audio chips.GOOD LUCK.
Oh one other thing does the radio have same same problem in either vehicle? A insulating washer on the antenna bracket can cause this also,
Happy New Year , Tom
Dec 30, 2008 | Uniden PRO510XL 40-Channels Base CB Radio
Distorted voices
if it sounds garbled it may be due to digital communication. most scanners cannot recieve the digital communication. that is why you hear a garbled inaudible sound from it.
Jun 18, 2008 | Uniden BCD396T Handheld Scanner
Countinous Garbled Sound
Probably a DIGITAL/ENCRYPTED talkgroup that you cant get on the 246T
Nov 26, 2007 | Uniden BC246T Handheld Scanner
Uniden PRO510XL 40-Channels Base CB Radio Logo
263 people viewed this question
Top Uniden Radio Communications Experts
Iron
Iron
Jason
Robert McClure
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
