Lanier ld175 What is a 552 code?
Lanier printer spc240dn engine menu nsequence
Go to the Lanier web site and download the manual. If you can't find them then contact them through the site and ask for help. See: http://www.lanier.com/downloads/Default.aspx?hbn=manuals
Apr 01, 2015 | Lanier Office Equipment & Supplies
Service code sc301 on a lainer ld0105
http://copierquestions.messageboardchat.com/post/ricoh-savin-and-lanier-error-codes-3442638
Looks like it's a Charge Corona Output Error 2 - Charge Current Leak
Lanier is now owned by Ricoh (Savin and Lanier) ... you should contact them for repairs if you are not qualified to repair it yourself. Remember, there are very high voltages in there and you can do serious harm to your printer ... or worse, YOU.
Mar 01, 2014 | Office Equipment & Supplies
Lanier 5635 error code displaying a SC320
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
Oct 15, 2010 | Lanier 5222/27 Laser Printer
Have a lanier 6735 with an ''A1''Code
Hello sir; A-1 code means discharge corona cleaner problem, check it up may be the cleaner not function right.
Oct 16, 2009 | Lanier Office Equipment & Supplies
Lanier Model #7320 Copier SN 826255. Has a wrench
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
Sep 23, 2009 | Lanier Office Equipment & Supplies
Lanier copier ld145 locked up, code is sc546
Fuser warm up problem. Cause needs to be fixed and then code can be reset in service mode by a tech.
Jul 29, 2009 | Lanier Office Equipment & Supplies
Lanier 6725 need pm code or manual
A2 means something is wrong in the duplexer. Check all parts of the duplexer for jammed paper.
May 28, 2009 | Lanier Office Equipment & Supplies
18 people viewed this question
jasbo
jasbo
