Question about Mercury P4VM800M7 Motherboard
Whenever i shutdown my computer and restart it again only a black screen with mouse pointer appears in the welcome screen and then only if i change the first boot-in device to CD Rom i am able to log in, my date and time also  keeps on changing to the year 1999  .I have a mercury motherboard.
    Scholar:
  • 80 Answers
Hello my name is Tim Ehrhart and I believe If this pc has a floppy drive (3.5 mm) and it is first on the boot sequence then it sounds like it is a bad floppy drive and needs either removed or replaced, try setting the dvd drive to be first in the boot sequence and save it so it is always first. also try testing your floppy drive. hope this helps you out
Posted on Mar 13, 2009
Hard disk is not boot up after windows screen appears
It seems you computer is not recognising the hard-drive, on boot up, because it doesn't know where to look, i.e. it is booting up to a different drive letter. Have you got more than one drive on the system? If you have you will need to reconfigure the bootup list. Good Luck. George
Mar 29, 2013 | Fujitsu MHW2120BJ-G1 Hard drive 120GB...
The mouse
Hello there.
I recommend doing the following:
1) Shut down the computer (you can hold down the power button on the front of the computer base unit or laptop power button for a few seconds instead of using the mouse)
2) Unplug the mouse base station.
3) Plug the mouse base station in again
4) Turn on the computer and let it start up as normal.
5) Watch for any system messages appearing, like found new hardware.
These steps will verify that there is not a problem with the mouse's base station plugged into the computer. Another thing to check is if the mouse requires batteries, this is often overlooked.
If after doing this there is still no pointer registered, i would suggest trying the mouse in another computer, and if possible trying a different mouse on the same computer.
If the mouse works on another computer then it could be a software problem, which we can help you with.
If the mouse doesn't work on another computer, but a different mouse works fine on the same computer, then im afraid your mouse has to be replaced.
Please post back after trying the above steps and let us know. Telling us which mouse you have exactly will futher help.
Hope this helps.
May 09, 2008 | Logitech Cordless Mouse
Samsung laptop cursor tweeking
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 10, 2012 | Samsung SENS R460 LAPTOP LCD SCREEN 14.1"...
The cursor jumps around on my ASUS K501J notebook.
Step 1
Step 2
2. Select the "
Apply."
4. Pick the "
Step 3
Oct 08, 2012 | ASUS K50IJ Notebook
How do you unlock mouse on Laptop Toshiba? It is locked in the middle of screen.
is your mouse a lead or wireless mouse??? make sure the lead is securely seated make sure batteries are charged and the usb device is insereted correctly
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer if your mouse works in safe mode
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
or
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps you
Sep 13, 2011 | Toshiba Computers & Internet
Just upgraded to windows 7 and all of the sudden the cursor keeps moving where ever my mouse pointer is, why is this? I tried changing the pointer settings, but it didnt help.
Try the following:
1. Disconnect the mouse from the laptop
2. Shutdown your computer
3. Plug the mouse back in and reboot your computer
be sure to vote
Apr 22, 2010 | Toshiba Satellite A100-S8111TD Notebook
When i try to restart/turn off my shutdown menu is different how can i return it to normal?
Whenever u disable the windows welcome screen setting in xp the shutdown menu will be different. Goto Control Panel-> User Accounts -> Change The User Logs on and then check the Use Welcome Screen. You`ll get back ur old shutdown menu
Sep 25, 2009 | Microsoft Windows XP Professional With...
Black screen mouse pointer visible after i enter my password
hi..this problem is due to the loading drivers
during the time of login.The reason for the problem
may be due to the following reason.some files could
have got corrupted while loading drivers that may be
some damage due to the windows file corruption or
due to the virus corruption.
try it out..
thank u..
Feb 05, 2009 | HP Pavilion dv4000 Notebook
Wireless Mouse a Problem
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Dec 25, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Mercury P4VM800M7 Motherboard Logo
47 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
