Question about Tablets & eReaders
Any pin code to unlock etouch tablet e702 - Tablets & eReaders
How do i unlock my tablet
So it was being REALLY stealthy :>)
You will need to do a factory reset. Don't set a passcode!
In order to do a hard reset or a reboot, first turn the power off completely. Then while pressing the Volume + or Volume - press and hold the Power Button until the device switches on and a recovery menu appears on the screen which will guide you through the rest of the procedures. This should surely help and sort your problem.
Jan 23, 2016 | Trio Stealth G2 7 inch Tablet with 8GB...
Why did I lock myself out of my tablet?
How do I unlock my Tablet when it's locked with a pin code ...
visihow.com/How_i_unlock_my_tablet_when_its_lock_with_pin_code
I locked my tab with a pin lock and I forgot the code. ... Locked out of my Samsung Galaxy S2 i91000? .... can use, the following steps (as well as the video above) in order to help yourself to get back into your device by using a reset combination: .... Cannot get my screen on my tablet to unlock, don't remember pin number?
My Tablet has been locked and I also forgot its Google ID ...
visihow.com/I_have_locked_my_tablet_and_now_I_do_not_know_its_...
The easiest way out right now would be to reset your Tablet. Press the ... Yes ' No ' I need help. See more questions like this: I forgot my pin password on my o+ mobile ...My Android phone has been locked and it asks for Google accounts, but I don't remember which one I used. .... I've tried to break into it myself. How can I ...
Hard reset your Android phone or tablet when you forget the ...
Jan 01, 2016 | Irulu 7" 4gb Mid Google Android 2.3...
I forgot my pin code of my tablet how i open it?
If you have an android table, the only chance you have is to enter your Gmail account credentials to unlock it. Otherwise you have to do an "hard reset" as explained in this page: How unlock my tablet when its lock with pin code
But be careful because you'll loose all your data !
Feb 11, 2015 | Tablets & eReaders
Got a eTOUCH tablet and I'm trying to connect the Internet though my personal hotspot on my iPhone4 for some reason it will only save my device on the tablet won't connect?? I'm stuck with what to do...
Hi Jess
If you are trying to connect via bluetooth or via a connected serial cable, then perhaps your eTouch is expecting a device with files. Like a hard drive.
If the iPhone4 (make sure it's up to date & running version IOS7.1.2) has Hotspot turned on with No cables attached & Bluetooth turned off,... it will be broadcasting it's 3G Internet connection over WiFi.
On it's WiFi Antenna. ... It's Hotspot.
I don't use an eTouch, I'm all Apple so I use iPad.... so I don't know the particulars of eTouch technology. But... I would assume Your eTOUCH has the ability to pick up this WFii signal just like it was connecting to any local hotspot service in the neighbourhood. Thereby giving you access to the internet when your eTouch picks up this signal. Like on an iPad, you may have to go to the settings or control panel and choose the Network & Wifi Name and give it a password or key to allow you to join.
For people with limited technical ability I always recommend that they use the benefits of Apple's Ecosystem. Things just connect simply and easily. Thats why we pay a higher price for their technology. If your a nurd and don't mind diving in to the guts of technology then buy a PC with windowz.
Good Luck
Trevor
Jul 14, 2014 | Tablets & eReaders
Etouch tablet
It looks like your tablet isn't calibrated correctly. Go to the settings and look for touch screen calibration.
May 22, 2013 | Tablets & eReaders
Etouch android wont charge
switch off.wait for 5 mins.
connect to pc or laptop with usb cable.
press & hold power button till it turns on then off.
press power button for 3 secs.it should work.
if no luck try this-
switch on by pressing power button while holding volume + and -.
keep hold of both until powers on.
can take few mins.
good luck!!!
Jun 27, 2012 | Tablets & eReaders
Tablets & eReaders Logo
99 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
