Question about Mitsubishi WD-52631 52" Projection HDTV
My remote will not work with my TV (Mitsubishi WD52631). The remote had been working fine. The remote appears to be functioning and the batteries are ok. I've reset the TV and the remote using code 00935 and tried code 00936 and neither will resolve the problem...help!
  • dino_1653 Mar 13, 2009
    No the crystal is fine, but thanks!
  • 76 Answers
The crystal probally broke when fallen down,slammed down.goto w mart universal 15$
Posted on Mar 13, 2009
Mitsubishi tv remote will not turn tv on. put in new batteries already . only the red light on the tv button turns on.
You should reprogram your remote. Start with the tv on. You have got to find a code that will operate all of the functions you want it to. In others some code will only turn on the tv. Some codes will work with volume and the channels. Once you find a code that works you should be able to operate the tv with the remote. It sounds like to me when you put new batteries you erased the function of your mitsbishi remote. So once the tv turns off you have found your code.. but make sure before you save it you write down on something; and, it works all of the functions that you want it to. I hope that this helps a ton...
Jun 29, 2014 | Mitsubishi New Original 290P137C10 Remote...
How do i get c/captions , i do NOT have a factory remote model # cs-26201
Oddly the Closed Caption function in that set is accessed with the remote by pushing the VIDEO button which cycles through contrast, brightness, tint, color and eventually to CC. You don't need the factory remote just one of those generics specific to operating a Mitsubishi tv. Just google Mitsubishi remote and you'll find some relatively cheap that work fine.
Jun 16, 2009 | Mitsubishi Televison & Video
52" dlp
YOU NEED TO RESET THE TV. USE A PAPER CLIP TO HOLD DOWN THE BUTTON, AFTER THE LIGHT FLASHES FOR ABOUT ONE MINUTE YOU SHOULD BE ABLE TO TURN ON THE TV.
Jun 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The remote does not work. My satelite remote
There is usually a remote module mounted on the inside of the front of the tv that senses the remote signal. This controls all functions of the tv. If you are not comfortable in troubleshooting this, I would recommend a repair center.
Mar 07, 2009 | Mitsubishi WS-65313 65" Rear Projection...
WS-55511 55in volume turns up by itself & can't switch devices
The remote is not the problem. The switch for volume up on the control panel has become leaky. Very common problem for this generation Mitsubishi. If you don't mind not having the control panel working you can disconnect it and the set will work just fine with the remote. To disconnect the control panel pull the speaker grill, it just snaps off, and remove the front access panel. Once that is done you'll see a cable going to the switches just disconnect it.
Nov 23, 2008 | Mitsubishi WS-55511 55" Rear Projection...
TV won't come on
Im not at home right now so I can not get the exact part number but you need the powersupply for this set. There are numerous bad capacitors on this board and you might have a blown main on here. Replacing this will repair your set back to working condition.
Josh
Feb 21, 2008 | Mitsubishi WD-52631 52" Projection HDTV
WS-55908 remote control
Take out the batteries or simply reprogram the remote by using the manual search function on the remote. There is probably a couple of different settings in the remote for this type of TV set, Good Luck
Jul 02, 2007 | Mitsubishi WS-55908 55" Rear Projection...
Mitsubishi WD-52631 52" Projection HDTV Logo
687 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
