Chipsbnk flash disk repair
Description: [G:]USB Mass Storage Device(ChipsBnk Flash Disk) Device Type: Mass Storage Device Protocal Version: USB 2.00 Current Speed: High Speed Max Current: 100mA USB Device ID: VID = 1E3D PID = 2093 Device Revision: 0100 Manufacturer: ChipsBnk Product Model: Product Revision: 5.00 Chip Vendor: ChipsBank Chip Part-Number: CBM2093/V88 - [2009-03-28]
3 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: how can i fix my
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair the tick the second box
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Posted on Mar 25, 2011
  • 14 Answers
SOURCE: boot adata 8G
http://www.flashboot.ru/forum/index.php?topic=13924.0
Posted on Aug 16, 2012
My flash kingstone 16 g is not accessable how to make it work?
Maybe there is such a kind of bad sectors on the hard disk.
You can use softwares to improve flash / hard drive.
Can be downloaded for free, it's freeware.
I recommend, HDD REGENERATOR, which can repairing without deleting the data (if there is data).
If the flash does not contain data, try reformatted.
Can also initialize from the device manager.
Or if necessary, run FDISK.
Aug 27, 2015 | Computers & Internet
System32\config\system is corrupted. I want to boot from a flash drive. How it is made, the flash drive?
I recommend you to boot from a Windows CD and use the 'repair' option.
Anyways, Flash Drive is a Universal Serial Bus - Mass Storage Device (USB Memory Storage Device) also known as Pen Drive in common.
  • To install/Repair OS using a Flash Drive, you need to follow these steps
Make your flash drive bootable using Bart's mkbt util:
http://www.nu2.nu/mkbt/ ' Alt: mkbt20.zip
  1. Put a bootable floppy disk in your A: drive or create one using Windows.
  2. Download mkbt20.zip and unpack to to new temp folder you create.
  3. Go to the temp folder.
  4. Extract the bootsector from the bootable floppy disk. eg Open a DOS Window and go to the directory where you extracted MKBT. Type:  mkbt -c a: bootsect.bin
  5. The boot sectors from the bootable floppy disk have just been saved to a file in the temp folder you created.
  6. Format the flash drive in FAT or FAT16.
  7. Copy the bootsector to the flash drive. Open a DOS Window and go to the folder where you extracted MKBT. Type:  mkbt -x bootsect.bin Z:
"Z" represents the flash drive drive Letter. So if your flash drive has another drive letter, then change the "Z" accordingly.
Now you should be able to copy the utilities you need to the pen drive.
If you need more Methods/Options, you can check BootDisk
Aug 11, 2011 | Computers & Internet
Instructions for password protection option on Maxell usb 360 flash drive
click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Mar 20, 2011 | Computers & Internet
Hi, im having problem with my windows usb it cannot be detected by my windows xp.. in the device manager the mass storage device is marked (x) on it. what would i do to make this functional on my...
First of all try changing the usb port you are using I am sure that there will be more than one usb ports in your PC. After this try using another similar USB device.
I mean if you are trying to plug in a Flash drive use a different one or If you are trying to connect an external Hard Disk (as it is obvious from the mass storage device marked with an x as you have pointed out). Try using a different External Hard Disk that you may borrow from someone checks will help you locate the problem. The reason why your USB device is not being detected by your PC must be the driver of the USB drive is out dated. Check the version of the USB Is it 2.0? or the driver might have been corrupt.
You can download USB Mass storage driver from the following site. You can search for USB drivers on other sites also.
http://download.cnet.com/windows/usb-drivers/
Best of Luck!
Jul 31, 2010 | Microsoft Windows XP Professional for PC
WITH SERVICE PACK 3 (WIN XP) MY 795 IS "DISCONNECTED" NO MATTER WHAT! PLEASE HELP!!
The iFP-795 is a player that has connection type UMS
(also called MSC): seeing the player as a removable disk:
Go to next site to see the connection type:
http://www.iriver.com/flash/index.asp?code=0300
and click on connection. Scroll down to see the iFP-700 series listed in the connection type UMS.
UMS = Universal Mass Storage
MSC = Mass Storage Class
With XP sp3 the computer Operating System has setup USB connections with new drivers, that support both UMS (= MSC) and MTP connections.
MTP = Media Transfer Protocol
When you experience next making connection:
Connecting the device to the computer Wizard found new hardware pops up.
Only this time the Windows update searching for software will not work on automatic routine: ending up with "Cannot Install this Hardware".
Manual performing the wizard, setting the device to USB connection type:
1. Can Windows connect to Windows Update to search for software ?
Select "No, not this time".
[Next]
2. If your hardware came with an installation CD, or floppy disk, insert it now.
Select "Install from a list or specific location(Advanced)."
[Next]
3. Please use your search and installations options.
Select "Don't search I will choose the driver to install."
[Next]
4. Select the device driver you want to install for this hardware.
Select "USB Mass Storage Device."
[Finish]
Just post a comment if you need more help.
Sep 24, 2009 | iRiver iFP-795 MP3 Player
How do I get started using a USB flash drive and how do I set up a security system?
hey, heres something that would help u:  Copying files to a flash drive on a PC:
  1. Open My Computer and see which drives are shown. Most computers, for example, have a hard disk such as a C: drive and a few removable storage devices such as a floppy drive, a CD-ROM drive, and perhaps a zip drive.
  2. Insert the flash drive into the USB port and watch to see where the USB flash drive appears. Most will appear as removable storage, but some will instead appear as hard drives. Note the name Windows is using to refer to the flash drive ("Removable Disk (G:)," for example).
  3. Open My Documents or the location from which you want to transfer files to the flash drive. Select the files or folders you want to save to the flash drive by left-clicking on them. To select more than one, hold down the CTRL key while you click and select all of the files you wish to save.
  4. Right-click on the file(s) or folder(s) you selected, then select Send to, then select the name you saw appearing in My Computer for the flash drive ("Removable Disk (G:)," for example).
  5. When the copying is finished, do not immediately remove the flash drive from the USB port. Instead, left-click on the Remove Hardware icon toolbar.gif located in the System Tray. A window containing a list of the USB devices will appear. Left-click on the Safely Remove Mass Storage Device line that matches your flash drive (for example, Safely Remove Mass Storage Device - Drive(G:)).
  6. When you see the following message appear in the bottom left toolbar, it is, as it says, safe to remove the flash drive from the USB port; you may close the message or ignore it, as it will close itself automatically:
Copying files from a flash drive on a PC:
  3. Double-click on the flash drive to locate the file(s) or folder(s) you want to copy to this computer. Select the files or folders you want to copy by left-clicking on them. To select more than one, hold down the CTRL key while you click and select all of the files or folders you wish to copy.
  4. Right-click on the files or folders you have selected and choose Copy.
  5. Open My Documents or the location to which you want to transfer files from the flash drive.
  6. Click on the Edit menu, then select Paste.
  7. When the copying is finished, do not immediately remove the flash drive from the USB port. Instead, left-click on the Remove Hardware icon toolbar.gif located in the System Tray. A window containing a list of the USB devices will appear. Left-click on the Safely Remove Mass Storage Device line that matches your flash drive (for example, Safely Remove Mass Storage Device - Drive(G:)).
  8. When you see the following message appear in the bottom left toolbar, it is, as it says, safe to remove the flash drive from the USB port; you may close the message or ignore it, as it will close itself automatically:
    ok_msg.gif                                      =========================================================
For the security system setup go through the following link .. http://www.rohos.com/configuring_usb_stick_logon.htm
if u require some other sort of security system let me know.
cheers
Oct 13, 2008 | Computers & Internet
Can't open my flash disk
my computer asks me to format my flash disk yet have been using it over and over a gain.what could be the problem pliz help.peter Okeyo
Nov 09, 2007 | Electronics - Others
Computers & Internet Logo
1,447 people viewed this question
David Payne
David Payne
