Question about Dryers
How do I assemble the Bosch wta 2000 tumble dryer switch.
SOURCE: Bosch WTA 3100 Tumble Dryer ON/OFF switch
The on/off switch is combined with the door release switch in one item - part number 154145 (a little over £20) and my problem was the door interlock bit had failed. The following worked for me :
Plug out, remove top panel, and open door + look up at switch panel - you see 5 slots under the switch panel (the 2 outer ones are mostly covered by the main front panel). Start at either side and work across, using as wide-bladed a screwdriver as will fit across the slot width : put a wood block under blade as a support and lever bottom of panel towards front - each has a plastic pin behind pointing towards the rear, held by a spring clip. Each will pop clear and when all are unclipped you rotate the panel outwards from the bottom edge, taking the timer knob and its drive linkage with it. To get switch out I removed the door and the screws around the main front panel - one is hidden behind a cover plug below the access port (to gain access to bottom screws on main panel, lever the bottom panel outwards along its top edge).
Posted on Sep 08, 2008
canbruce75
  • 1776 Answers
SOURCE: bosch tumble dryer, model wta 4100 , no heat,
If the dryer isn't heating, check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. Both components are located in the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Hope this helped and best wishes.
Posted on Sep 12, 2009
  • 18 Answers
SOURCE: bosch wta 2000 dryer, heats but drum not turning
If you can hear the motor running then the belt has came off or it is broken. If you cant hear the motor then you possibly have a bad motor.
Posted on Mar 08, 2010
SOURCE: Where do I find the reset button on the Bosch WTA
my dryer is blowing cold air it is a bosch 2000wta
Posted on Apr 07, 2010
small6363
  • 18409 Answers
SOURCE: Bosch WTA2000 Tumble Dryer. Main on/off switch is hard to press, will not come on . How can i take the front panel off.
click this link for instructions
http://www.youtube.com/watch?v=3mfozpKPcB0&feature=relmfu
Posted on Aug 28, 2012
How to reconnect the wiring on the bosch wta 2000 tumble dryer?
And why did you not tag the wires when disconnecting them as a good repairman always does .
Sep 16, 2015 | Bosch Tumble Dryer Fluff Lint Filter...
Bosch WTA2000 tumble dryer motor turns weakly without the belt.
The brushes in the motor are probably shot. Good luck in finding those though, best to just replace the motor.
Dec 09, 2013 | Bosch Axxis WTA 3510 Electric Dryer
I replaced the heating element on my Bosh WTA 2000 tumble dryer , but it still doesn't heat up? Is there other components that could be damaged?
There are multiple thermal protectors on the circuit. Make sure they are all ok. Double check your connections
Aug 08, 2013 | Bosch Dryers
How do you change the drive belt on a Bosch Classixx tumble dryer WTA3003GB/17?
Its a fairly simple process depending on your machine. Most Bosch machine belts are simple to replace. Here is a good resource: http://www.videojug.com/film/how-to-replace-the-belt-on-a-tumble-dryer-bosch
Dec 03, 2010 | Bosch Axxis WTA 3003 Electric Dryer
Looking for manual for the bosch wta 2000 tumble dryer. thank you.
I've made a PDF of the Bosch WTA2000 Tumble Dryer User Manual and (hopefully) it will be available on this link in case anyone else still needs a copy, as the original request above is a bit old now.
It's a leeeettle blurry as I should have used a higher dpi when scanning the pages, but I can't be bothered doing it all again. I think it should be sufficient for purpose anyway.
https://onedrive.live.com/?cid=5D5DECF4115C2175&id=5D5DECF4115C2175!189
Nov 21, 2010 | Dryers
Where do I find the reset button on the Bosch WTA 3100 tumble dryer?
It would be at the rear of the machine. You need to remove the rear cover which is secured by Self-Tapping screws. Cover would be almost circular in shape and the button is in the position 10 o'clock looking from the rear.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 11, 2009 | Bosch Dryers
Bosch tumble dryer, model wta 4100 , no heat, otherwise all OK
Sep 12, 2009 | Bosch Dryers
Drive Belt on BOSCH WTA 3003 dryer
No,It`s quite a difficult & fiddly job.
Nov 10, 2008 | Bosch Axxis WTA 3003 Electric Dryer
Dryers Logo
55 people viewed this question
Top Dryers Experts
