Question about Vulcan EF3 Deep Fryer
Sg14dont fire up
Pitco sg14 change out t-cup it work like a champ..2 month later today it will not fire up..the pilot stay on
    Scholar:
  • 127 Answers
If the pilot stays on, the thermopile and high limit are good. Check for continuity across the thermostat terminals when set at operating temperature. Usually, when you turn the temperature control up you will hear it click on. If the thermostat is good, the gas valve is bad. Replace it.
Posted on Mar 17, 2009
    Sergeant:
    Champion:
  • 234 Answers
The thermocouplen is bad .But before you replace it try to reset the hi limit.It you lite and hold for minute and still go out replace the thermocouplen.
Posted on Mar 13, 2009
Pitco frialator excessive pilot flame
If you didn't figure it out already you lost the orifice on the pilot light. It's a little metal cup with a tiny hole in it that slips over the end of the gas tube in the pilot assembly. The orifice controls the size of the pilot light. Need to get a new one or find the lost part.
Oct 11, 2012 | Pitco Frialator SG14 Deep Fryer
Pitco deep fryer flames coming out the fryer
Hi there.
The soot or carbon have probably build up inside the fire tubes, better check and have an authorized service technician clean them.
Make sure that the fryer is receiving the rated gas pressure and correct gas type as stated on the nameplate, this way, carbon or soot formation on fire tubes can be prevented
Regards.
Sep 12, 2011 | Pitco Frialator SG14 Deep Fryer
I have 2 SG14 Pitco fryer, One of them have fail to work. It seems that the pilot flame is become smaller, but it will stay on. When I turn it to 325F, sometimes it will turn on the fire, but it will heat...
Have you tried adjusting pilot light or recalibrating your thermostat? it sounds similar to the problem i just had, but replacing the thermopile worked for me, but i also replaced my thermostat and high limit switch prior to the thermopile.I also made sure all my connections were cleaned. i'm not an expert by the way just someone who went through the same problem.
Oct 23, 2010 | Pitco Frialator SG14 Deep Fryer
Pitco Frialator SF14 pilot will light and the burners will light but within an hour it completely shuts off (pilot and burners). The high limit and thermostat have been changed 1 month ago.
Check the hi limit sensing bulb, it should not touch the fire tube, when it does, it will sense high temperature which will trip its mechanical contacts and will shut pilot and burner flames.
Make also sure that the thermopile is free of soot or any form of dirt and is properly heated by the pilot flame.
Jul 06, 2010 | Pitco Frialator SG14 Deep Fryer
I have a gas fryer (pitco) that has no electric running to it,why does it have wires running from the thermocoupling
The thermopile on gas operated equipment acts as small voltage generator when heated that energizes the pilot valve and main valve of the gas valve,. Without it, you will not be able to fire up your fryer.
Apr 28, 2010 | Pitco Frialator SG14 Deep Fryer
Pitco Fryer will not light up
Check the thermopile, it must be free of dirt or soot so that it can absorb enough heat from pilot flame and in turn can generate the right amount of voltage to energize pilot and burner coils.
Check also the gas pressure, it should be of standard as required on the unit's nameplate.
Apr 15, 2010 | Pitco Frialator SG14 Deep Fryer
Pilot is off.
Most fryers have pilot lighting instructions on the inside of the door. If yours doesn't then find the gas valve, turn the knob to the pilot position, push in on the knob and light the pilot. Keep the knob pushed in after you lite the pilot for at least another 30 seconds. The pilot should stay lit.
Feb 22, 2010 | Pitco Frialator SG14 Deep Fryer
Pitco Fryalator
This is caused by a failing pilot safty bypass inside the gas valve itself. You will need to replace the gas valve.
Aug 11, 2008 | Pitco Frialator SG14 Deep Fryer
Pilot light won't stay lit
Wrong voltage thermocouple? must have 400mv, residential uses 25-40mv.
Feb 10, 2008 | Pitco Frialator SG14 Deep Fryer
Vulcan EF3 Deep Fryer Logo
139 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Treefrog15
Treefrog15
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
