Question about Garden
What would make the positive battery terminal post melt on my lawn tractor
2 Suggested Answers
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
Where is the solenoid located on a briggs and stratton engine model number 282H07/0334
Mary Jo, solenoid is not normally on engine, follow the positive battery cable from battery to where it bolts to a small double terminal device(this is the solenoid) the other bolt has cable attached that goes to battery.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mower Starter Solenoid Replacement Craftsman Riding Lawn Mower Repair Part...
Replacing Solenoid on Craftsman Lawn Mower or Tractor
Mar 24, 2016 | Briggs & Stratton Garden
Wont start no power to switch
I'm not familiar with your brand and make of lawn tractor but here's a few basics many of them have in common.
Any one of several safety features on newer lawn tractors will prevent it from starting.
Assuming your battery is fully charged, here's a few basic things to check, depending upon your level of skill and motivation:
1. Parking brake: A switch must be engaged when the parking brake is set. Most newer lawn tractors have to have the brake set to allow the starter interlock relay to energize the starter.
2. Blade engagement PTO: The blade PTO switch or lever must be OFF or the tractor starter won't energize.
3. Seat switch: Some (not all) newer lawn tractors won't start if the operator presence seat switch is not closed. (you have to be sitting in the seat or the starter will not be energized.)
4.. Corroded/loose battery terminals or wires. Remove the battery leads and clean the terminals. Check and make certain the battery leads are tight.
You can do some investigative sleuthing by using a multimeter, set in the OHM position, to test switch continuity. Locate and unplug these switches from the wiring harness, one at a time. Insert the meter's test leads into the switch plug's terminals; not the wiring harness. Activate the switch. If your meter shows current pass-through or continuity, the switch is working. If the meter reads OL (for digital meters) or stays at zero, that switch is bad.
If your safety switches are good, you'll have to look deeper.
Some lawn tractors have a fuse panel to protect the electrical circuits and components.
1. If you have a fuse block on your tractor, remove the plastic cover. Most of the fuses in today's tractors are the color coded, plastic cased, automotive type. Remove each fuse and inspect their filaments one at a time. A blown fuse will be easily identified. Replace any blown fuse.
2. The starter interlock relay may be faulty, or have a disconnected/broken wire. Check your wires and terminals. The starter switch itself may be faulty. Use your meter in the OHM setting, put your leads on the starter switch terminals with the switch disconnected and off. Turn on the ignition switch and turn the switch to the start position. If the switch shows current pass-through, the switch is good. If not, replace it.
3. Is your battery discharged? Do you hear a "click" when you try to start your tractor? If you hear a "click" when you turn your key to the start position, and your battery is charged, there's a strong likelihood your starter has malfunctioned and needs to be replaced. (or your engine is seized) If you hear absolutely nothing while trying to crank over the engine, it's a safe bet you're not getting power to the starter because of a safety switch, bad fuse, starter interlock relay, or a broken/disconnected wire somewhere.
Sep 20, 2015 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
Which side is the positive battery terminal wire on an Ariens riding lawn mower
check and see that one terminal should lead you to the starter,it should be a positive
Jul 02, 2013 | Garden
Hello - I have craftsman 42 inch deck mower with a kohlar engine that does not start. Battery appears fine, when I turn it - it clicks with the head lights turning on. Ang ideas on how to get it started?...
With the key in the run position, using a jumper cable, jump from the positive post on battery to terminal on starter motor. If it runs you have a solenoid or ignition switch problem. (assuming all electrical connections are clean). If it doesn't crank the battery is the culprit.
Oct 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My husband has a husqvarna GTH2654 tractor. We are having a hard time finding a replacement battery. Do you have any suggestions??
Sears auto centers generally carry lawn tractor batteries. Or go to a specialized battery store like Battery Exchange. The lawn tractor batteries are all pretty much the same outward size, but three things to beware of:
  • Be sure it has the same type of terminal (some have a hole in them, others are simply posts)
  • The positive terminal must be at the same end as your current battery (they are made both ways, and the cables may not be long enough to cross over to the other terminal, not the mention the risk of putting them on backwards which is a disaster)
  • Buy the heaviest-duty battery. Your tractor has a nice hefty motor and an economy battery will have a short life.
Bottom line: take the old battery with you and don't come back with a new one unless it matches up properly. Good luck! Please rate my solution if helpful.
Aug 09, 2010 | Husqvarna Garden
Craftsman Lawn Tractor, 18 HP, 44" Cut; No SWtart!
Check the by pass switches on the seat, clutch pedal, and check the fuses.
May 15, 2010 | Craftsman Garden
Need a wiring diagram for solenoid on Ford lawn tractor. Trying to reconnect solenoid after replacing it (battery loses its charge almost too easily, and we constantly have to charge the battery). Any...
one wire goes from the positive terminal on the battery to either post on the solenoid, another wire goes from the other post on the solenoid to the starter. you will have a 3rd small gauge wire coming from the key switch and this goes to the small terminal on the solenoid. all in all it's pretty straight forward. hope this helps you.
Sep 19, 2009 | Ford Garden
Replaced battery for lawn tractor and nothing happens.
You probably just blew the fuse behind the ignition or the fuse link on the power to solenoid.
May 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
143 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
