Question about HP Officejet 6100 e-Printer Wireless Color Printer
Hp officejet 6100 eprinter hard reset
I configured an ip address and i cannot access the webpage, i need to reset the printer back to factory defaults but i dont know how to? any ideas?
eng_darwish1
  • 233 Answers
SOURCE: default hp 2015 password so I can change the IP address
make a cold reset or NVRAM reset
To do a cold reset you power on the printer while holding down the go button for about 5 seconds and then release the button. If the button is held for more then 15 seconds it may do a NVRAM reset
Posted on Jul 07, 2008
  • 61 Answers
SOURCE: HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Posted on Jul 24, 2008
leroyal
  • 2120 Answers
SOURCE: Resetting network settings to default on HP 2015n
Enter the ip address into your we browser annd reset in the options
Posted on Feb 04, 2009
SOURCE: Hp officejet pro L7780
I just did the full resetting, hold # + 9 while is on (is what i did) and i unplug the power cord just one is back of the printer, and released for a while to connect again power cord, so when printer star back on, i hold again # + 9 for a 15 seconds, and power off for a moment, later push the power bottom and start a blue screen with FULL RVRAM something like that, leave the printer , is gonne make alignments and so on , so after 10-15 minutes AWSOME , factory reset setting, GOOD LUCK
Posted on Dec 30, 2010
Prefab
  • 152 Answers
SOURCE: how to i configure the
Hello, When you first install the printer onto the Network it will automatically find an IP Address, this is called "DHCP". In order to change the IP Address the printer needs to be setup as what is known as "STATIC". You can do this in in a couple of ways 1) Type the IP Adrees into an internet explorer Browser, this should open up the printers EWS (embedded Web Browser) if it opens click on the networking tab - Chnge the IP Address , set DHCP to "OFF"and click Apply. 2) From the printers control panel - push the "MENU" button and scroll down to the "CONFIGURE DEVICE" to "I/O" to "EMBEDDED JETDIRECT" Withi the TCIP setting you are able to change the printers IP Address
Posted on Jan 15, 2011
How can i do a factory reset on a hp officejet pro 8100
You don't factory reset printers Jennifer. You only factory reset cellphones and tablets.
What you need to do on your new computer is download the Officejet Pro 8100 software suite which includes scan software and drivers. You will find these on the HP website. Or perhaps you have the installation CD in a drawer somewhere?
Make a COMMENT to this post if you need any further help.
Mar 20, 2016 | HP Officejet Pro 8100 Wireless Inkjet...
How do I delete eprint?
Usually for HP printers not being recognized because they loose their IP address on the network or the computer can't see it.
What you can do is completley uninstall the HP software for the Officejet 8600, then go to HP.com lookup the officejet 8600 under Support > Download Drivers. download the latest full installation then run the install. When it ask you how to install it do the custom install and then only select the things you want to install.
When it ask you to do the eprint set up you can skip that part. also once install try running the HP updates for find any Network fixes or and Firmware updates.
HP Officejet Pro 8600 All in One Printer N911a Software and Drivers
Aug 06, 2015 | HP CM749A - Officejet Pro 8600...
Reset hp 1515n
? Restore defaults-used to reset all customer-accessible menu settings back to the factory default
settings (except language) via the control panel or software
NOTE: This service menu item does not reset factory-settable settings, including formatter
number, page counts, factory paper settings, language, and so on.
NOTE: Before restoring defaults, print a menu structure report and a configuration page. Use the
information on these pages to reset customer-specific settings.
CAUTION: All HP Jetdirect settings are also reset. Be sure to print a configuration page before
restoring defaults. Make note of the IP address that is listed on the Jetdirect configuration page. You might need to restore the IP address after performing a cold reset.
Restore the factory-set defaults on the (HP Color LaserJet CP1510 Series Printer
1. Press OK to open the menus.
2. Use the Left arrow or the Right arrow button to select Service, and then press OK (Select).
3. Use the Left arrow or the Right arrow button to select Restore defaults, and then press OK.
The product automatically restarts.
Jul 13, 2011 | HP LaserJet CP1515n Printer
Hi, I need to reset my Printer using cold reset option. please help.
? Cold Reset
CAUTION All HP Jetdirect settings are also reset. Be sure to print a configuration page
before performing a cold reset. Make a note of the IP address that is listed on the Jetdirect
page. You must restore the IP address after performing a cold reset.
Use this item to unlock menus that have been previously locked and to set all control panel menu
items (including EIO settings) back to the factory defaults. However, using this item does not clear
the values in the SERVICE menu (such as the serial number and page counts).
NOTE Before performing a cold reset, print a menu map and a configuration page.
Use the information on the configuration page to reset any customer-set device configuration values that the cold reset procedure changes.
Apr 14, 2011 | HP LaserJet M5035 MFP Printer
Hi, I rested my HP 1022n Printer, now with old IP address its not printing, how can get my printer new IP address ? and please tell me how can take Test report of same printer, i tried pressing Green(go)...
Every network printer or print server has a unique IP address associated with it. This address is either configured manually or set using an automatic network protocol such as the boot protocol, reverse address resolution protocol or zeroconf. You can normally find the IP address of a printer on the printer's control panel or by printing the configuration page. Select the printers and faxes tab from the control panel. Right click on the printer those you want to find the IP address and click properties. Then click on the ports tab to display the IP address of your printer.
Nov 25, 2010 | HP LaserJet 1022n Printer
Not printing
When printing from the microsoft word document, make sure the printer selected is right. By that, i mean the default printer selected in the printers icon under the control panel should be HP OfficeJet 6100 series and not HP OfficeJet 6100 fax.
So the reason why this message comes up " scanner failure ". is you are either selecting a wrong printer when printing from microsoft word document or probably the printer port is not selected right.
To check the printer port.
Click on start-->control panel-->printer & faxes-->right click on HP OfficeJet 6100 series--> select properties-->Select the top tab called ports-->
Check the ports selected here.
If you have a USB connected printer it should be your printer model with USB settings.
If you have a wireless connected printer it should be your printer model with wireless settings like IP address.
Apr 29, 2010 | HP OfficeJet 6110 All-In-One InkJet...
On the front panel of my L7680 all in one printer I usally get an option to scan to email, however I now only have 2 options 1. scan and repeat 2. scan to memory device. How do I get the full list back?
we need to perform a reset, it will take the pritner to the factory settings and this may help you,
the process of reset goes like.
unplug the power cable from the pritner >
then press and hold down the # key and 6 key >
while pressing and holding these keys plug in the power cable back into the printer and wait for 20 secs and then release the buttons..
after this the printer will re-initialize and this might take few minutes.. so wait untill it finishes and follow the onscreeen instruction as well.(if any)
Nov 04, 2009 | HP Officejet Pro L7680 All-In-One Printer
I need to change the IP address on my hp color laser jet 2840 coud you help me with that
Most HP printers can be reset to factory defaults (or cold-reset ) by turning the printer off and holding down the Online or Go button while turning the printer back on. The printer control panel display should read "Cold Reset" or "Restoring Factory Settings" or something like these lines. This will remove any IP address that the printer had previously.
When you plug it in, your router should have assigned an ip address automatically. Go into your router and look at the attached devices and it will show you what ip address has been assigned to each device on your network.
Use Web Interface or Manually Assign an IP address NOTE: Network HP Printers allow you to manage them via Internet Explorer. You can enter the IP address that the printer currently has and access its configuration settings. This assumes that the web interface hasn't been locked.
NOTE: We recommend that you install the latest version of Sun's Java software before trying these steps. See this How To: How to Update Sun's Java 2 Runtime Environment Plug-in.
  1. Print the Configuration page if needed. You will be entering the "current" IP Address.
  2. Open Internet Explorer. Delete EVERYTHING from the Address line.
  3. Enter the IP Address in the Address line and press Enter.
  4. You should then connect to the printer. If this fail, go to the next section to assign the IP address manually.
    NOTE: There are 2 basics versions of the web interface. Type 1 is on newer printers. Type 2 is on older models
  5. Type 1: Click the Networking tab.
    Type 2: Click the Administration button. Click the Configuration tab.
  6. Edit the IP address, Subnet Mask, and Gateway as needed.
  7. Do not change any other fields.
  8. Scroll to the bottom and click Apply. Click OK.
  9. Close Internet Explorer.
  10. Restart the Printer. Print the Configuration page to see if number was set.
NOTE: If the above steps do not allow you to assign the IP address via the Wizard, you will need to do it through at the printer itself.
  1. Go to this HP Support Page.
    Configuring TCP/IP through the Front Control Panel
  2. Click the link to your printer model. Highlight these steps.
  3. From the File menu choose Print. In the Page Range section, click Selection. Click Print.
    Note: For the complete printer user guide, go to the HP Printers Support & Troubleshooting page. Locate your specific printer type and model. On its home page, under self-help resources, click the manuals link. Download the printer's User Guide (not the Getting Started Guide). Look for steps to manually configure TCP/IP parameters from the printer control panel.
  4. Follow the steps from the printout to assign the desired IP Address to the printer.
    IP address will be entered at the IP BYTE prompt
    Subnet mask is entered at SM BYTE prompt
    Gateway address is entered at GW BYTE prompt
    Note: The syslog server IP address (LG BYTE 1=) and timeout (TIMEOUT=) do not need configured.
  5. Once the IP Address is entered, restart the Printer. Print the Configuration page to see if number was set.
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | HP LaserJet 2840 Printer
HP Officejet printer
i assume that your printer is connected to a network. if so, it could be that the printer is set to use dhcp for the ip address. and if that's the case, it's better to set the printer to use static ip address since there would come a time that the dhcp server (a router most of the time) would provide another ip addresses to all the devices connected to it. that could be the reason why you are getting a "no connection" message (disconnecting and reconnecting it at times would solve the problem temporarily).
here are the steps on how to set static ip on the printer using a windows computer.(Note: the installation cd can automatically assign a static IP address as long as the printer does not obtain a dynamic (dhcp) address)
- boot up your computer the normal way so it'll get an ip address from your dhcp server
- then turn off your dhcp server so that the printer will not get any ip address via dhcp
- reset the printer to set its factory default configuration (with no dhcp address)
* unplug the printer from the power
* plug the power cord back in while holding in the printer’s
report button (it will try to find a dhcp server; after about three
minutes of no dhcp response, the printer will default to a static ip address of 192.0.0.192
- then print a configuration page to confirm that the ip address of the printer is set to 192.0.0.192
- then press the report button (wait until IP address is 192.0.0.192 before proceeding. if it remains set to 0.0.0.0, check the network cable connection to the printer and to the network is secure. If some other address appears repeat steps 3 and 4 until the default address appears
- you can now start the software installation cd
*during the installtion, follow these steps:
- select the model of the printer that you are using which is hp officejet before clicking on "next"
- then select "do network settings for me, then press "next
*follow the instructions on the remaining install screens
- the software will pick an ip address in the private 169.254.x.x range (not available on the open Internet) and permanently assign it to the printer. it will also set up a static route to that address in the computer’s printer configuration
- turn the dhcp server back on by turning on the dhcp server by
connecting your cable/dsl modem or dhcp to the network. because the hp now has a permanent static ip address, it will
no longer try to use dhcp server to get an address
- install the software on the other computers on the network who will be using the printer. the installation software will discover the hp printer at the 169.254.x.x address, and will add the static IP address in each computer’s printer configuration
Note: if the installation cd will permit you to change th private ip address from 169.24.x.x, it's better to set it on the same range as of the ip address given by your dhcp server (for example your dhcp server provides ip addresses starting from 192.168.1.100-192.168.1.250, set the printer's ip address to 192.168.1.59-below or any ip address that will not compromise any ip addresses that were already being used by your other devices)
hope this'll help you but if you'll have other concerns just ask me.
ciao!
Jun 28, 2008 | Computers & Internet
HP Officejet 6100 e-Printer Wireless Color Printer Logo
4,816 people viewed this question
Seeker5211
Seeker5211
