Question about Dell 922 All-In-One InkJet Printer
Computer cancels printer 922
Computer cancels printer 92When I want to print an article I go to FILE I punch PRINT Then screen comes on to ask for CopiesI push OK A block shows on screen Cancel--and thats it
  • 240 Answers
The article is cpyright protected that's the reason. get the web site grabber software or do the ctrl+prt scr and paste it to paint (built in image editor of windows)
now you can print it
Posted on Mar 13, 2009
I'm trying to print an article from the computer and blank pages keep running through the printer non-stop.
Try canceling the print job, unplug the printer and plug it back in. Copy the article to a Word Doc. and print it from there.
Dec 07, 2010 | HP DeskJet 932c InkJet Printer
Keep printing old docoments / will not print current docoment / printing seem to be strunt
Follow these steps to fix your problem :
Method A :
Press the cancel button or use the cancel menu command on the printer
The most obvious way to cancel a print job is to find a cancel button or a cancel menu command on the printer and to press it. So, if you have not already done this, try this method first.
If this method worked for you, you are finished with this article. However, you may want to read the "Prevention tips" section to avoid this problem in the future.
If your printer does not have these items or if this method did not work for you, try Method B.
Method B:
Turn the printer off and on
Next, try turning the printer off and then on. With certain printer models, this cancels the print job.
If this method did not work for you, turn your printer off, and then try Method C.
Method C:
Use Control Panel to cancel printing
This method is a bit fancier. We will use Control Panel to try to cancel printing.
But what exactly are you trying to do? Are you trying to cancel printing only a single document, or are there other print jobs that you want to cancel? And are all the print job yours, or are there print jobs that other people have sent to the printer? If you have to cancel documents that other people have sent to the printer, you must have Computer Administrator status or you must have permission to cancel the print jobs. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
To cancel one or more print jobs, follow these steps.
1. Click Start, and then click Run.
2. In the Open box, type control printers, and then click OK.
3. Right-click the icon for your printer, and then click Open.
* To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
* To cancel all print jobs, click Cancel All Documents on the Printer menu.
Note If you cancel a print job that you did want to print, make sure that you send the print job to the printer again.
If this method did not work for you, make sure that your printer is turned off, and then try Method D.
Back to the top
Method D: Stop the print spooler and delete all spooled files
If you tried Methods A through C and you were not successful, Method D should work for you. If you came to Method D immediately only to delete a print job, some of what we say here might not apply to you, so please bear with us.
Method D is somewhat more complex and will require a bit more work than the other methods, but don't worry. Method D looks much more difficult than it really is.
First, in case that you don't know how printing works, here is a short explanation. Print jobs are sent to the printer as spooled files. This means that the files are put in a temporary location so that the printer can access a print queue and print jobs at its own speed. If you stop the spooler and its files, most of the time, you both cancel printing and delete the print job.
Note To use this method, you must have Computer Administrator status. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
Step 1: Start Notepad
To stop the print spooler and its files, we will have you create and run a script file that will automatically stop the service. This sounds difficult, but it really isn't. Just follow these steps carefully.
2. In the Open box, type notepad, and then click OK. Notice that a blank Notepad document opens.
Step 2: Copy a command script to Notepad
Now we will have you copy and paste some commands to the Notepad document.
1. Carefully select (highlight) all the following text:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
2. Right-click the text that you selected, and then click Copy.
3. In Notepad, right-click in the blank document, and then click Paste.
4. Carefully select (highlight) all the following text:
C:\DeletePrintJobs.cmd
5. Right-click the text that you selected, and then click Copy.
6. In Notepad, click Save As on the File menu.
7. In the File Name box, right-click, and then click Paste.
8. Click Save.
Step 3: Run the command script file
Now that you have created the command script file, you will run it. To run it, you will copy and paste the name of the command script file in the Run box.
3. Click Start, and then click Run.
4. In the Open box, right-click, and then click Paste.
5. Click OK.
6. Notice that the Command Prompt window opens to run the command script file that you created. Notice also that this window closes automatically when the command script file has finished running. If you do not see the Command Prompt window open, check that you saved the command script file by using the correct name and that you entered the correct command script file name in the Run box.
If this method does not work the first time, or if you cannot print anything after you use this method, restart your computer, and then try again.
Nov 20, 2010 | Lexmark X2500 All-In-One Printer
How do i cancel a print job?
Method A: Press the cancel button or use the cancel menu
loadTOCNode(2, 'resolution');
Method B: Turn the printer off and on
Method C: Use Control Panel to cancel printing
printing.
steps.
    • To cancel individual print jobs, right-click the print job that you want to
    • To cancel all print jobs, click Cancel All
If
future.
files
us.
it really is.
print job.
loadTOCNode(3, 'resolution');
    net stop spooler
    del
    del
    net start spooler
    File menu.
    then click Paste.
    Note Notice that
    this file name differs from most other file names that you might have seen. That
    is because this file is a command script file.
  8. Click Save.
    click Paste.
  5. Click OK.
    Run box.
Note If this method does
Oct 08, 2010 | Pitney Bowes AddressRight DA300 Printer
I would like to cancel the printing once in progress .
Go to Control Panel >>Printer and faxes.
Right click on the printer icon
Click on Clear print queue.
Disconnect the Printer and restart the computer.
Regards
Riztech
Feb 23, 2010 | HP PSC 2175 All-In-One InkJet Printer
FILE IN QUE, WILL NOT PRINT
What kind of printer are you using?
If you are trying to print a PCL PC-XL or PostScript file, go into the printer driver and click the "Print to File" box. Then send the print file to me at don.farr@verizon.net. I can look at the file with some lab tools that I have and see if I can find the failure.
You can cancel the print job that is active in the queue by double clicking on the printer icon (lower right of the screen) Then highlight the print job and select cancel from the menu at the top of the queue box.
Don
Nov 20, 2009 | HP Office Equipment & Supplies
My computer is Windows Vista.Printer ishp officejet4215 all-in-one.I started to print from computer saw article ran 26 pages, so I hit cancel after page 1. Now the printer will not print any new matter...
delete the pending print go to the control panel printer and fax andselect your printer double click there its show pending print deleteall or cancel all and and unplug your printer then connect it restartyour computer then check it.
reply me
mujahed@imsindia.co.in
Sep 26, 2008 | HP Office Equipment & Supplies
Printer not printing
To print a Web page that has frames, follow these steps:
On the File menu, click Print.
Click the Options tab, and click one of the following options:
  • 'As laid out on screen'
  • 'Only the selected frame'
NOTE: Use this option when you want to print only one frame. Click within the frame, to select it for printing, before you start the printing process,
'All frames individually'
Click Print.
This article is from the Microsoft KB Article 255076
Sep 26, 2008 | HP PSC 1210 All-In-One InkJet Printer
When I cancel the printer does not print other items that have been scanned. it gets hung up.
when you print an article on-line. it goes into your printers memory. 10 pages for instance. if you cancel after 5 pages. the printers RAM ( memory ) stores the remaining pages to be printed. the only way to do this, is to cancel printing. then go into printer program. and delete the queue, or pending items, before exiting windows.
hope this explains your dillema.
mike @ Compurepair.
Feb 20, 2008 | HP DeskJet F380 All-In-One Printer
Hp printer will not effectively cancel print
Solution by www.freaksmania.org,
We cannot turn off HP printers when the printing job is going on or it runs out of paper,Paper Jam or Cartridge runs out of Ink or any other reason,ie power failure.
To Cancel printing easily,
1)First plug out the Power Cable(the System tray icon will now disappear).
2)Plug out the USB Data Cable
3)Reconnect the power Cable and turn the printer on.
4)Turn the printer off again and Connect the USB Data Cable.
5)Turn on and then your existing printing Job will be Cancelled.
Solution provided by Team Freaksmania
http://www.freaksmania.org
http://www.freaksmania.org/forum
http://www.freaksmania.org/coderz
http://www.freaksmania.org/graphics
Nov 08, 2007 | HP PSC 1315 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
55 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
