Question about GPX D1816 DVD Player
My GPX D1816 DVD player won't turn on. The little
My GPX D1816 DVD player won't turn on. The little red "standby" light stays lit - Will turn on "green" for only a second then immediately switches back to red. Won't open, won't let me do anything. I've tried restting it by disconnecting everything and setting back up to no avail. It's only 1 yr old and had a useless 90 day warrenty. Help!
  • Anonymous Mar 24, 2009
    Same here.
  • Anonymous Apr 18, 2009
    Yeah i have the same problem except it never goes green.
SOURCE: dvd GPX cannot find the remote code for it
turn on the player
eject the tray
press the number 9 five times
the number 9 should appear at the top
close tray and turn off
your player is now region free
Posted on Jan 08, 2008
ghel1981
  • 34 Answers
SOURCE: my gpx dvd will not power on
hi! the problem is the power supply section,maybe the regulator ic is in low voltage operation.
Posted on Sep 08, 2009
SOURCE: tray of gpx d1816 will not open
disasemble and open manually then change the motor charge belt
Posted on Dec 16, 2009
  • 270 Answers
SOURCE: need a code for a
Here is a link for remote control codes.
http://esupport.sony.com/perl/model-remote.pl?mdl=rmv202
This is the GPX home page: http://www.gpx.com/store/pg/78-GPX-Support.aspx
Strangely enough, there are no remote codes that i can find... Universal remotes have a default fallback where you go thru the entire preprogrammed database to find one that work..
You might want to call the support number on the page and make your inquiry.
good luck and don't forget to vote.
Posted on Oct 12, 2010
BElectric
  • 1140 Answers
SOURCE: I need RCR3273R remote codes
I'm not sure you're going to be able to use that remote for that DVD. Philips / Magnavox remotes don't list codes for GPX equipment. I've managed to find a couple of codes that might work but no guarantees here:
0699 or 0769
Your best hope is to use the auto search function on the remote control. If that doesn't work, then it's unlikely the remote will work for you. Do you still have the instructions for programming the remote?
Please don't give me a low rating if these codes don't work. This is a difficult request and I've searched as many sources as I can find. Thanks.
Posted on Oct 16, 2010
During a thunderstorm, the power flickered off for an instant with the GPX D1816 in standby mode (red light?), but now the standby light is blinking green and it will not work.
If the indicator light is blinking it is probably a faulty power supply. I just fixed mine today. Open the player up by removing the Phillips screws and locate the power supply board - this is the circuit board that connects directly to the incoming 120 Volt power. On this board look closely at the barrel shaped capacitors and note any bulging at the top of these capacitors. My 1000uf 16volt cap was just barely bulging so I decided to replace it with a piece salvaged from an old PC power supply. It is simply a matter of de-soldering the old piece and soldering in a new one. If you must purchase one you could probably get one from Radio Shack or Digi-Key for under a dollar. The replacement should be 1000uf and rated for at least 16volts or more.
Jun 17, 2011 | GPX D1816 DVD Player
My gpx dvd will not power on
Sep 08, 2009 | GPX D1816 DVD Player
GPX DVD player flashing power light
Ihave a GPX portable dvd player that has a broken charging jack on the unit itself. The model is a GPX 808.
Mar 11, 2009 | GPX D1816 DVD Player
Dvd player bad disc message
your dvd head (lens) is bad
(1) it needs to be cleaned by a special fluid puted in the cleaning disc or
(2)it needs to be adjusted because it lit vey low illumination (light) during detecting the details of the disc. and this need a qualified technician ot adjust the variable resistor port attached in the lens assembly unit.
Sep 08, 2008 | GPX D1816 DVD Player
Hooking it up
Easy, just match up color codes from tv to dvd player. If you only have red, yellow and white, they should coincide wih the TV as some TV's dont have the 5 color jacks R/W/G/B/Y inputs. If they do, use the colorstream or "comp" input on the TV
Mar 03, 2008 | GPX D1816 DVD Player
Dvd GPX cannot find the remote code for it
I need to program a universal remote with my GPX DVD player
does anyone know the 3 digit code?
Jan 03, 2008 | GPX D1816 DVD Player
GPX D1816 DVD Player Logo
173 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
