Question about Canon EOS-AE-1 35mm SLR Camera
Lens locked? I loaded the film into my camera and went to take my first photo when I pushed the shutter button the lens locked
  • Mark Van Skiver May 11, 2010
    Lens locked or shutter stayed open?
    Problem Solver:
  • 14 Answers
Every time you change lenses if you are using a wide you have to lock shutter mirror back first
Posted on Mar 13, 2009
Will a nikon n2000 turn on without a lens and film?
The camera should operate perfectly fine without a lens. It should also operate perfectly fine without film (other than for not taking any pictures, of course).
I know this is stupid, but make sure the batteries are inserted in the proper direction. Then make sure the film advance mode selector around the shutter release button is not in the "L" position. L is for Lock, S is for single-frame, and C is for continuous.
If you need a manual you may download a copy here.
Apr 27, 2012 | Nikon N2000 35mm SLR Camera
I just bought new Lomo Fisheye2 camera. I read the instruction first before i will do anything to my camera. Once i read everything, i just follow the instruction step by step. Putting AA battery and...
If your film was TOTALLY blank then it's been bleached due to a processing error. By totally blank, I mean that there are no frame numbers or other film markings on your blank film. Otherwise, you simply have an unexposed film.
First, operate the camera with the camera back open, hold the camera up to a bright light and operate the camera as you look into the back of the lens. If you see a brief bit of light coming through as you operate the shutter then the shutter is admitting light into the camera and so you should have got some kind of an image unless you failed to correctly load the film (very common).
Unfortunately, there's no way to tell unless you try another roll of film. Once the film is loaded, turn the rewind crank gently to take up slack film and take a few pictures; each time you advance the film the rewind crank should turn a little. If it doesn't then the film has not been correctly loaded as the film leader has not engaged onto the take-up spool. If so, open the camera and re-engage the film. If it clearly has engaged, then the take-up spool is failing to rotate when the film is advanced: try taking a few shots and winding on the film with the back open. If the film is not advancing then you have a faulty Lomo. This is extremely common as it is a plastic toy camera with atrocious build quality and materials and is the FishEye is only designed for paltry ten rolls of film lifespan.
A final check for film which has not advanced through the camera is if the rewind is extremely short when the film has finished.
Aug 11, 2010 | Lomo Fisheye 35mm Film Camera
Have a canon T70 camera I picked up off ebay. Loaded it with film and took a pic of my daughter. Aftrer i shoot the pic the camera did not rewind to the next frame i noticed the shutter locked up about...
Completely. The shutter is badly damaged and I'll be very surprised if your fix has permanently cured it, but fingers crossed... If not, there's only one fix. Chuck the camera away (spare shutter assemblies are nearly as rare as hens' teeth/fresh **** ****) and replace it. There are loads of T-series bodies and later Canon EOS triple digit/Rebel models available for free just by asking on FreeCycle and Freegle. Note that the lens mount used on the T-series is different to the Canon Autofocus mount used on later models. Also plenty of all the other makes as well. You may have to wait and to ask a few times, but it's where I still get the majority of my 35mm film camera equipment.
May 21, 2010 | Canon T70 35mm SLR Camera
My Cannon Rebel EOS 35mm film Camera is producing blank Film
If you are getting some photos where only part of the image is visible, then I suspect that they were photos where you used a flash.
Cameras have a specified maximum shutter speed for use with a flash, this is called its 'sync speed'. This is the fastest speed that the camera will need to open the lead shutter and close the trailing shutter in order to expose the entire surface area of the image and have it evenly lit by the flash unit. If you shoot too fast of a speed, then the shutter will only be partly completed its exposure and you'll get a photo with only part of the image showing. The faster the speed past the sync speed, the less the resulting area of the image. Most cameras will have a sync speed of 1/250 or less. I think a lot of the Rebel models are 1/90 - consult your manual.
Nov 23, 2008 | Canon EOS Rebel G 35mm SLR Camera
Canon T70 not taking photos!?!? Help
Oops my bad.
It could be a jammed shutter. If you take the lens out and the film out. Take a few pictures and see if the shutter moves. If there is no movement I would take it into a camera shop and take a look at it. Unless the shutter spring is busted, it could be an easy fix.
Jun 15, 2008 | Canon T70 35mm SLR Camera
Shutter problems
I am having a similar problem with my eos 100QD.
shutter opens, then stays open until I depress the shutter switch again.
Sometimes about half my photos are lost on a roll, but the other photos are fine (as would be expected from how the film is wound). This problem looks like it's caused by the shutter mechanism failing, a common problem with older camera and one that is often more expensive to repair than it is to replace the body.
May 25, 2008 | Canon EOS Rebel GII with 35-80 lens 35mm...
Taking photos
be sure batteries are good. pull up on the rewind knob to open film door. load film ,push down rewind knob. pull enough film to connect to take-up spool. close film door. advance film to counter # 1. look through finder and set meter ( push shutter button to turn on meter ) focus subject and fire shutter repeat to end of film. push rewind button ( bottom of camera ) rewind film.
remove lens by pushing button and turn lens left to remove.
Apr 28, 2008 | Vivitar V3800N 35mm SLR Camera
Pentax ME SLR Camera
Push the small white button down and turn the select to B or Flash mode the shutter should fire at 1/60th sec. in flash mode. As long as you want in B mode. Turn select to A
put lens on and check shutter speed in finder. Rotate F stop on lens and bring shutter speed to over 1/100 sec. push shutter button, it should fire at the speed you selected.
If not check battery cap and contacts in bat. holder, clean with pencil eraser if needed. Be careful with contacts in holder.
If it still locks up remove lens and rotate to F/16 push metal pin in and check operation of diaphragm, it should be smooth and pin return quickly.
If the shutter still locks in auto that's about it---- no parts are available
Dec 30, 2007 | Photography
Blank film
I had the same problem. I think I finally figured it out. My problem was that the Shutter was in lock mode. In the manual book there is a section called "Shutter Lock." How to get it unlocked: While pressing the drive mode button (1), turn the camer on with the function dial (2); the data panel displays the status of the shutter lock. If it says "lock", you will need to do this process again to get it unlocked.
To find out where the buttons are, you will need to look in your manual -- page 53.
Hope this corrects your problem.
Nov 26, 2007 | Konica Minolta Maxxum 50 QD with 28-100...
Canon EOS-AE-1 35mm SLR Camera Logo
136 people viewed this question
Top Canon Photography Experts
old marine
old marine
Are you a Canon Photography Expert? Answer questions, earn points and help others
