Question about Western Digital Computers & Internet
Picture flickering I have a Samsung L19WA monitor which is about 4 yrs old. After it has been on for a couple of hours i get this buzzing noise coming from the monitor & faint lickering lines going up & down the scree. Initially i can stop this by going through the picture mode options i.e txt economy & back to picture mode but after a while this doesn't stop it anymore. Can anyone help?
  • 395 Answers
SOURCE: TV flickers when turned on
this sound like panel or inverters that drive the lamps ( fluorescent lamps that are not replacable they are part of the panel).
Posted on Jan 20, 2008
SOURCE: samsung j700 cant open my picture messages
Try this go to Message settings - Multimedia messages - Multimedia messages Profile - choose your provider.
It worked for me!!
Posted on Feb 08, 2009
  • 4 Answers
SOURCE: LG W1952T LCD monitor power save mode during bootup?
called customer service - see other post for details
Posted on May 12, 2009
Sea Breeze
  • 4655 Answers
SOURCE: fridge/freezer,wbm39 MS. Motor cuts out after about an hr.
You need someone to open the cover on the compressor and examine or replace the start relay, start capacitor and motor windings. One of those 3 are not working properly.Is the model number you gave made for and sold in the UK? Sea Breeze
Posted on May 22, 2009
  • 95 Answers
SOURCE: Green light flickering & Sunset red screen display.
You've got components that have gone bad, probably from age and the normal heat inside a CRT monitor case.
I hate to say it, but it's really not worth fixing. You can usually find a used but working 17" monitor for under 20 bucks.
Posted on Sep 27, 2009
L19wa monitor
It could be your sound cable is detached. it could be the inbuilt amplifier has failed.
Apr 24, 2013 | Computers & Internet
My monitor comes on briefly then the picture flickers and disappears. There is a high pitch buzzing noise as this happens, it then seems to go completely dead after just a couple of seconds.
Worst case will be the arcing in the lamp assemblies.
See pictures here:
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 12, 2011 | Samsung SyncMaster 920NW Monitor
Hi, I have a V7 L19WA - 19" widescreen monitor.
The fact that you can see a faint picture indicates that the monitor is working but the backlight circuit has a problem. The typical failures are blown transistors or bad capacitors. This can be troubleshot if you know how to unsolder and check the components with a meter. Don't know how technical you are, but if you are not, you could take to to an electronic repair service to fix. Hope this helps you.
Jan 24, 2011 | Videoseven L19WA 19" LCD Monitor
Have flat panel hdtv monitor 1080i samsung no picture or sound
Tv has no picture or sound; will go out while watching. The picture will go into a line and sound and picture will go out; shortly after that tv will turn off. Did this last nite and I did not turn back on until this morning, it worked no problem. On for couple of hours and now it's out again. What could be problem and how do I fix myself
Feb 27, 2010 | Televison & Video
Samsung HL-P4663W/HL is making a buzzing noise
Color wheel needs replacement is the most likeliest cause.
Jan 02, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Loud buzzing noise
sounds like a color wheel problem, I can send you a DIY File with pictures if you wish. Contact me at techman32K@ Good Luck!!
Sep 05, 2009 | Samsung HCM5525W 55" Rear Projection...
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Computers & Internet Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
