Question about Westinghouse Electric L2610NW 25.5 in. LCD TV
Westinghouse L2610nw LCD Monitor
Hello, I'm looking for a replacement backup light for it. The monitor will power up but will stay on for a 2 seconds. I can't find anyone with the part number. Also how do you get the bezel cover off. I can't figure out how to take it apart. Where can I find a service manual. Thanks Shawn
  • edlefou May 06, 2009
    I'm looking for the service manual and replacement parts as well.
My tv will not stay on.model lc320em9b. tv will only stay on for about 2 minutes then goes off.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Feb 24, 2015 | Emerson LC320EM9 32 in. LCD HDTV
No power Westinghouse LD4655BX
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Dim screen
- Slow start
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Apr 04, 2014 | Westinghouse Televison & Video
I got the westinghouse LCD monitor model L2140NM several years ago. Yesterday the monitor got hit on the screen and it does not work. How much would it cost to repair? the screen is cracked and needed to...
hi, i'm actually looking for a broken westinghouse l2410nm monitor to fix mine. if you're interested in selling yours shoot me an email at mymaries1806@gmail.com. parts are hard to find for this monitor especially the screen itself. thanks for you consideration.
Sep 04, 2010 | Westinghouse L2410NM 24 in. LCD TV
I have sound but no picture on my Westinghouse LTV-32w3HD. I get a picture for 1 second when I first turn the set on then it just goes black and stays that way.
it can be one of 2 things that the ballast is not strong enough to maintain the lamp on and that why you dont have any picture, because if it was the lamp you would not get any picture at all.
Jul 23, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse LCD TV, tv comes on, picture stays on for 3-4 sec. then goes black, sound is still on, can turn channels....
This sounds like a bad backlight power supply. The heat buildup in the TV case causes parts called capacitors to bulge and short out. This makes the power supply shut off. If you can solder then you should be able to do the repair yourself. Check out our web site at:
www.ccl-la.com/capacitors.htm this page explains what capacitors are and what they look like when they fail. Then open the back of your monitor and look for the bulging parts, replace all that you find and you should be back going again. If you don't want to do the repair yourself we do offer a repair service for $35 plus shipping. You can contact us thru our web site if you have any questions.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Feb 04, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Monitor power light is blinking .but monitor is not displaying anything after 4 hr monitor blinking light is become slow and when restart the monitor is displaying after 4 hr please help me i have a 20.1...
If there is a flashing led on front of the monitor, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact manufacturer to find out a service point.
If you want to repair at your own expenses, just locate any good qualified repairer.
Regards
Oct 15, 2008 | Westinghouse LTV20V2 20 in. EDTV-Ready LCD...
Westinghouse Electric L2610NW 25.5 in. LCD TV Logo
190 people viewed this question
Top Westinghouse Electric Televison & Video Experts
Jerry Kramer
Jerry Kramer
Back2life...
Are you a Westinghouse Electric Televison and Video Expert? Answer questions, earn points and help others
