Question about Mtd Garden
Clutch set up
When i push the clutch in the pully that is ment to be conected donest do anything
You will have to replace the clutch located on the bottom rear of the mower, its very easy.
Posted on Apr 25, 2013
Can i rotate the clutch 90 or 180 degrees on part mt100000
part number doesn't mean anything ,what is it your trying to do ? but to answer your question on all clutches there ment to rotate 360, but on what????????????????????? year make ,model motor size would really help .to define your question
Sep 27, 2014 | Cars & Trucks
How do i remove the belts. the clutch is stuck, and needs replaced?
Just slip a sppon handle between the belt and the pully. Push the sppon and and over, the belt will come off.
Aug 13, 2014 | Washing Machines
I have a Juki ddl 8700 complete with table and clutch motor , everything is pretty together and belt is on but the belt is hitting the wood table on the side before I even push down on the pedal and when I...
Your table sounds like it was cut for a different machine..You might be able to move your motor over to where the belt will come straight down from the handwheel. There is some adjustment that can be made with a wrench on the large nuts that hold the motor up to the table. Good luck.
May 23, 2017 | Juki DDL-8700
How to remove a water pump
Locate water pump.. It's where the bottom radiator hose goes from the radiator. Remove any brackets or parts that are in your way. Remove water pump! Reverse procedure for installation. You have to remove the fan clutch from the water pump shaft and lift the shroud, fan and clutch all out together. remove two bolts in the center radiator support which let the radiator move forward an inch or so, loosen the fan from the clutch for a little more wiggle room to get it out. The shroud will have rubber splash shields hooked to the lower sides too, so be sure to unhook them or you will tear out the holes in the rubber shields.The fan clutch has to come off anyway because it's attached to the water pump. You don't need to remove the fan shroud. Just take out two bolts on the fan clutch and loosen the other two so you can push the clutch back a little (DON'T let the fan clutch fall). Then remove the water pump. It's a little tight, but much easier than removing the fan shroud.the only specialty tool that you will need is the water pumpt "grab" tool and the fan clutch wrench. These two items come together in one kit that you can rent from the Auto Parts store.
The "grab" tool holds the water pumpt pully firmly while you rotate the fan clutch retainer using the fan clutch wrench.
DO NOT attempt to use a break over bar or some other home-grown tool to hold the water pump pully while attempting to break the fan clutch free - you will mess up the heads of the four retainer bolts holding the pully to the water pump face.
this will help.thanks.
Feb 21, 2010 | 2006 GMC Envoy
Water leaking from behind a pully on the block. how or what can i do?
the pully that the coolant is leaking out from sounds like your water pump. with no coolant in the system the temperature gage wont read the correct temperature. replace the water pump and pray that the engine didn't overheat, as to do permanent damage.
May 25, 2009 | 2001 Ford Focus
Cam timing marks wrong?
turns out the two arrows on the cam pullys face up then you can see line type marks by the teeth on either pully faceing each other
Apr 14, 2009 | 1998 Honda Accord
97 ford escort will not start
check all your conections clean with a wire brush sounds like a bad conection. let me know. Phil
Jan 12, 2009 | 1997 Ford Escort
Bogs under light pedal
1st thing to do is run the KOEO test, then run the KOER test and see what shows up.
Aug 04, 2008 | 1988 Ford Mustang
Need to set timing on a 88 subaru 1.8 liter
The crank shaft pully will need removal and the water pump pully as well, also the 2 inspection covers and the center housing cover that they conect with, when removed all of the timing belts will be exposed as well as crank shaft end. I used a screw driver angled wedged and held in on the teeth of the fly-wheel to lock it in position so I could remove the crank shaft pully bolt, (standard lefty-loosey threaded). This would have been easier with the fly-wheel locking tool from subaru, or even just a budy to hold the fly-wheel while i turned the bolt loose at the crank pully. I unbolted the fan and slid it out of the way, I did not even need to unplug it. just be sure battery is not conected. The oil dip-stick tube has one 12 mm bolt at the end of a brace at top of engine. loosen and pull up and forward to remove. the crank shaft bolt-you will need to put back in the bolt only! on the end of the crank shaft so you can rotate the engine manualy with a socket on the crank shaft pully nut, while looking through the hole on the top of rear engine area just above fly wheel. wach fly wheel as it turns, look for 3 lines side by side these are not the timing degree marks they are seperate from them, align them to the little arow on the houseing in front of the 3 little marks. be sure the e-brake is set, trany in nutral so engine can turn freely. inspect the cam shaft pullies, on the surface there are 4 evenly spaced holes, there is one tiny hole that lays between the other holes, this little hole that is the pully mark, it needs to be at the twelve oclock position, there is a small groove on the housing at the twelve oclock position as well. align the two with each other, the little hole with the little notch directly above. do the same for the other side cam pully, same way. loosen the idler pulies for each belt, 2 bolts, move it to its full retracted position, pushing on it with fngers against spring tention, titen one of the nuts so the pully stays retracted/pushed. remove old belts, being carefull not to move the place marks of either of the 2 cam shafts or the engine crank placement. put in the new belts check to see if belt has a direction of dravel and match with engine, mine it did not matter but was told that it may with other belt makers? i don't know about that? but thought it was worth the warning?
once belts are on be sure again that marks all mate with marks on all 3 points crank and fly-wheel, both cam shaft pullies with notchs, now release the tnsion on the idler pullies, and retighten where they fell. check again on the 3 timing points be sure they have not moved again... tireing but worth it. if the have moved off of any mark you must realign it by moveing the pully to the rite spot and putting the belt back on. one tooth off on the drivers side of engine cam can meen up to 16 degrees of timing lose either way of perfect. once aligned, put the center cover back over the crank shaft, bolt on. put on the oil dip stick, put on the water pump pully and crank shaft pully, put on belts. leave the fans out untill all is done, just be sure they are free of obstacles so if they come on later it does no harm to it, you, or anything else. leave off the inspection covers at each cam pully. be sure to un block the fly-wheel. re asemble engine and componants to the installed normal positions as best as posible. re conect battery, be sure all tools are clear, start engine, if it will not run smoothly re set the distributer for timing, if still runs bad, you may have one or both cams off by plus or minus 1-2 teeth one the belts. this was hell... you have to move one side one tooth and start the engine and time it again, if that was not it then you move one tooth in in the oposite direction from the oiginal spot, now 2 teeth the oposite way. if not better put back on the original tooth, and do the same to the other cam one step and start at a time untill you find it to work the best, it may even be off by 1 tooth on the rite and 1- tooth on the left. This was a nite-mare but i finaly found the rite placements.
take 2 aspirin, advil, etc. pre-medicate for the manditory headache. and best of luck..
if you are wondering if the valves and the pistons may have struck, forget it subaru made this 1.8l engine as a none contacting engine, this meens that they can never touch piston to valves even in a cam belt failure.
Jul 21, 2008 | 1984 Subaru Gl
Garden Logo
15 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
