Question about Kenmore Dryers
How to convert my new kenmore 600 natural gas dryer to propane
    Brigadier General:
  • 8,619 Answers
Hi!
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Posted on Mar 13, 2009
3 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: Need to convert from natural gas to propane
Take 3 screws out of bottom side of Z shaped metal part on the back of the dryer's top. Stand in front of dryer and use the palms of your hands to sharply push dryer top back about 2 inches and lift top off. Open door and remove screw at 4 and 8 O'Clock position. Remove control panel (ususally 2 screws and a bunch on retaining plastic parts along the top side) and set on top of dryer or unplug electrical plugs and set aside. Remove screws at top of front panel. Unplug light bulb and door switch. Tilt front panel forward and lift off bottom tabs, then unplug moisure sensor wire at bottom, allowing front panel to be set aside. Remove 4 screws at sides of drum support assembly, lift up and off. Release belt, and remove drum. (easier to do if flat metal part originally right behind control panel is removed first) Use belt as a handle and lift drum out of dryer, allowing access to burner assembly. Change burner orfice and regulator blocker. Re-assemble and test.
Posted on Nov 18, 2011
  • 409 Answers
SOURCE: i DO NOT HAVE NATURAL GAS AVAILAABLE WHERE I LIVE/
You can order an LP conversion kit to change it over to propane. Most kits cost between 30 and 60 dollars, and require you to take the drum out of the dryer to access the gas valve for the change over.
Posted on May 07, 2010
How do you convert to propane a kenmore elite model # 79671622310
You have to get the conversion kit. Mostly the burner gas nozzels has to be changed. Propane has a higher BTU value than natural gas. So the burner nozzle has to be smaller with propane.
You have to have the right nozzle kit for your dryer. Normally the propane nozzle kit comes with the new dryer. It is attached in a plastic seethrough bag and attached somewhere in the back of dryer.
Also you have to adjust the air opening in the burner for propane. Propane need more air than natural gas to burn properly. If you buy the conversion kit or find the conversion kit in the back of your unit, it will clearly give instructions how to do it.
Sep 26, 2014 | Dryers
Converted a kemore from gas to propane now it doesnt get very hot and takes forever to dry
Normally natural gas appliances have a different nozzle size than the propane units. i would check with your propane/gas dealer to make sure.
Mar 02, 2014 | Kenmore Elite HE3 Steam 8674 Dryer
How do i convert gas dryer to propane kenmore elite
kenmore has instructions along with the correct orfices you need to burn propane the only difference between gas and propane orfices is the hole size in the center of the orfices and there is very little difference in size propane is smaller hole because the pressure difference between natural gas low pressure proppane higher pressure
Jan 13, 2013 | GE GFDS350GLWW Dryer
I have a kenmore ellite bbq model 141.16691 propane - I want to convert to natural gas, there is no conversion kit to make it but the natural gas model 141.17691 is exactly the same - just natural gas. If...
Many manufacturers make grills in propane and natural gas, but are not convertible from one gas type to another. The reason being safety. Each grill model, whether it's Natural Gas or Propane is tested and approved for that one specific gas type and that alone. Converting it would put all the responsibility on you, if something was to go wrong.
I suspect in part, the reason you want to convert is so that you want have to refill the propane tank any longer. But, you may want to consider this against convenience. Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Which boils down to lower high end temperatures, longer preheating times and the expense of running an approved gas line to the grill for Natural Gas. Not to mention the cost conversion parts.
But, the decision is yours to make. Thanks for choosing FixYa.
Aug 06, 2011 | Kenmore Elite 644 sq. in. Cooking Area Gas...
I'm converting my natural gas dryer over to LP gas. I've changed the orifice but it is saying to close the regulator. It says the same thing with Natural gas but that doesn't make sense because it isn't...
I know from working on piles of restaurant equipment, that when you change over from natural to propane, you have to change the orifices and the regulator. Most natural gas equipment needs 3.5-4.0" of W.C. (that is, water column) and most propane gas equipment needs 9.0-11.0" W.C. The density and specific gravity of the gases are different. If it is glued so as you can not make any adjustments to the pressure, change the regulator to a propane one. Most natural gas regulators can not be adjusted to the propane pressure needed. Please be careful as working with gas can be dangerous. Natural gas is usually lighter than air and will rise but propane is heavier and will "pool" or "puddle" in low areas and can cause explosions in the right circumstances.
Dec 05, 2017 | Kenmore Dryers
Need book to convert dryer from natural to lp
Thank you for contacting Fixya.com.
Please check the bellow links to have an in-depth knowledge related to your query:-
http://www.ehow.com/how_5321294_convert-dryer-natural-gas-propane.html
http://fixitnow.com/wp/2009/03/13/converting-a-gas-dryer-from-natural-gas-to-propane/
Please get back to us if you have any further query.
Have a nice day.
Dec 02, 2010 | Whirlpool Dryers
I DO NOT HAVE NATURAL GAS AVAILAABLE WHERE I LIVE/
May 07, 2010 | Kenmore 73952 Gas Dryer
Can a clothes dryer be converted from natural gas to propane
Easily, I recommend you get the propane supplier to do it.
Sep 09, 2009 | Kenmore 73952 Gas Dryer
I moved and after hooking up my gas dryer to gas tank it will not heat up....
were you on propane b4 the move or natural gas? A natural gas dryer will not run on propane nor a propane one run on natural gas
Jan 14, 2009 | Kenmore 73932 Gas Dryer
How to convert from LP back to Natural Gas?
I have an old Kenmore dryer that I need to convert from LP to gas. I have the parts but no instructions. Can you please help?
Thank you, Roxanne
Mar 06, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Dryers Logo
969 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
