Question about HP LaserJet color laser printer
Computer crashed yesterday, so rerouted HP4700n printer to a different computer and now a message comes up on the printer when we are printing a job. We have to manually press continue for every piece of stock that goes through the printer, instead of putting a stack of stock in the manual feed tray and letting it print 100 automatically, we have to now push the arrow button, to continue after every sheet. Never had to do that. Our old computer was an XP and this new computer is Vista. Does that make any difference?
    Scholar:
  • 124 Answers
Makes big difference.
Try this go to printer settings see if paper tray selection is set to manual or automatic should be automatic.
Posted on Mar 13, 2009
Error 49.23F9
. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 19, 2014 | HP CP3525N Color LaserJet Printer
Laserjet 2605 49 error
Error 49 is a firmware error. Try following these steps:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 10, 2014 | HP LaserJet 2605dn Printer
Error code 490665 van HP Laserjet 2420
49.XXXXX ERROR
alternates with
To continue turn off then on
A critical firmware error has occurred.
memory.
turn the printer on again.
3. Go to http: www.hp.com/
support/lj2420.
Click Download Drivers and
Software. Check for the
latest firmware image version
at the bottom of the page. If
this firmware image is newer
than the one installed on the
printer and the printer can
receive a firmware update,
download the newer firmware
upgrade. Not all printer
models can receive firmware
upgrades.
4. Try printing a job from a
different software program. If
the job prints, go back to the
first program and try printing a
different file. If the message
appears only with a certain
software program or print job,
contact the software vendor
for assistance.
If the message persists, try this:
1. After performing the actions
listed in the preceding item, if
the message persists when
using different software
programs and attempting
specific print jobs, disconnect
printer to the network or a
computer.
2. Turn the printer off.
3. Remove all memory DIMMs
firmware DIMM in slot J1.)
4. Remove all of the
EIO devices from the printer.
5. Turn the printer on.
6. If the error message
disappears, reinstall
each DIMM and EIO device
individually, making sure to
turn the printer off and then
on again as you install each
device. To replace a DIMM,
see.
7. Replace the DIMM or
EIO device that caused the
error message.
8. Remember to reconnect all of
the cables that connect the
computer.
9. If this error message persists,
10. Replace the formatter
Jul 11, 2011 | HP LaserJet 2420 Printer
49,4c18 error
49.XXXXX ERROR
1. Turn the device off and then on.
2. Try to determine whether the error occurs intermittently, while printing, or when turning on the device.
3. If the error appears while printing, determine whether it occurs when printing from a specific computer, a specific application, or a specific file. If all other computers, applications, or files
can print without the error, then the problem may be only within one print job or computer. Make sure the computer has the most current printer drivers, or use a generic printer driver.
4. Go to www.hp.com/support/LJP3005. Click Download Drivers and Software. Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the
one installed on the device and the device can receive a firmware update, download the newer firmware upgrade.
Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
6. If the message persists, contact your HP Support.
Feb 22, 2011 | HP LaserJet P3005n Printer
Error message 49 on my HP CP 2025 (printer shuts itself off and truns itself back on to see error message 49)
Firmware error:
Nov 22, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
Describe your HP Laserjet 2430tn problem: what
memory.
support/lj2410, www.hp.com/
support/lj2420, or
www.hp.com/support/lj2430.
Software
. Check for the
upgrades.
for assistance.
computer.
see.
error message.
computer.
Mar 24, 2010 | HP LaserJet 2430tn Printer
Error 49.4C2D
3. Try printing a job from a
application or print job, contact
assistance.)
5. Turn the printer off.
6. Remove all memory DIMMs or
firmware DIMM in the lowest
DIMM slot.)
7. Remove all EIO devices from
the printer.
8. Turn the printer on.
9. If the error no longer exists,
install each DIMM and EIO
device one at a time, making sure
to turn the printer off and back on
as you install each device.
10. Replace a DIMM or EIO
device if you determine that it
causes the error.
11. Remember to reconnect all
12. If the error persists, replace
the firmware DIMM.
13. Replace the formatter.
Nov 09, 2009 | HP LaserJet 4100dtn Printer
Computer goes into Hybernate Mode after each print Job.
Try plugging the printer power cable into a different power outlet, preferably an outlet that is not shared. I had a similar problem but in my case, the computer would crash. For some reason, the HL-5250DN demands so much electricity on starting a job that it doesn't play nice with the other equipment.
Mar 04, 2009 | Brother HL 5250DN Laser Printer
49.2F80 Service error
occurred.
Try following these steps -
memory.
support/lj2420.
Software
. Check for the
upgrades.
for assistance.
computer.
see.
error message.
computer.
Jul 18, 2008 | HP LaserJet 2420dn Printer
49.FF05 SERVICE ERROR
occurred.
memory.
support/lj2420, or
Software
. Check for the
upgrades.
for assistance.
computer.
see.
error message.
computer.
Jul 14, 2008 | HP LaserJet 2420 Printer
HP LaserJet color laser printer Logo
35 people viewed this question
Ben Johnson
