Question about Black & Decker GT300 Coffee Maker
Water comes out the bottom of my home cafe GT300
When I push the button to brew on my Black and Decker Home Cafe GT300, it doesn't brew at all, the water comes out the bottom and the cup remains empty.
    Sergeant:
    Champion:
  • 234 Answers
Sounds like the sswitch is bad.
Posted on Mar 13, 2009
Removable filter basket for black and decker cofee maker
Removable Filter Baskets for BLACK & DECKER Coffee Makers at:
ereplacementparts.com
Nov 04, 2009 | Black & Decker Black&Decker Home Cafe...
Blak & Decker Home Cafe GT300 won't stop untill water is gone
With the GT300 you can service the unit. You will need a flat head screwdriver, preferably a low quality one, that will need to have a small spot filed out in the very middle of the flat head area to remove a few special screws that are common to these appliances.Luckily it is very easy to modify a flat head screw driver to remove the area necessary to make the tool work well enough to remove the special screws. After that, you will need a phillips screw driver as well. Remove all the screws, some are hidden underneath the plastic grip pads on the bottom as well. You will observer a tin can heater, and a priming pump (white) and an invensys ******** pump (red). The invensys pump (CP1, CL1) is very easy to service and this is what you will find the problem is 99% of the time. Just unscrew the plastic ends (you may need a wrench) on the invensys pump. It will come apart, be careful to keep all the pieces, they will spring apart like a jack in the box if you are not careful. Get all the pump pieces where they are moving again and then put the pump back together. There should be two metal rings with a plastic ring between them. You may have to plug and unplug the unit a few times and get out any excess water before getting the system primed and running again.
Jul 25, 2009 | Black & Decker GT300 Coffee Maker
My black and decker home cafe will not dispense water
I work for Black and Decker customer support. Our customer service phone number is 1-800-231-9786.
If the unit won't dispense the coffee, it needs to be replaced. Unfortunately, the unit can't be repaired. The unit comes with a one year warranty from the date of purchase. Please call the number above so that we can determine your warranty eligibility and help you in any way that we can.
While this doesn't actually solve your problem, I hope the information allows you to make an informed decision as to how to proceed from here. Please let me know if I can be of further assistance.
Nov 16, 2008 | Black & Decker Black&Decker Home Cafe...
Black and Decker whiper snipper runs for a few seconds then stops
I work for Black and Decker customer support. Our customer service phone number is 1-800-231.9786.
If what you have is a Home Cafe coffee maker and it stops after a few seconds, the unit needs to be replaced. Unfortunately, the unit can't be repaired. The product comes with a one year warranty that begins on the date of purchase. If you purchased or received the unit within the last twelve months, please call the number above for our warranty procedure.
While this doesn't solve your problem, I hope that the information will allow you to make an informed decision as to how to proceed. Please let me know if I can be of further assistance.
Aug 13, 2008 | Black & Decker Black&Decker Home Cafe...
7oz and 9 oz blinking
Unplug and then plug the machine back in. The stop light should be blinking.
Hold down the lid release lever until the lid opens up. Close the lid enough so that the sensor thinks the lid is closed, but not enough so that it actually latches closed. You'll hear a "click" where the sensor engages before the latch takes hold. Hold the lid in that position until the red stop light stops blinking, then close the lid all the way until it latches.
Press the clean button (with water in the tank) and it should begin working properly again. Good luck!
Apr 16, 2008 | Black & Decker GT300 Coffee Maker
Black&decker home cafe
If the unit is failing to make coffee on a consistent basis, it needs to be replaced. Unfortunately, the unit can't be repaired. The unit comes with a one year warranty from the date of purchase. Please call the number above so that we can determine your warranty eligibility.
Nov 26, 2007 | Black & Decker Black&Decker Home Cafe...
Home Cafe GT300 Black and Decker- won't work, brand new
I have the GT300, and it also started having problems with the 14oz and cream loight s blinking. After trying the unplug and replug thing I gave up, I came back to it the next day and it started working again so I just kept running it over and over until I got it to fail again when I opened the lid and put a pod in to make a cup of coffee. It wouldn't work again so I unplugged it and set it back up and held my hand on the lid and applied a little pressure and it started working again, so far with a little preesure applied it still works. My guess is there is a switch that dosen't make as well as it should, you don't have to hold the lid down during the entire brewing cycle just long enough for it to get started. Good Luck
May 07, 2007 | Black & Decker GT300 Coffee Maker
Black & Decker GT300 Coffee Maker Logo
221 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Henry  Thomas
Henry Thomas
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
