Question about Euro-Pro 8260 Mechanical Sewing Machine
Can't figure out how to thread the needle
It's been awhile since Ive used a sewing machine and Ive never used this one. and i can't figure out how to thread the needle.
  • 8,197 Answers
Here is the manual.
http://www.euro-pro.com/europro/manuals/8260.pdf
Good Luck and please Rate FixYa!
Posted on Mar 13, 2009
My machine keeps skipping stitches. I have had it werviced three times in the last n6 months, by two different repairmen, and it works for awhile, then starts backnup again. Any suggestions?
Usually, the first thing to try when a machine skips stitches is install a brand new needle. Also, be sure you are using the right type of needle for the fabric and thread you are using, ie ball point needle for knits, sharp needle for wovens, leather needle for thick fabrics/denim/leather... Needles do wear out with use, so changing needles frequently could be helpful. (Needles are the least expensive solution to most sewing problems!)
You can also try removing the upper thread. ALWAYS raise the presser foot and rethread from the beginning. Verify the thread path is correct.
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
If the problem continues, it could very well be something within your machine that has not been appropriately addressed by the technicians.
Dec 29, 2016 | Sewing Machines
My thread keeps breaking, Ive checked and changed my needle, re-threaded bobbin and upper but every time I try to sew the upper thread breaks.
Have you tried loosening the upper tension? Remove the upper thread, RAISE the presser foot and rethread from the beginning (make sure it follows the correct thread pathway). Sometimes the upper thread jumps out of a thread guide or wraps around something. Or try a different brand of thread? Avoid old or bargain bin threads--use good quality thread. Could also be the incorrect needle for the thread/fabric, ie thread too large for the needle eye.
Sewing Machine Thread Keeps Breaking
NMSU Checklist of Common Machine Troubles
Why Does My Thread Keep Breaking While Sew
Apr 03, 2016 | Sewing Machines
Top thread will not work ive tryed changing needles is there a special needle to use
the needle used depends on the fabric being sewed. the needle must move thru the needles eye smoothly.
make sure the machine is threaded correctly, using every thread guide
make sure also the bobbin is wound correctly and that the bobbin is inserted into the bobbin case correctly, if the bobbin is turned the wrong way the machine wil not sew
here is a link for a free manual, if you don't have one
http://www.singerco.com/uploads/download/756_white-3300-emb-x.pdf
Sep 07, 2013 | White Sewing W3300 Computerized Sewing...
Riccar sewing machine tension
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Aug 05, 2013 | Sewing Machines
Singer7462 timing adjustment
try these sites
youtube
fixsewingmachine.com
Mar 04, 2012 | Singer 7462 Mechanical Sewing Machine
Iam new to sewing. Ive never had a Bernia 930 machine. Iam having problems creating stitches. The top thread is threaded correctly and the bobbin is in correctly. Iam able to bring bottom thread up but...
have you try changing the needle
sometimes the needle & thread are not compatable--here's how to check
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
& make sure the threads are always pulled to the back behind the needle area
happy sewing
Oct 12, 2010 | Bernina Sewing Machines
Top thread goes for awhile and then breaks. Alsoo
Try a fresh needle and be sure the flat side of the needle shaft is facing the back of the machine.
Thread the machine with the presser foot in the up position.
Make sure the bobbin is inserted into the case so the thread is feeding from the bobbin spool in the correct direction and through the proper guides.
Hold onto the thread end at the needle and hand-walk the needle down into the needle plate and back up, bringing the bobbin thread with it.
Take both thread ends under the presser foot and to the back of the machine.
Feb 25, 2010 | Singer 8280 Mechanical Sewing Machine
Cannot get the bobbin thread to come up with the top thread
1. Make sure the needle is up in the machine all the way.
2. Make sure the flat side of the needle is facing the rear of the machine
3. Only turn the handwheel on the side of the machine towards you, never away from you.
4.Double check your threading of the top of the machine.
5. Also make sure your using the proper needle, your machine takes the most common needle on the market but some look like it and are shorter or longer and wont work properly. Also make sure your not buying needles for a singer serger.
Oct 07, 2009 | Euro-Pro 473
Tons of loops on bottom
Check your threading.
Berhaps your thread is not between the discs.
Mar 09, 2007 | Kenmore 15516 Mechanical Sewing Machine
Euro-Pro 8260 Mechanical Sewing Machine Logo
215 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
