Question about Electrolux 36" Electric Hybrid Induction Cooktop - Black
Electrolux E 95 code
Not working E 95 code
  • Official Brand Answer
  • 4,342 Answers
Hello Robert - Typically, error code E95 indicates a power voltage miscommunication to the main components of the unit. You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then I would recommend contacting a professional to proceed further.
Posted on Apr 26, 2013
Hi , our cooktop started to show E99 code. What E99 means ? It occasionally starts to work again - but after day or two E99 appears again. Power off / on helped only few times
Hello Cecilia, thank you for your inquiry! If you are receiving an error code E99 on your Electrolux Induction Cook-top, it typically relates to a communication failure. If switching your breaker off and on did not resolve your issue, you may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you. Thanks, JK
Oct 16, 2015 | Electrolux Cooktops
Electrolux Cooktop Hybrid error E07- sometimes, cooking gets interrupted with E07 code and shuts off the panel. On next turn on, usually works okay. Could you describe me the error code? Thanks!
I appreciate your post, friend!
I see that you are having an issue with your Electrolux cooktop displaying a "E07" and shutting off. An "E07" code stands for an issue with your key sensor timer and this could be a potential problem with your right, left, or center board. This may not be a simple DIY job and I would highly recommend having a professional technician come out to diagnosis your cooktop. The technician will have the appropriate tools needed for properly diagnosing your cooktop. This step will help you to avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
Feb 19, 2015 | Electrolux Cooktops
I have a glass cooktop Electrolux which is only 2 years. stopped functioning with a E-11 error code and cannot ulock. what can Ido?
Hello Gloria Padilla, thank you for your post!
I understand that your Electrolux cooktop is displaying an error code "E-11" and will not allow you to operate. The "E-11" error code stands for key sensor in cook place four. This could mean a possible issue with your flex cable, right board, or left board. I see you have completed a reset on your cooktop, at this point I would recommend having a professional technician for a proper diagnosis to be completed. I hope this information is helpful. -Matt
Dec 29, 2014 | Electrolux Cooktops
Electralux Surface Cooktop, with code---E----40
Hi Linda Wallman, thanks for your post!
I see that your Electrolux cooktop is displaying an "E40" error code. Typically, the "E40" stands for no communications, shorted bus. This could be an internal communication error with your left control board, relay board, or filter board. I would recommend getting a technician out to your home for proper diagnosis and repair. I hope this is helpful. -Matt
Oct 20, 2014 | Electrolux Cooktops
How to fix error code 15 on Electrolux electric range.
It is likely you may have used self-clean feature at some stage before this happened. The error is something to do with oven overheating. This is common when you use self-clean. The solution may be to reset the thermal fuse.
See this thread on internet for possible solution. Hope it helps.
F15 Code on Electrolux EW30DS65GS5 The Kitchen Appliance Repair Forum
Sep 28, 2014 | Electrolux Cooktops
Electrolux e21
Thank you for your post, friend!
I understand that your Electrolux cooktop is flashing an "E21" error code. Based off the information I was able to look up it sounds like a possible issue within the left board. I would suggest seeking assistance from a technician for proper repair because some of these intricate parts do require precision and patience. Therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. -Matt
Sep 28, 2014 | Electrolux 30" Induction Cooktop
Error code 32
Same unit, error 32. Replaced capacitors that were bulging on relay board. Work for a bit now same error message. Read somewhere else that they capacitors on filter board likely went as well. Where is the filter board located? I am guessing under the induction elements because I can't imagine it would be anywhere else. Can someone please assist in telling me how to access that board? I would greatly appreciate it
Dec 21, 2013 | Electrolux Cooktops
Error message on my electrolux INDUCTION STOVE TOP
Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
Oct 30, 2012 | Electrolux ICON Designer Series E36IC80ISS...
Electrolux Induction Cooktop E36IC75FSS Error Code 41
Hi Sue -- when you switched the breaker, how long did you leave it off before switching it back on? Generally, it's a good idea to leave the breaker off (or unplug the unit) for a full 30 seconds before switching the unit back on. If you did have it off for 30 seconds and the error code came on after that point, then it may possibly be a relay isse. That will more than likely require a visit from an authorized servicer to properly diagnose the cooktop. Hopefully the 30-second test prevails and the issue is resolved. Best of luck!
Aug 27, 2012 | Electrolux 37 in. Designer Series...
Electrolux 36" Electric Hybrid Induction Cooktop - Black Logo
959 people viewed this question
Top Electrolux Cooktops Experts
rugby prop
Paul Carew
Are you an Electrolux Cooktop Expert? Answer questions, earn points and help others
