Question about Radio Communications
The blue light stays on ond the head set does not respond except that it connects to the phone bluetooth indicator.How do I rectify problem?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 104 Answers
What is the brand and model of your headset?
Posted on Apr 29, 2013
Sir,
my name is dhani I've samsung hm1700bluetooth fast 1 year working good but now there is no voice coming as well as music also our service center told me company will not take service due to the serevice date is over what todo kl help me how to rectify this problem give suggesion
Regards,
Dhani
Posted on May 07, 2013
  • sheqschequa May 14, 2013
    Thanks for the response. Sorry if I just responded. I've been so busy this past few days and I wasn't able to check my email. Anyway, have you tried charging your headset until it's fully charged? If so, try to reset your bluetooth headset. To do this, follow this procedure from the manual: In Pairing mode, press and hold both Volume buttons and Talk button at the same time for 3 seconds. The headset will turn on automatically. When you reset the headset, all connection settings in the headset will be deleted and the connection with your phone will be lost. In order to use the headset, you will have to pair it again.
SOURCE: Motorola Bluetooth HS850 Pairing Mode
was soooo helpful just make sure u do flip it open immediately after, thats were i messed up... Thk
Posted on May 18, 2008
SOURCE: My motorola bluetooth h270 appears to be frozen.
Put it on charging once again. While it is charging, switch it off. It should go off now. Now, remove from charging and switch it back on. Hope it works for you
Posted on Jul 30, 2009
  • 33 Answers
SOURCE: connecting bluetooth head set
>Paraphrasing from the manual:
>1. Turn off headset.
>2. Press & hold the Multi-function button for 8 seconds, until >the lower half is lit up blue (not flashing).***THIS IS >IMPORTANT! KEEP HOLDING IT IN UNTIL IT STOPS >FLASHING! The whole thing will be lit up blue, but the lower >half will be brighter.
>3. Set your 'phone to discover bluetooth devices.
>4. Your 'phone will find the "Samsung WEP410" headset, & >ask if you want to pair with it. Confirm by pressing "Yes" or >"OK".
>5. Enter passkey or PIN "0000" (4 zeros), then "Yes" or "OK".
Posted on Apr 05, 2009
SOURCE: help! I've no idea!
fold the boom up, push and hold down the central button until it turns violet, open the boom and then let up on the button. The central button should stay violet without blinking. Then go through the pairing routine on your phone.
Posted on Mar 04, 2007
SOURCE: Bluetooth problem
I have an lg sprint muziq and I cant get my blue tooth headset connected. The phone can't read or see the blue tooth head set
Posted on Jul 04, 2008
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
How to pair phone to samsung bluetooth headset wep301? I do not have my user guide.
Bluetooth Headset
Pairing Instructions
1. When you turn on your Samsung Bluetooth
headset for the first time, it proceeds into pairing
mode immediately.
2. If you have paired the headset with other
Bluetooth devices, make sure that the headset
is off. Press and hold the Multi-Function button
until the blue indicator light stays solid blue after
blinking.
3. Set your Bluetooth phone to discover the headset
by following your phone's guide. Typically, the
steps involve going to a 'Setting', 'Connection',
or 'Bluetooth' menu on your phone and then
selecting the option to discover Bluetooth devices.
4. Your phone will find the Samsung headset and
ask if you want to pair with it. Confirm this by
pressing the Yes or OK key.
5. Enter a passkey or PIN, 0000 (4 zeros), then
press the Yes or OK key.
6. If pairing was successful, the indicator light will
flash in blue 10 times rapidly before going to
flashing every 3 seconds. If unsuccessful, the
light remains on, and you will need to re-attempt
pairing.
7. When you turn on your headset after pairing
with the phone, the headset is automatically
connected to the phone.
8. When you turn on your phone after pairing with
the headset, the phone is connected to the
headset by pressing the Multi-Function button.
Jun 01, 2011 | Samsung SGH-U600 Cellular Phone
How do I setup wep301 headset to a simple at&t phone
Follow the steps to connect your WEP 301 bluetooth headset to phone.
1.When you turn on your Samsung Bluetooth
mode immediately.
blinking.
by following your phone’s guide. Typically, the
steps involve going to a ‘Setting’, ‘Connection’,
or ‘Bluetooth’ menu on your phone and then
pairing.
Thank You
Aug 14, 2010 | Samsung Cell Phones
Head set not pairing with sony erricson k750i
The solution for paring the explorer 240 is found in the bottom of the product page for the embedded link on the User Guide Link. I have also provided the instructions below. I hope this helps
How to Pair Your Phone With Your Headset for the First Time
1 Turn on the Bluetooth feature on your phone.
For most phones, select Settings/Tools > Connections >
Bluetooth > On. See your phone’s user guide for more information.
2 Turn the headset on.
Turn on your headset by sliding the Power Switch toward the microphone. Wait until the indicator light flashes red then blue.
If you don’t see the red then blue flashes, turn the headset off, then turn it on again. Press and hold the Call Control button until you see the red then blue flashes that indicate pairing mode status.
3 Set your Bluetooth phone to ‘discover’ to locate the headset.
This usually involves going to ‘setup’, ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add a device’.
4 Once available headsets are listed, select your headset (for example 2XXPlantronics or 3XXPlantronics). If prompted for a passkey, enter 0000.
When pairing is successful, the indicator on your headset flashes blue. Your phone will also confirm when pairing is complete.
John M
May 06, 2010 | Plantronics Explorer 220 Bluetooth Headset...
I need help pairing my motorola h500 to motorola i580 phone
  1. Make sure your phone's bluetooth is on.
  2. Go to MENU > SETTINGS > CONNECTION > BLUETOOTH LINK > SETUP.
  3. Scroll to power then press change.
  4. Scroll to ON the press select to turn on the bluetooth feature. Bluetooth feature remains ON until it is turned off.
  5. With the headset power off, press and hold the CALL button for 6-10 seconds until the blue light indicator turns on and remains steadily lit. If it does not stay lit, turn off the headset. To turn it off, press and hold CALL button until blue light stops.
  6. While holding the CALL button on the headset, on your phone select MENU > SETTINGS > CONNECTION > BLUETOOTH LINK > HANDS-FREE > LOOK FOR DEVICES. The phone lists all bluetooth devices it finds.
  7. Select Motorola H500.
  8. Press OK or YES to pair the headset with your phone.
  9. Enter the passkey 0000.
  10. Press OK.
Oct 08, 2009 | Motorola Mobility H500 Headset
How do i place a h555 motorola bluetooyh in pairing mode
Step A - ENSURE HEADSET IS IN PAIRING
MODE
Power on headset by sliding the Call button
towards the microphone to initiate easy
pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate
headset is in pairing mode.
Step B - SET YOUR PHONE TO LOOK FOR
YOUR HEADSET
On your Motorola phone, press (Menu) >
Settings > Connection > Bluetooth Link >
Handsfree > Look for Devices.
The phone lists Bluetooth devices it finds.
Select Motorola H555.
Select OK or Yes to pair your headset with
your phone.
Enter the passkey: 0000
Select OK.
When your headset successfully pairs and
connects with your phone, the indicator light
changes from steadily lit to flashing blue.
Troubleshooting: Make sure that any devices previously pairedwith the headset are turned off. If the indicator
light is not steadily lit in blue, turn off both the
other device and headset, wait 10 seconds,
then turn headset back on. Wait for the indicator
light to become steadily lit in blue, indicating
the headset is now in pairing mode.
User Manual
Aug 22, 2009 | Motorola Mobility Bluetooth Hands Free...
How can i pair my samsung bluetooth headset to
turn off the head set then press and hold the on button until the blue light stays solid blue.
search for device on your new phone and add device code is 0000
Mar 19, 2009 | Samsung WEP500 Wireless Headset
Plantronics explorer 330
I just figured out how to reset the 3XXPlatronics 330. The guest might of of made it a little confusing for some:
1) TURN OFF bluetooth head set by holding the volume control button for about a few seconds until it flashes blue.
2) Make sure your phone's bluetooth is on and on discover mode.
3) Turn on the blue tooth head set (NOTE: HOLD DOWN THE VOLUME BUTTON UNTIL IT FLASHES BLUE AND RED)
4) Lastly, go into your search menu to find new bluetooth devices. The device should show up as "3XXPlantronics" (PASSKEY IS 0000).
P.S. Keep in mind this worked for me, but if it doesn't work feel free to email me at; cispy006@yahoo.com
Mar 15, 2008 | Plantronics Explorer 330 Headset
Resetting a paired headset
turn the head set off.
Turn on your phone's blue tooth
turn head set back on and proceed to HOLD the button down until your phone discovers it. Then enter the CODE 0-0-0-0.
Feb 21, 2008 | Samsung WEP410 Bluetooth Headset Wireless...
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Radio Communications Logo
1,727 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
