Question about Car Audio & Video
Remove door cover
How do i remove the door cover to replace speakers on 2001 dodge ram with manual windows the handle that rolls the window down is attached and i don't know how to get it off
Try pulling out the rolling handle really hard or look to see if behind the handle has some pin and remove it ( don't loose it u'll need to put it back later to keep the handle in position)
Posted on Jun 05, 2009
    Problem Solver:
  • 4 Answers
Hi
You might find that the handle for the winder is conected by a circlip. If you get a screwdriver and push up on it, it should come off. Make sure you get it back on though or the handle will keep coming off.
Thanks jeremy
Posted on Mar 13, 2009
How to remove rear door glass?
Remove Inner door panel, usually, the door handle has a screw, behind the lever, on the inside, and may be covered by a plastic cover, take the screw out, and move the handle forward, then take, the side on clip, off, the rod.
remove, any inside door handles, screw to door, and then starting from the bottom, pull the panel towards you, unsnapping, the plastic clipps, holding them on the door.
Roll window down, till you can see the 2 nuts, holding the bottom of the window.
Now, run the window mechanism, all the way down, away from window, while holding window.
Now it is loose, twist the window, inside the door, front down, back up, so, it comes out, the top
Put back, same way
May 21, 2014 | 2001 Toyota Highlander
Dodge Neon Passenger Window off track
You have to remove the inner door panel, End then put it back into the track,
Nov 04, 2012 | 2003 Dodge Neon
2000 neon manual windows don't roll down, crank turns but window doesn't move
you need a window regulator you need to take the door apart to be sure
Jan 25, 2012 | Dodge Cars & Trucks
The driver side window in my 1988 ford ranger will not roll down. Its manual. What's the problem and how should I fix it???
Remove the clips in the inside of the window handle,also clips on door handle.Look for any screws holding the door panel on, then take a screwdriver and pry the door panel away from the door. re install the window handle,and try rolling the window down. You will probably see what is stopping it. If it looks like the window regulator is worn out, check the local junk yards for a replacement.
Jul 16, 2011 | 1988 Ford Ranger
Remove door panel with manual crank window
Pull of handle. Remove door lock, remove all visible screws, then gently pry the panel loose, then pull up and off.
Jul 28, 2010 | 2001 Dodge Ram 2500 Truck
I can roll the window down with the passenger side switch but to roll it up i have to use the master on the drivers side. it a 2002 dodge ram 2500
I am assuming that the switch from the drivers side will roll the window down and up for all windows, so this is going to be a worn out or defective window switch in the passenger door. These are quite easy to change, and can get the part from the dealer for usually at or around $50.
The armrest cover will pop up where the switch is with a little effort, flip the cover over and remove the plug to the switch. The switch has usually 4 tabs that will need to be pried gently back and the switch housing will release. Install the new switch housing, attach wire plugs, and it's plug and play! This will correct the problem.
Window and lock switches use a small plastic piece that presses down on metal tabs. These plastic parts wear out, or I have even seen them get hot and melt if pressed and held down by kids playing with the window buttons.
Hope this helps, let me know.
Chip
Apr 10, 2010 | 2001 Dodge Ram 2500 Truck
How to remove the inside door panel from a dodge 2005 2500 pick up
FRONT DOOR TRIM PANEL - REMOVAL
Release door latch and open door.
Roll window down.
Remove window crank Window Crank - Typical , if equipped.
Remove screws attaching trim panel to door Door Trim Panel and Trim Panel Screw
CAUTION: Do not forcibly pull trim panel from door, damage to trim panel may occur.
Simultaneously lift upward and outward to release retainer steps from inner door panel Trim Panel Retainer
Disengage inside handle linkage rod from inside handle.
Disconnect speaker harness wire connector Speaker And Power Mirror Connector
Disengage power mirror wire connector, if equipped (driver's side only) Speaker And Power Mirror Connector
Disengage clips attaching power window/lock switch panel to door trim panel. Disengage wire connector from switch panel, if equipped Power Door Lock/Window Connector
Separate door trim panel from vehicle.
INSTALLATION
Position trim panel at door.
Engage wire connector for window/lock switch panel, if equipped. Engage clips attaching power window/lock switch panel to door trim panel.
Engage power mirror wire connector, if equipped.
Connect speaker harness wire connector.
Engage inside handle linkage rod to inside handle.
Align trim panel retainer steps with inner door panel and slide trim panel into place.
Install screws attaching trim panel to door.
Install window crank, if equipped.
Hope helped with this; remember rated this help. Good luck.
Nov 12, 2009 | 2005 Dodge Ram 2500 Truck
Remove inside panel pass.side door of 2001 Dodge gr.caravan sport
1, Disconnect the able from negative terminal of the battery.
2. Pry the courtesy light from the door trim and disconnect the wire connector..
3. Remove all door trim panel retaining screws and door pull armrest assemblies.
4. Remove the door switch panel and the control switch panel and the control switch assembly.
5. On models with memory seats/mirrors, use small-flat bladed pry tool to remove and disconnect the wire.
6. Grasp the trim panel lift up and pull out to detach it from the door. Disconnect the inner door handle lock rod from the handle. Unplug any electrical connectors remaining and remove the door panel.
7. To install, connect the wire harness connectors and place the panel in position in the door. Press the trim panel down into place until the hooks are seated.
8. Install the armrest/door pulls, the courtesy light and the window switch'
9. Reconnect the battery
Also. You will need star pattern drivers to remove the window and motor from your door. If you have all the equipment it should only take you 1 hour.
Jan 15, 2009 | 2000 Dodge Caravan
Manual window won't roll up
so is the right rear door ??
if so here are some instructions.
  1. If applicable, remove the regulator handle by pulling the clip out with a wire hook.
  2. Remove the inside door handle and disconnect the latch rod.
  3. Remove the screws and detach the clips attaching the door panel (see trim pad remover.
  4. Disconnect the power window and courtesy light harnesses.
  5. Remove the door panel bracket and carefully remove the plastic cover
  6. Remove the screw attaching the door lock crank. Disconnect the latch rod from the latch side.
if you have an email address i can send some images on how to do it.
hope this helps
Jun 07, 2008 | 1991 Honda Accord
Removing rear door panel
Remove the door window regulator handle and then remove clip using a piece of cloth (Manual type only)
Remove the rear door inside handle housing.
Remove the mounting screws (3EA) from the trim fasteners and the door trim panel to pry off. Disconnect the connector.
Insert a trim panel remover between the trim fasteners and the door trim panel to pry off. Disconnect the connector.
Remove the door pull handle mounting bracket and door inside handle.
May 29, 2008 | 2001 Hyundai Sonata
Car Audio & Video Logo
46 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
