Question about Garden
Can cold water pressure washer take up gum? - Garden
You can try a small amount of WD-40 and the gum will start to come apart.
Posted on Apr 25, 2013
My pressure washer has lost pressure and has water coming out of a small outlet i assume to be a pressude release device;can this be fixed or replaced ?
that's probably the unloader valve all it might need is a quick dissasle to see whats gumming up the works , as all I was able to find for sale for that model here was a new gun and the soap injector for about sixty bucks each , you might have to look around in the Uk for one as that's were there most popular
Mar 18, 2016 | Karcher Garden
Washer does not fill with water at startup
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
May 12, 2015 | Washing Machines
Why water can't come out from the tube on panasonic na f90s3 even i turn on the water
Cold water not coming out again
May 11, 2015 | Washing Machines
I have a maytag bravos x mct washer. It will not pump cold water the hot water comes out not the cold any ideas?
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
By the way my advice is free cuz God is good!
May 08, 2015 | Maytag Washing Machines
Pressure washing with cold water
I have a "dirt blaster attachement" for my pressure washer that rotates at high speed. If you have that part, it should work fine.
Apr 25, 2013 | Garden
Water pressure for Washer (rinse only)
you nead to turn off both cold and hot water.next you nead to remove cold water hose from washer.remove screen and clean it and replace it.hookup cold water hose to washer and turn water back on.you should have better pressure.your rince cycle is cold water.
Nov 18, 2009 | Kitchen Ranges
The water does not flow to the softener reservoir of my maytag neptune tl.
most likely problem is to low of cold water pressure. if you set it to cold/cold, and the water coming in doesn't have much pressure, the screen on the cold water valve could be plugged. turn the water off to the washer, remove the water hoses from the washer inlet valve in the back of the washer. look in the inlet valve, there is a screen. if it has sand and debris, clean the screen, hook hoses back up, and check the pressure on cold again. if it has more pressure, this should allow water into the softener reservoir. Also- make sure you take the softener reservoir out, and clean both pieces. make sure the syphon holes are clear. hope this helps. shane
Aug 22, 2009 | Maytag Neptune Washer
Pressure washer has no pressure coming out
I think yor hot water softened one of the pressure seals and has allowed it to buccle. This will drop the pressure away from the pump. It will require new seals to be fitted and the cost is close to $200.
Aug 14, 2009 | Garden
Kenmore HE3 Front Load Washer
Remove the dipenser and feel down inside the hole. You will probably feel a detergent build up in the cavity. If so clean this out and rinse with hot water. This problem is becoming more common since people are washing more in cold water to save electricty. Some detergents and fabric softeners will not disolve in cold and it "gums" up the works. Post back to let me know what you find.
Oct 08, 2007 | Kenmore Elite 45986 Front Load Washer
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
