How do I get to the bulb to change it
I have removed the back cover but how do I get to the bulb
    Top Expert:
  • Televison & ... Master
  • 74,377 Answers
What is the brand name to your PTV? Provide more details please. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window. Lamp replacement proceedings to many models of PTVs are given in detail with illustrations. http://electronicshelponline.blogspot.com/
Posted on Apr 25, 2013
Change a light bulb in Bernina 1008 sewing machinge
If you still have original Acessories there should have been a grey or brown cone shaped rubber gripper that could be slid up on bulb to assist in turning it If not remove the side cover, then back cover to access the bulb. Some 1008's have push in bulb others screw in so be careful not to break bulb as you remove it
push in bulbs must be pushe in and rotated 45 degrees counter clockwise to remove. Of course screw in bulbs just rotated counter clockwise to remove
Aug 23, 2014 | Bernina Sewing Machines
How to change the inside bulb in a ge spacemaker microwave that has a top vent fan
My Spacesaver bulb replaces from the top. You have to remove 2 screws that hold the upper vent cover. W/ cover off you will find a phillips head screw about the center that holds the bulb cover. Remove the cover screw & lift up & remove the cover, then replace the bulb, the cover & screw then put the vent cover & it's 2 screws back. There may be some variance but they are all similar.
Mar 16, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
How hard is it to change a fog light bulb on a 2005 Subaru Forester? Can anyone do it?
Front Fog Light Assembly
REMOVAL
  1. Disconnect the ground cable from battery.
105919447
  1. Remove the two clips and lower mudguard on side that bulb is being changed.
  2. Disconnect the harness connector from bulb on back of fog lamp.
105919448
Front Fog Light Bulb
REMOVAL
1. Locate back cover on fog lamp assembly where bulb is located inside.
105919462
  1. Remove the back cover.
105919463
  1. Remove the spring retainer, and then detach the fog light bulb.
  2. DO NOT TOUCH HALOGEN BULB!! Oils from skin will cause bulb to explode during operation.
Jul 27, 2011 | Subaru Forester Cars & Trucks
How to change light bulb in refrigerator
Unplug the Whirlpool refrigerator from the electrical outlet.
Step 2
Locate the bulb on the inside of the Whirlpool refrigerator.
Step 3
Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
Step 4
Unscrew the old light bulb.
Step 5
Screw in the new light bulb.
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
Jul 29, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
Change light bulb in fog light on 2003 subaru outback wagon
remove lower cover, remove cover on back of lamp and disconnect wire then unhook clip (clip just swings to the side) and remove bulb. dont touch new bulb on the glass part ,will weakin life of lamp. goodluck.
Oct 19, 2009 | 2003 Subaru Outback
How do I change a headlight bulb in a S60 60
Bulb is an H7 55w - price depends on brand (Hella or Sylvania Silver Star much higher than standard Sylvania). To change, open hood and look for round plastic cover over back of headlight. It's about the diameter of a big orange. Turn to remove. Remove black plastic connector (2 wires) from the bulb BEFORE you remove the spring holding the bulb in. New bulb goes in with the small square tab pointing up. Don't touch the glass part of bulb with your hands - your body oil will cause it to fail sooner. Getting the spring back on can take some effort. Then reconnect wire. And be sure to put the plastic cover back on.
Mar 17, 2009 | 2006 Volvo S60
How to change headlight in 2000 chrysler sebring convertible
There is a cover over the bulb that is removed by turning counter clockwise. (as viewed from the back of the housing)
Remove the spring clip that holds the bulb and pull out bulb.
Plug in new bulb (do not touch glass with hands) and install re-install spring clip and back cover.
Mar 15, 2009 | 2000 Chrysler Sebring
Headlight repair on 2003 Mercedes Benz E320
how do you change left low beam bulb on 2003 mercedes e320
Mar 15, 2009 | 2003 Mercedes-Benz E-Class
HOW CHANGE DE BULB?
On the side you plug everything to.... has 2 screws.remove them ..after completly removing screws..remove cover plate remove the 2 screws holding the bulb housing... you will see a hinged flap pull on this and the whole unit comes out..DO NOT REMOVE IF BULB IS HOT!!!!!
The new bulb comes with a new housing Please do not touch the bulb the oil from your hands will reduce the life of your bulb..Slide the new one in put the screws back, , the cover back and thats it
Oct 07, 2008 | Philips ProScreen 4650 Multimedia...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
